REST API reference
Retrieve the NFS configuration for an SVM
Retrieves the NFS configuration for a storage virtual machine (SVM) to understand its current network file system settings.
HTTP method and endpoint
GET /protocols/nfs/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NFS configuration of an SVM.
  • vserver nfs show
  • vserver nfs status
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
access_cache_config
access_cache_config
auth_sys_extended_groups_enabled
boolean
Specifies whether or not extended groups support over AUTH_SYS is enabled.
credential_cache
credential_cache
enabled
boolean
Specifies if the NFS service is administratively enabled.
exports
exports
extended_groups_limit
integer
Specifies the maximum auxillary groups supported over AUTH_SYS and RPCSEC_GSS.
file_session_io_grouping_count
integer
Number of I/O operations on a file to be grouped and considered as one session for event generation applications, such as FPolicy.
file_session_io_grouping_duration
integer
The duration for which I/O operations on a file will be grouped and considered as one session for event generation applications, such as FPolicy.
metric
metric
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
protocol
protocol
protocol_access_rules
qtree
qtree
root
root
rquota_enabled
boolean
Specifies whether or not the remote quota feature is enabled.
security
security
showmount_enabled
boolean
Specifies whether or not the showmount feature is enabled.
state
string
Specifies the state of the NFS service on the SVM. The following values are supported:
  • online - NFS server is ready to accept client requests.
  • offline - NFS server is not ready to accept client requests.
statistics
statistics
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
svm
svm
transport
transport
vstorage_enabled
boolean
Specifies whether or not the VMware vstorage feature is enabled.
windows
windows
      "href": "/api/resourcelink"
  "credential_cache": {
    "negative_ttl": 7200000,
    "positive_ttl": 7200000,
    "transient_error_ttl": 72000
  "exports": {
    "name_service_lookup_protocol": "string"
  "extended_groups_limit": 32,
  "file_session_io_grouping_count": 5000,
  "file_session_io_grouping_duration": 120,
  "metric": {
    "v3": {
      "duration": "PT15S",
      "iops": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput": {
        "read": 200,
        "total": 1000,
        "write": 100
      "timestamp": "2017-01-25T11:20:13Z"
    "v4": {
      "iops": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput": {
        "read": 200,
        "total": 1000,
        "write": 100
    "v41": {
      "iops": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput": {
        "read": 200,
        "total": 1000,
        "write": 100
  "protocol": {
    "v40_features": {
      "acl_max_aces": 500
    "v41_features": {
      "implementation_domain": "string",
      "implementation_name": "string"
    "v4_id_domain": "string"
  "protocol_access_rules": {
    "cifs_access_type": "string",
    "nfs3_access_type": "string",
    "nfs4_access_type": "string"
  "security": {
    "chown_mode": "string",
    "ntfs_unix_security": "string",
    "permitted_encryption_types": [
      "string"
  "state": "string",
  "statistics": {
    "v3": {
      "iops_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
    "v4": {
      "iops_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
    "v41": {
      "iops_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
  "svm": {
    "name": "svm1",
  "transport": {
    "tcp_max_transfer_size": 16384
  "windows": {
    "default_user": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
access_cache_config
harvest_timeout
integer
Specifies the time after which an entry is deleted from the access cache, if unused.
isDnsTTLEnabled
boolean
Specifies whether Dns TTL is enabled.
ttl_failure
integer
Specifies the time to live value for entries for which a failure was encountered, in seconds.
ttl_negative
integer
Specifies the time to live value of a negative access cache, in seconds.
ttl_positive
integer
Specifies the time to live value of a positive access cache, in seconds.
credential_cache
negative_ttl
integer
Specifies the age in milliseconds, of the negative cached credentials after which they are cleared from the cache.
positive_ttl
integer
Specifies the age in milliseconds, of the positive cached credentials after which they are cleared from the cache.
transient_error_ttl
integer
Specifies the age in milliseconds, of the cached entries during a transient error situation.
exports
string
Specifies the protocol to use for doing name service lookups.
netgroup_trust_any_nsswitch_no_match
boolean
Specifies if you can consider a no-match result from any of the netgroup ns-switch sources to be authoritative. If this option is enabled, then a no-match response from any of the netgroup ns-switch sources is deemed conclusive even if other sources could not be searched.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
v3
The NFSv3 operations
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
v4
The NFSv4 operations
_links
_links
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
v41
The NFSv4.1 operations
_links
_links
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
metric
v3
v3
v4
v4
v41
v41
v3_features
connection_drop
boolean
Specfies whether the dropping of a connection when an NFSv3 request is dropped is enabled.
ejukebox_enabled
boolean
Specifies whether NFSv3 EJUKEBOX error is enabled.
fsid_change
boolean
Specifies whether the change in FSID as NFSv3 clients traverse filesystems should be shown.
mount_daemon_port
integer
Specifies which port the NFS mount daemon (mountd) uses.
mount_root_only
boolean
Specifies whether the SVM allows MOUNT protocol calls only from privileged ports (port numbers less than 1024).
network_lock_manager_port
integer
Specifies which port the Network lock manager uses.
network_status_monitor_port
integer
Specifies which port the Network status monitor port uses.
rquota_daemon_port
integer
Specifies which port the NFS quota daemon port uses.
v40_features
acl_enabled
boolean
Specifies whether NFSv4.0 ACLs is enabled.
acl_max_aces
integer
Specifies the maximum number of aces in a NFSv4.0 ACL.
acl_preserve
boolean
Specifies if the NFSv4 ACL is preserved or dropped when chmod is performed. In unified security style, this parameter also specifies if NTFS file permissions are preserved or dropped when chmod, chgrp, or chown are performed.
read_delegation_enabled
boolean
Specifies whether NFSv4.0 Read Delegation is enabled.
write_delegation_enabled
boolean
Specifies whether NFSv4.0 Write Delegation is enabled.
v41_features
acl_enabled
boolean
Specifies whether NFSv4.1 or later ACLs is enabled.
string
Specifies the NFSv4.1 or later implementation ID domain.
implementation_name
string
Specifies the NFSv4.1 or later implementation ID name.
pnfs_enabled
boolean
Specifies whether NFSv4.1 or later Parallel NFS is enabled.
boolean
Specifies whether NFSv4.1 or later Read Delegation is enabled.
trunking_enabled
boolean
Specifies whether NFSv4.1 or later trunking is enabled.
boolean
Specifies whether NFSv4.1 or later Write Delegation is enabled.
v42_features
seclabel_enabled
boolean
Specifies whether NFSv4.2 or later security label is enabled.
sparsefile_ops_enabled
boolean
Specifies whether NFSv4.2 or later sparsefile operation is enabled.
xattrs_enabled
boolean
Specifies whether NFSv4.2 or later extended attributes is enabled.
protocol
v3_64bit_identifiers_enabled
boolean
Specifies whether 64-bit support for NFSv3 FSIDs and file IDs is enabled.
v3_enabled
boolean
Specifies whether NFSv3 protocol is enabled.
v3_features
v3_features
v40_enabled
boolean
Specifies whether NFSv4.0 protocol is enabled.
v40_features
v40_features
v41_enabled
boolean
Specifies whether NFSv4.1 or later protocol is enabled.
v41_features
v41_features
v42_features
v42_features
v4_64bit_identifiers_enabled
boolean
Specifies whether 64-bit support for NFSv4.x FSIDs and file IDs is enabled.
v4_id_domain
string
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol.
cifs_access_type
string
Access available for the CIFS protocol.
nfs3_access_type
string
Access available for the NFSv3 protocol.
nfs4_access_type
string
Access available for the NFSv4 protocol.
qtree
export_enabled
boolean
Specifies whether qtree export is enabled.
validate_export
boolean
Specifies whether qtree export validation is enabled.
root
ignore_nt_acl
boolean
Specifies whether Windows ACLs affect root access from NFS. If this option is enabled, root access from NFS ignores the NT ACL set on the file or directory.
skip_write_permission_check
boolean
Specifies if permission checks are to be skipped for NFS WRITE calls from root/owner. For copying read-only files to a destination folder which has inheritable ACLs, this option must be enabled.
security
chown_mode
string
Specifies whether file ownership can be changed only by the superuser, or if a non-root user can also change file ownership. If you set this parameter to restricted, file ownership can be changed only by the superuser, even though the on-disk permissions allow a non-root user to change file ownership. If you set this parameter to unrestricted, file ownership can be changed by the superuser and by the non-root user, depending upon the access granted by on-disk permissions. If you set this parameter to use-export-policy, file ownership can be changed in accordance with the relevant export rules.
nt_acl_display_permission
boolean
Controls the permissions that are displayed to NFSv3 and NFSv4 clients on a file or directory that has an NT ACL set. When true, the displayed permissions are based on the maximum access granted by the NT ACL to any user. When false, the displayed permissions are based on the minimum access granted by the NT ACL to any user.
ntfs_unix_security
string
Specifies how NFSv3 security changes affect NTFS volumes. If you set this parameter to ignore, ONTAP ignores NFSv3 security changes. If you set this parameter to fail, this overrides the UNIX security options set in the relevant export rules. If you set this parameter to use_export_policy, ONTAP processes NFSv3 security changes in accordance with the relevant export rules.
  • Default value: 1
  • enum: ["ignore", "fail", "use_export_policy"]
  • Introduced in: 9.11
array[string]
Specifies the permitted encryption types for Kerberos over NFS.
rpcsec_context_idle
integer
Specifies, in seconds, the amount of time a RPCSEC_GSS context is permitted to remain unused before it is deleted.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
v3
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
v4
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
v41
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
statistics
v3
v3
v4
v4
v41
v41
svm
_links
_links
name
string
The name of the SVM.
uuid
string
transport
rdma_enabled
boolean
Specifies whether RDMA transport is enabled for the NFS server.
tcp_enabled
boolean
Specifies whether TCP transports are enabled on the server.
integer
Specifies the maximum transfer size in bytes, that the storage system negotiates with the client for TCP transport of data for NFSv3 and NFSv4.x protocols. The range is 8192 to 1048576.
udp_enabled
boolean
Specifies whether UDP transports are enabled on the server.
windows
default_user
string
Specifies the default Windows user for the NFS server.
map_unknown_uid_to_default_user
boolean
Specifies whether or not the mapping of an unknown UID to the default Windows user is enabled.
v3_ms_dos_client_enabled
boolean
Specifies whether NFSv3 MS-DOS client support is enabled.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
