REST API reference
Retrieve NVMe protocol historical performance metrics
Accesses historical performance metrics for the NVMe protocol of an SVM, giving you insights into past performance trends.
HTTP method and endpoint
GET /protocols/nvme/services/{svm.uuid}/metrics
Introduced in
ONTAP 9.7
Usage notes
Retrieves historical performance metrics for NVMe protocol of an SVM.
fc.throughput.read
integer
query
False
Filter by fc.throughput.read
  • Introduced in: 9.10
fc.throughput.write
integer
query
False
Filter by fc.throughput.write
fc.throughput.total
integer
query
False
Filter by fc.throughput.total
fc.iops.write
integer
query
False
Filter by fc.iops.write
fc.iops.total
integer
query
False
Filter by fc.iops.total
fc.iops.other
integer
query
False
Filter by fc.iops.other
fc.iops.read
integer
query
False
Filter by fc.iops.read
fc.status
string
query
False
Filter by fc.status
fc.duration
string
query
False
Filter by fc.duration
fc.latency.write
integer
query
False
Filter by fc.latency.write
fc.latency.total
integer
query
False
Filter by fc.latency.total
fc.latency.other
integer
query
False
Filter by fc.latency.other
fc.latency.read
integer
query
False
Filter by fc.latency.read
throughput.read
integer
query
False
Filter by throughput.read
throughput.write
integer
query
False
Filter by throughput.write
throughput.total
integer
query
False
Filter by throughput.total
tcp.throughput.read
integer
query
False
Filter by tcp.throughput.read
tcp.throughput.write
integer
query
False
Filter by tcp.throughput.write
tcp.throughput.total
integer
query
False
Filter by tcp.throughput.total
tcp.iops.write
integer
query
False
Filter by tcp.iops.write
tcp.iops.total
integer
query
False
Filter by tcp.iops.total
tcp.iops.other
integer
query
False
Filter by tcp.iops.other
tcp.iops.read
integer
query
False
Filter by tcp.iops.read
tcp.status
string
query
False
Filter by tcp.status
tcp.duration
string
query
False
Filter by tcp.duration
tcp.latency.write
integer
query
False
Filter by tcp.latency.write
tcp.latency.total
integer
query
False
Filter by tcp.latency.total
tcp.latency.other
integer
query
False
Filter by tcp.latency.other
tcp.latency.read
integer
query
False
Filter by tcp.latency.read
timestamp
string
query
False
Filter by timestamp
duration
string
query
False
Filter by duration
latency.write
integer
query
False
Filter by latency.write
latency.total
integer
query
False
Filter by latency.total
latency.other
integer
query
False
Filter by latency.other
latency.read
integer
query
False
Filter by latency.read
status
string
query
False
Filter by status
iops.write
integer
query
False
Filter by iops.write
iops.total
integer
query
False
Filter by iops.total
iops.other
integer
query
False
Filter by iops.other
iops.read
integer
query
False
Filter by iops.read
svm.uuid
string
path
True
Unique identifier of the SVM.
interval
string
query
False
The time range for the data. Examples can be 1h, 1d, 1m, 1w, 1y. The period for each time range is as follows:
  • 1h: Metrics over the most recent hour sampled over 15 seconds.
  • 1d: Metrics over the most recent day sampled over 5 minutes.
  • 1w: Metrics over the most recent week sampled over 30 minutes.
  • 1m: Metrics over the most recent month sampled over 2 hours.
  • 1y: Metrics over the most recent year sampled over a day.
  • Default value: 1
  • enum: ["1h", "1d", "1w", "1m", "1y"]
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "duration": "PT15S",
      "fc": {
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
      "iops": {
        "read": 200,
        "total": 1000,
        "write": 100
      "latency": {
        "read": 200,
        "total": 1000,
        "write": 100
      "status": "ok",
      "svm": {
      "tcp": {
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
      "throughput": {
        "read": 200,
        "total": 1000,
        "write": 100
      "timestamp": "2017-01-25T11:20:13Z"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
fc
The NVMe/FC portion of the aggregated metrics.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
svm
uuid
string
tcp
The NVMe/TCP portion of the aggregated metrics.
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
records
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
_links
_links
duration
string
fc
fc
iops
iops
latency
latency
status
string
svm
svm
tcp
tcp
throughput
throughput
timestamp
string
The timestamp of the performance data.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
