REST API reference
Retrieve an S3 policy configuration
Retrieves the S3 policy configuration of an SVM to view or manage its policy settings for object storage. This helps you ensure the SVM's storage policies align with your organizational requirements.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.8
  • vserver object-store-server policy show
name
string
path
True
Policy name
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
comment
string
Can contain any additional information about the S3 policy.
name
string
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
read-only
boolean
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method.
statements
array[s3_policy_statement]
Specifies the policy statements.
svm
svm
  "comment": "S3 policy.",
  "name": "Policy1",
  "statements": [
      "actions": [
      "effect": "allow",
      "index": 0,
      "resources": [
        "bucket1",
        "bucket1/*"
      "sid": "FullAccessToBucket1"
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
s3_policy_statement
Specifies information about a single access policy statement.
actions
array[string]
For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
  • GetObject - retrieves objects from a bucket.
  • PutObject - puts objects in a bucket.
  • DeleteObject - deletes objects from a bucket.
  • ListBucket - lists the objects in a bucket.
  • GetBucketAcl - retrieves the access control list (ACL) of a bucket.
  • GetObjectAcl - retrieves the access control list (ACL) of an object.
  • ListAllMyBuckets - lists all of the buckets in a server.
  • ListBucketMultipartUploads - lists the multipart uploads in progress for a bucket.
  • ListMultipartUploadParts - lists the parts in a multipart upload.
  • CreateBucket - creates a new bucket.
  • DeleteBucket - deletes an existing bucket.
  • GetObjectTagging - retrieves the tag set of an object.
  • PutObjecttagging - sets the tag set for an object.
  • DeleteObjectTagging - deletes the tag set of an object.
  • GetBucketLocation - retrieves the location of a bucket.
  • GetBucketVersioning - retrieves the versioning configuration of a bucket.
  • PutBucketVersioning - modifies the versioning configuration of a bucket.
  • ListBucketVersions - lists the object versions in a bucket.
  • PutBucketPolicy - puts bucket policy on the bucket specified.
  • GetBucketPolicy - retrieves the bucket policy of a bucket.
  • DeleteBucketPolicy - deletes the policy created for a bucket. The wildcard character "*" can be used to form a regular expression for specifying actions.
effect
string
Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
index
integer
Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated and is retrieved using the GET method.
resources
array[string]
sid
string
Specifies the statement identifier which contains additional information about the statement.
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
