REST API reference
Retrieve a counter row
Obtains a counter row to access specific performance or utilization data within ONTAP. This helps in analyzing system metrics for monitoring or troubleshooting purposes.
HTTP method and endpoint
GET /cluster/counter/tables/{counter_table.name}/rows/{id}
Introduced in
ONTAP 9.11
Usage notes
Returns a single counter row.
counter_table.name
string
path
True
Counter table name.
id
string
path
True
Unique row identifier.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
aggregation
instance_counter_aggregation
Aggregation information about this counter.
counter_table
counter_table_reference
Counter table reference.
counters
array[counter]
Array of counter name/value pairs.
id
string
Unique row idenfier.
properties
array[counter_property]
Array of property name/value pairs.
      "href": "/api/resourcelink"
  "counter_table": {
    "name": "string"
  "counters": [
      "counters": [
          "label": "string",
          "values": [
            "integer"
      "labels": [
        "string"
      "name": "string",
      "values": [
        "integer"
  "id": "string",
  "properties": [
      "name": "string",
      "value": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
8585320
Table requested is not found
8586228
Invalid counter name request.
8586229
Invalid counter property request.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
complete
boolean
The aggregation state for this row. For non-aggregated tables: Not present For aggregated tables: If all requests to remote nodes for counter data are successful, then this value will be 'true'. If any requests to remote nodes fail, then this value will be 'false'.
count
integer
Number of nodes included in the aggregation of this counter.
_links
_links
name
string
Counter table name.
counter2d
Counters that represent the second dimension of a two-dimension counter.
label
string
Second dimension label.
values
array[integer]
List of values for the counter.
counter
Representation of a counter and contains one of the following:
  • Scalar counter populates the 'name' and 'value' fields.
  • A 1D array populates the 'name', 'labels' and 'values' fields.
  • A 2D array is represented as a list of counter entries.
"counters": [
// Scalar counter
    "name": "memory",
    "value": 4480
// one dimensional array "sys_read_latency_hist"
    "name": "sys_read_latency_hist",
    "labels": ["0 - <1ms", "1 - <2ms", ...],
    "values": [0, 0, ...]
// Two dimensional array "foo" with ["Label 1", "Label 2"] as the first
// array dimension and labels ["w", "x", "y"] for the 2nd dimension
    "name": "foo",
    "labels": ["Label 1", "Label 2"],
    "counters": [
            "label": "x",
            "values": [0, 0]
            "label": "y",
            "values": [0, 0]
            "label": "z",
            "values": [0, 0]
counters
array[counter2d]
List of labels and values for the second dimension.
labels
array[string]
List of labels for the first dimension.
name
string
Counter name.
value
integer
Scalar value.
values
array[integer]
List of values in a one-dimensional counter.
counter_property
Single string counter entry.
name
string
Property name.
value
string
Property value.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
