REST API reference
Retrieve ports
Retrieves a collection of physical, VLAN, and LAG ports for an entire cluster to view the network configuration and manage connectivity across your ONTAP environment.
HTTP method and endpoint
GET /network/ethernet/ports
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of ports (physical, VLAN and LAG) for an entire cluster.
  • network port show
  • network port ifgrp show
  • network port vlan show
interface_count
integer
query
False
Filter by interface_count
  • Introduced in: 9.11
vlan.base_port.name
string
query
False
Filter by vlan.base_port.name
vlan.base_port.uuid
string
query
False
Filter by vlan.base_port.uuid
vlan.base_port.node.name
string
query
False
Filter by vlan.base_port.node.name
vlan.tag
integer
query
False
Filter by vlan.tag
  • Max value: 4095
  • Min value: 0
speed
integer
query
False
Filter by speed
enabled
boolean
query
False
Filter by enabled
state
string
query
False
Filter by state
reachable_broadcast_domains.name
string
query
False
Filter by reachable_broadcast_domains.name
  • Introduced in: 9.8
reachable_broadcast_domains.ipspace.name
string
query
False
Filter by reachable_broadcast_domains.ipspace.name
reachable_broadcast_domains.uuid
string
query
False
Filter by reachable_broadcast_domains.uuid
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
mac_address
string
query
False
Filter by mac_address
name
string
query
False
Filter by name
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.status
string
query
False
Filter by statistics.status
statistics.device.link_down_count_raw
integer
query
False
Filter by statistics.device.link_down_count_raw
statistics.device.transmit_raw.discards
integer
query
False
Filter by statistics.device.transmit_raw.discards
statistics.device.transmit_raw.packets
integer
query
False
Filter by statistics.device.transmit_raw.packets
statistics.device.transmit_raw.errors
integer
query
False
Filter by statistics.device.transmit_raw.errors
statistics.device.receive_raw.discards
integer
query
False
Filter by statistics.device.receive_raw.discards
statistics.device.receive_raw.packets
integer
query
False
Filter by statistics.device.receive_raw.packets
statistics.device.receive_raw.errors
integer
query
False
Filter by statistics.device.receive_raw.errors
statistics.device.timestamp
string
query
False
Filter by statistics.device.timestamp
statistics.timestamp
string
query
False
Filter by statistics.timestamp
uuid
string
query
False
Filter by uuid
reachability
string
query
False
Filter by reachability
type
string
query
False
Filter by type
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.duration
string
query
False
Filter by metric.duration
metric.status
string
query
False
Filter by metric.status
metric.timestamp
string
query
False
Filter by metric.timestamp
rdma_protocols
string
query
False
Filter by rdma_protocols
  • Introduced in: 9.10
lag.mode
string
query
False
Filter by lag.mode
lag.active_ports.name
string
query
False
Filter by lag.active_ports.name
lag.active_ports.uuid
string
query
False
Filter by lag.active_ports.uuid
lag.active_ports.node.name
string
query
False
Filter by lag.active_ports.node.name
lag.distribution_policy
string
query
False
Filter by lag.distribution_policy
lag.member_ports.name
string
query
False
Filter by lag.member_ports.name
lag.member_ports.uuid
string
query
False
Filter by lag.member_ports.uuid
lag.member_ports.node.name
string
query
False
Filter by lag.member_ports.node.name
broadcast_domain.name
string
query
False
Filter by broadcast_domain.name
broadcast_domain.ipspace.name
string
query
False
Filter by broadcast_domain.ipspace.name
broadcast_domain.uuid
string
query
False
Filter by broadcast_domain.uuid
discovered_devices.system_name
string
query
False
Filter by discovered_devices.system_name
discovered_devices.platform
string
query
False
Filter by discovered_devices.platform
discovered_devices.version
string
query
False
Filter by discovered_devices.version
discovered_devices.capabilities
string
query
False
Filter by discovered_devices.capabilities
discovered_devices.chassis_id
string
query
False
Filter by discovered_devices.chassis_id
discovered_devices.remaining_hold_time
integer
query
False
Filter by discovered_devices.remaining_hold_time
discovered_devices.protocol
string
query
False
Filter by discovered_devices.protocol
discovered_devices.ip_addresses
string
query
False
Filter by discovered_devices.ip_addresses
discovered_devices.remote_port
string
query
False
Filter by discovered_devices.remote_port
discovered_devices.name
string
query
False
Filter by discovered_devices.name
mtu
integer
query
False
Filter by mtu
  • Min value: 68
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[port]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "broadcast_domain": {
        "ipspace": {
          "name": "ipspace1"
        "name": "bd1",
      "discovered_devices": [
          "capabilities": [
            "router",
            "switch"
          "chassis_id": "string",
          "ip_addresses": [
            "192.168.100.24",
            "192.168.100.26"
          "name": "ETY-R1S4-510Q13.datacenter.example.com",
          "platform": "93180YC-EX",
          "protocol": "cdp",
          "remote_port": "FastEthernet0/12",
          "system_name": "string",
          "version": "Cisco Nexus Operating System (NX-OS) Software, Version 8.1"
      "interface_count": 0,
      "lag": {
        "active_ports": [
            "name": "e1b",
            "node": {
              "name": "node1"
        "distribution_policy": "string",
        "member_ports": [
            "name": "e1b",
            "node": {
              "name": "node1"
        "mode": "string"
      "mac_address": "01:02:03:04:05:06",
      "metric": {
        "duration": "PT15S",
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25T11:20:13Z"
      "mtu": 1500,
      "name": "e1b",
      "node": {
        "name": "node1",
      "rdma_protocols": [
        "roce"
      "reachability": "ok",
      "reachable_broadcast_domains": [
          "ipspace": {
            "name": "ipspace1"
          "name": "bd1",
      "speed": 1000,
      "state": "string",
      "statistics": {
        "device": {
          "link_down_count_raw": 3,
          "receive_raw": {
            "discards": 100,
            "errors": 200,
            "packets": 500
          "timestamp": "2017-01-25T11:20:13Z",
          "transmit_raw": {
            "discards": 100,
            "errors": 200,
            "packets": 500
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "type": "string",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "vlan": {
        "base_port": {
          "name": "e1b",
          "node": {
            "name": "node1"
        "tag": 100
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
name
string
Name of the broadcast domain's IPspace
broadcast_domain
Broadcast domain UUID along with a readable name. Either the UUID or both names may be provided on input.
_links
_links
ipspace
ipspace
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
discovered_devices
capabilities
array[string]
The list of the capabilities of the discovered device.
chassis_id
string
Identifier associated with this specific discovered device, useful for locating the device in a data center.
ip_addresses
array[string]
The IP addresses on the discovered device.
name
string
Name of the discovered device.
platform
string
Hardware platform of the discovered device.
protocol
string
The protocol used to identify the discovered device. This can have a value of CDP or LLDP.
remaining_hold_time
integer
The number of seconds until the discovered device entry expires and is removed.
remote_port
string
The name of the remote port on the discovered device. The format is dependent on the reporting device.
system_name
string
Additional name used to identifiy a specific piece of equipment.
version
string
The version of the software running on the discovered device.
node
name
string
Name of node on which the port is located.
active_ports
_links
_links
name
string
node
node
uuid
string
member_ports
_links
_links
name
string
node
node
uuid
string
lag
active_ports
array[active_ports]
Active ports of a LAG (ifgrp). (Some member ports may be inactive.)
distribution_policy
string
Policy for mapping flows to ports for outbound packets through a LAG (ifgrp).
member_ports
array[member_ports]
Array of ports belonging to the LAG, regardless of their state.
mode
string
Determines how the ports interact with the switch.
throughput
The rate of throughput bytes per second observed at the interface.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
metric
The most recent sample of I/O metrics for the port.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
node
_links
_links
name
string
uuid
string
_links
_links
ipspace
ipspace
name
string
uuid
string
receive_raw
Packet receive counters for the Ethernet port.
discards
integer
Total number of discarded packets.
errors
integer
Number of packet errors.
packets
integer
Total packet count.
transmit_raw
Packet transmit counters for the Ethernet port.
discards
integer
errors
integer
packets
integer
Total packet count.
device
Device-related counters for the port object. These counters are applicable at the lowest layer of the networking stack. These values can be used to calculate both transmit and receive packet and error rates by comparing two samples taken at different times and calculating the increase in counter value divided by the elapsed time between the two samples.
link_down_count_raw
integer
The number of link state changes from up to down seen on the device.
receive_raw
receive_raw
timestamp
string
The timestamp when the device specific counters were collected.
transmit_raw
transmit_raw
throughput_raw
Throughput bytes observed at the port object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the port.
device
device
status
string
throughput_raw
throughput_raw
timestamp
string
The timestamp of the throughput_raw performance data.
base_port
_links
_links
name
string
node
node
uuid
string
vlan
base_port
base_port
tag
integer
VLAN ID
port
_links
_links
broadcast_domain
broadcast_domain
discovered_devices
array[discovered_devices]
Discovered devices
enabled
boolean
interface_count
integer
Number of interfaces hosted. This field is only applicable for cluster administrators. No value is returned for SVM administrators. If the node hosting a port is not healthy no value will be returned.
lag
lag
mac_address
string
metric
metric
mtu
integer
MTU of the port in bytes. Set by broadcast domain.
name
string
Portname, such as e0a, e1b-100 (VLAN on Ethernet), a0c (LAG/ifgrp), a0d-200 (VLAN on LAG/ifgrp), e0a.pv1 (p-VLAN, in select environments only)
node
node
rdma_protocols
array[string]
Supported RDMA offload protocols
reachability
string
Reachability status of the port. Enum value "ok" is the only acceptable value for a PATCH request to repair a port.
array[reachable_broadcast_domains]
Reachable broadcast domains.
speed
integer
Link speed in Mbps
state
string
Operational state of the port. The state is set to 'down' if the operational state of the port is down. The state is set to 'up' if the link state of the port is up and the port is healthy. The state is set to 'up' if the link state of the port is up and configured to ignore health status. The state is 'degraded' if the link state of the port is up, and the port is not healthy.
statistics
statistics
type
string
Type of physical or virtual port
uuid
string
Port UUID
vlan
vlan
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
