Delete a multi-admin-verify request
Deletes a multi-admin-verify request to remove pending verification tasks from the system.
HTTP method and endpoint
DELETE /security/multi-admin-verify/requests/{index}
Introduced in
ONTAP 9.11
index |
string |
path |
True |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
