REST API reference
Retrieve a multi-admin-verify rule
Retrieves a multi-admin-verify rule to review its configuration and ensure compliance with verification policies.
HTTP method and endpoint
GET /security/multi-admin-verify/rules/{owner.uuid}/{operation}
Introduced in
ONTAP 9.11
owner.uuid
string
path
True
operation
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
approval_expiry
string
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used.
approval_groups
array[approval_groups]
List of approval groups that are allowed to approve requests for rules that don't have approval groups.
auto_request_create
boolean
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
  • Default value: 1
  • Introduced in: 9.11
  • x-nullable: true
create_time
string
execution_expiry
string
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used.
operation
string
Command that requires one or more approvals.
owner
owner
The owner of the rule. The only valid owner is currently the cluster.
query
string
When specified, this property limits the entries that require approvals to those that match the specified query.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
system_defined
boolean
Specifies whether the rule is system-defined or user-defined.
  "approval_expiry": "string",
  "approval_groups": [
      "name": "string"
  "create_time": "string",
  "execution_expiry": "string",
  "operation": "string",
  "owner": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "query": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
approval_groups
name
string
Name of the approval group.
string
self
owner
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
