REST API reference
Delete an event destination
Deletes an event destination, removing it from the current configuration. Use this when you need to manage or update the available event notification settings.
HTTP method and endpoint
DELETE /support/ems/destinations/{name}
Introduced in
ONTAP 9.6
  • event notification destination delete
  • event notification delete
name
string
path
True
Destination name
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983152
Default destinations cannot be modified or removed
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
