REST API reference
Retrieve an applied central access rule for an SVM
Retrieves an applied central access rule for a specific SVM to understand which rules are currently in effect. This can help you manage and audit access policies within your storage environment.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/central-access-rules/{name}
Introduced in
ONTAP 9.12
Usage notes
Retrieves applied central access rule for specified SVM.
  • vserver cifs group-policy central-access-rule show-applied
name
string
path
True
Central access rule name.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
create_time
string
Policy creation timestamp.
current_permission
string
Effective security policy in security descriptor definition language format.
description
string
Description about the policy.
name
string
proposed_permission
string
Proposed security policy in security descriptor definition language format.
resource_criteria
string
Criteria to scope resources for which access rules apply.
svm
svm
Will not be populated for objects that are yet to be applied.
update_time
string
Last policy modification timestamp.
  "create_time": "2018-01-01T12:00:00-04:00",
  "current_permission": "O:SYG:SYD:AR(A;;FA;;;WD)",
  "description": "rule #1",
  "name": "p1",
  "proposed_permission": "O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY)",
  "resource_criteria": "department",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "update_time": "2018-01-01T12:00:00-04:00"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
