Retrieve the S3 policies in SVM configuration
Retrieves the S3 policies configured for the Storage Virtual Machine (SVM). Use this to review the current S3 policy settings applied within your SVM environment.
HTTP method and endpoint
GET /protocols/s3/services/{svm.uuid}/policies
Introduced in
ONTAP 9.8
Usage notes
Retrieves the S3 policies SVM configuration.
Related ONTAP commands
vserver object-store-server policy show
svm.name |
string |
query |
False |
Filter by svm.name |
statements.actions |
string |
query |
False |
Filter by statements.actions |
statements.resources |
string |
query |
False |
Filter by statements.resources |
statements.sid |
string |
query |
False |
Filter by statements.sid
statements.effect |
string |
query |
False |
Filter by statements.effect |
statements.index |
integer |
query |
False |
Filter by statements.index |
read-only |
boolean |
query |
False |
Filter by read-only |
comment |
string |
query |
False |
Filter by comment
name |
string |
query |
False |
Filter by name
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[s3_policy] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"comment": "S3 policy.",
"name": "Policy1",
"statements": [
"actions": [
"effect": "allow",
"index": 0,
"resources": [
"bucket1",
"bucket1/*"
"sid": "FullAccessToBucket1"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
s3_policy_statement
Specifies information about a single access policy statement.
actions |
array[string] |
For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
effect |
string |
Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access. |
index |
integer |
Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated and is retrieved using the GET method. |
resources |
array[string] |
sid |
string |
Specifies the statement identifier which contains additional information about the statement. |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
s3_policy
An S3 policy is an object. It defines resource (bucket, folder or object) permissions. These policies get evaluated when an object store user user makes a request. Permissions in the policies determine whether the request is allowed or denied.
comment |
string |
Can contain any additional information about the S3 policy. |
name |
string |
Specifies the name of the policy. A policy name length can range from 1 to 128 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
read-only |
boolean |
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method. |
statements |
array[s3_policy_statement] |
Specifies the policy statements. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
