Retrieve an FC login
Retrieves an FC login to access information about Fibre Channel connections for monitoring or troubleshooting purposes.
HTTP method and endpoint
GET /network/fc/logins/{interface.uuid}/{initiator.wwpn}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver fcp initiator show
Learn more
NVMe: DOC /network/fc/logins
interface.uuid |
string |
path |
True |
The unique identifier of the FC interface through which the initiator logged in. |
initiator.wwpn |
string |
path |
True |
The world wide port name (WWPN) of the initiator. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
igroups |
array[igroups] |
The initiator groups in which the initiator is a member. |
initiator |
Information about the logged in FC initiator. |
interface |
An FC interface. |
protocol |
string |
The data protocol used to perform the login. |
svm |
"next": {
"href": "/api/resourcelink"
"igroups": [
"name": "igroup1",
"initiator": {
"aliases": [
"alias1"
"comment": "This is an FC initiator for host 5",
"port_address": "5060A",
"wwnn": "2f:a0:00:a0:98:0b:56:13",
"wwpn": "2f:a0:00:a0:98:0b:56:13"
"interface": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"protocol": "string",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4 |
The Fibre Channel login specified does not exist. |
5373983 |
An invalid WWPN was supplied. |
5374881 |
The Fibre Channel interface specified does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
igroups
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
initiator
aliases |
array[string] |
The logged in initiator world wide port name (WWPN) aliases. |
comment |
string |
A comment available for use by the administrator. This is modifiable from the initiator REST endpoint directly. See PATCH /protocols/san/igroups/{igroup.uuid}/initiators/{name} . |
port_address |
string |
The port address of the initiator's FC port. Each port in an FC switched fabric has its own unique port address for routing purposes. The port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the address given by a switch to the initiator port. This is useful for obtaining statistics and diagnostic information from FC switches. This is a hexadecimal encoded numeric value. |
wwnn |
string |
The logged in initiator world wide node name (WWNN). |
wwpn |
string |
The logged in initiator WWPN. |
interface
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
