REST API reference
Retrieve an NVMe service
Retrieves an NVMe service to access its current configuration and status within your storage environment.
HTTP method and endpoint
GET /protocols/nvme/services/{svm.uuid}
Introduced in
ONTAP 9.6
  • vserver nvme show
svm.uuid
string
path
True
The unique identifier of the SVM whose NVMe service is to be retrieved.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
enabled
boolean
The administrative state of the NVMe service. The NVMe service can be disabled to block all NVMe connectivity to the SVM.
This is optional in POST and PATCH. The default setting is true (enabled) in POST.
metric
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
statistics
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
svm
svm
      "href": "/api/resourcelink"
  "metric": {
    "duration": "PT15S",
    "fc": {
      "iops": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput": {
        "read": 200,
        "total": 1000,
        "write": 100
      "timestamp": "2017-01-25T11:20:13Z"
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "tcp": {
      "iops": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput": {
        "read": 200,
        "total": 1000,
        "write": 100
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
  "statistics": {
    "fc": {
      "iops_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "tcp": {
      "iops_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "throughput_raw": {
        "read": 200,
        "total": 1000,
        "write": 100
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The supplied SVM does not exist.
72089651
The supplied SVM does not have an NVMe service.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
fc
The NVMe/FC portion of the aggregated metrics.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
tcp
The NVMe/TCP portion of the aggregated metrics.
_links
_links
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
metric
_links
_links
duration
string
fc
fc
iops
iops
latency
latency
status
string
tcp
tcp
throughput
throughput
timestamp
string
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
fc
The NVMe/FC portion of the aggregated statistics.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
tcp
The NVMe/TCP portion of the aggregated statistics.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
statistics
fc
fc
iops_raw
iops_raw
latency_raw
latency_raw
status
string
tcp
tcp
throughput_raw
throughput_raw
timestamp
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
