REST API reference
Delete the Vscan scanner-pool configuration
Deletes the Vscan scanner-pool configuration to remove all scanner-pools associated with a specified SVM. Use this endpoint when you need to clear Vscan configurations, ensuring Vscan is disabled on the SVM first.
HTTP method and endpoint
DELETE /protocols/vscan/{svm.uuid}/scanner-pools/{name}
Introduced in
ONTAP 9.6
Usage notes
Important notes:
  • The Vscan scanner-pool DELETE endpoint deletes all of the Vscan scanner-pools for a specified SVM.
  • If a Vscan is enabled, it requires at least one scanner-pool to be in the active state. Therefore, disable Vscan on the specified SVM so all the scanner-pools configured on that SVM can be deleted.
  • vserver vscan scanner-pool delete
name
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10027070
Attempting to delete a scanner-pool but it is the only active scanner-pool for a Vscan enabled on the SVM
10027064
Attempting to delete a scanner-pool with a data SVM which was created with an administrative SVM
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
