REST API reference
Retrieve a SnapMirror relationship
Retrieves details of a SnapMirror relationship, useful for understanding the current replication state between two storage endpoints.
HTTP method and endpoint
GET /snapmirror/relationships/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a SnapMirror relationship.
  • snapmirror show
  • snapmirror list-destinations
Expensive properties
  • source.consistency_group_volumes.name
  • destination.consistency_group_volumes.name
Example
GET "/api/snapmirror/relationships/caf545a2-fc60-11e8-aa13-005056a707ff/"
uuid
string
path
True
Relationship UUID
list_destinations_only
boolean
query
False
Set to true to show relationships from the source only.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
consistency_group_failover
snapmirror_consistency_group_failover
SnapMirror Consistency Group failover information. The SnapMirror Consistency Group failover can be a planned or an unplanned operation. Only active SnapMirror Consistency Group failover operation progress can be monitored using this object. In case of an error during the failover operation, the property "consistency_group_failover.error" holds the reason for the error. ONTAP automatically retries any failed SnapMirror Consistency Group failover operation.
  • Introduced in: 9.8
  • readOnly: 1
destination
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
  • Introduced in: 9.6
exported_snapshot
string
Snapshot copy exported to clients on destination.
group_type
string
Specifies the group type of the top level SnapMirror relationship. The volume relationships are shown as none, the SVMDR relationships are shown as svm_dr, the Consistency Group relationships are shown as consistency_group, and the FlexGroup volume relationships are shown as flexgroup.
healthy
boolean
Is the relationship healthy?
identity_preservation
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type. This "identity_preservation" overrides the "identity_preservation" set on the SnapMirror relationship's policy.
lag_time
string
Time since the exported Snapshot copy was created.
last_transfer_type
string
Specifies the operation type of the last transfer that occured on the relationship. The initialize transfer occurs when the relationship state changes from uninitialized to snapmirrored or in_sync. The update transfer occurs when the snapshots are transferred from the source endpoint to the destination endpoint as part of scheduled or manual update. The resync transfer occurs when the relationship state changes from broken_off to snapmirrored or in_sync. The restore transfer occurs when the snapshot is restored from a destination endpoint to another endpoint.
policy
policy
Basic policy information of the relationship.
preserve
boolean
Set to true on resync to preserve Snapshot copies on the destination that are newer than the latest common Snapshot copy. This property is applicable only for relationships with FlexVol volume or FlexGroup volume endpoints and when the PATCH state is being changed to "snapmirrored".
quick_resync
boolean
Set to true to reduce resync time by not preserving storage efficiency. This property is applicable only for relationships with FlexVol volume endpoints and SVMDR relationships when the PATCH state is being changed to "snapmirrored".
recover_after_break
boolean
Set to true to recover from a failed SnapMirror break operation on a FlexGroup volume relationship. This restores all destination FlexGroup constituent volumes to the latest Snapshot copy, and any writes to the read-write constituents are lost. This property is applicable only for SnapMirror relationships with FlexGroup volume endpoints and when the PATCH state is being changed to "broken_off".
restore
boolean
Set to true to create a relationship for restore. To trigger restore-transfer, use transfers POST on the restore relationship. SnapMirror relationships with the policy type "async" can be restored. SnapMirror relationships with the policy type "sync" cannot be restored.
restore_to_snapshot
string
Specifies the Snapshot copy to restore to on the destination during the break operation. This property is applicable only for SnapMirror relationships with FlexVol volume endpoints and when the PATCH state is being changed to "broken_off".
source
snapmirror_endpoint
state
string
State of the relationship. To initialize the relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". To break the relationship, PATCH the state to "broken_off" for relationships with a policy of type "async" or "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" cannot be "broken_off". To resync the relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" can be in "broken_off" state due to a failed attempt of SnapMirror failover. To pause the relationship, suspending further transfers, PATCH the state to "paused" for relationships with a policy of type "async" or "sync". SnapMirror relationships with the policy type as "sync" and "sync_type" as "automated_failover" cannot be "paused". To resume transfers for a paused relationship, PATCH the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync". The entries "in_sync", "out_of_sync", and "synchronizing" are only applicable to relationships with a policy of type "sync". A PATCH call on the state change only triggers the transition to the specified state. You must poll on the "state", "healthy" and "unhealthy_reason" properties using a GET request to determine if the transition is successful. To automatically initialize the relationship when specifying "create_destination" property, set the state to "snapmirrored" for relationships with a policy of type "async" or to state "in_sync" for relationships with a policy of type "sync".
throttle
integer
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited.
transfer
transfer
Basic information on the current transfer or the last transfer if there is no active transfer at the time of the request.
transfer_schedule
transfer_schedule
Schedule used to update asynchronous relationships. This "transfer_schedule" overrides the "transfer_schedule" set on the SnapMirror relationship's policy. To remove the "transfer_schedule", set its value to null (no-quotes). Only cron schedules are supported for SnapMirror.
unhealthy_reason
array[snapmirror_error]
Reason the relationship is not healthy. It is a concatenation of up to four levels of error messages.
uuid
string
      "href": "/api/resourcelink"
  "consistency_group_failover": {
    "error": {
      "arguments": [
          "code": "string",
          "message": "string"
      "code": "4",
      "target": "uuid"
    "status": {
      "code": "string",
      "message": "string"
  "destination": {
    "cluster": {
      "name": "cluster1",
    "consistency_group_volumes": [
        "name": "volume1"
    "path": "svm1:volume1",
    "svm": {
      "name": "svm1",
  "exported_snapshot": "string",
  "group_type": "consistency_group",
  "identity_preservation": "string",
  "lag_time": "PT8H35M42S",
  "last_transfer_type": "initialize",
  "policy": {
    "name": "Asynchronous",
    "type": "string",
  "restore_to_snapshot": "string",
  "source": {
    "cluster": {
      "name": "cluster1",
        "name": "volume1"
    "svm": {
      "name": "svm1",
  "state": "snapmirrored",
  "throttle": 0,
  "transfer": {
    "end_time": "2020-12-02T18:36:19-08:00",
    "state": "string",
    "total_duration": "PT28M41S",
  "transfer_schedule": {
    "name": "weekly",
  "unhealthy_reason": [
      "code": "6621444",
      "message": "Failed to complete update operation on one or more item relationships.",
      "parameters": []
      "code": "6621445",
      "message": "Group Update failed",
      "parameters": []
Status: Default
ONTAP Error Response codes
Error code Description
13303825
Could not retrieve information for the SnapMirror policy type
13303817
Unknown value for the Snapmirror State
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
status
code
string
Status code
message
string
SnapMirror Consistency Group failover status.
error
error
status
status
storage_service
enabled
boolean
This property indicates whether to create the destination endpoint using storage service.
enforce_performance
boolean
Optional property to enforce storage service performance on the destination endpoint. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints.
name
string
Optional property to specify the storage service name for the destination endpoint. This property is considered when the property "create_destination.storage_service.enabled" is set to "true". When the property "create_destination.storage_service.enabled" is set to "true" and the "create_destination.storage_service.name" for the endpoint is not specified, then ONTAP selects the highest storage service available on the cluster to provision the destination endpoint. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints.
  • enum: ["extreme", "performance", "value"]
tiering
policy
string
Optional property to specify the destination endpoint's tiering policy when "create_destination.tiering.supported" is set to "true". This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. This property determines whether the user data blocks of the destination endpoint in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of the destination endpoint volume blocks increases if they are accessed frequently and decreases when they are not. all ‐ This policy allows tiering of both destination endpoint Snapshot copies and the user transfered data blocks to the cloud store as soon as possible by ignoring the temperature on the volume blocks. This tiering policy is not applicable for Consistency Group destination endpoints or for synchronous relationships. auto ‐ This policy allows tiering of both destination endpoint Snapshot copies and the active file system user data to the cloud store none ‐ Destination endpoint volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the destination endpoint volume Snapshot copies not associated with the active file system. The default tiering policy is "snapshot_only" for a FlexVol volume and "none" for a FlexGroup volume.
supported
boolean
Optional property to enable provisioning of the destination endpoint volumes on FabricPool aggregates. This property is applicable to FlexVol volume, FlexGroup volume, and Consistency Group endpoints. Only FabricPool aggregates are used if this property is set to "true" and only non FabricPool aggregates are used if this property is set to "false". Tiering support for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. Note that in order to tier data, not only do the destination endpoint volumes need to support tiering by using FabricPools, the "create_destination.tiering.policy" must not be "none". A destination endpoint that uses FabricPools but has a tiering "policy" of "none" supports tiering but will not tier any data.
snapmirror_destination_creation
Use this object to provision the destination endpoint when establishing a SnapMirror relationship for a FlexVol volume, FlexGroup volume, SVM, Consistency Group or ONTAP S3 Bucket. Given a source endpoint, the destination endpoint is provisioned in the SVM specified in the "destination.path" property. While protecting an SVM, the SVM destination endpoint can only be provisioned on the local cluster. To provision the SVM destination endpoint use the optional "source.cluster.name" property to specify the remote cluster name or use the optional "source.cluster.uuid" property to specify the remote cluster UUID. When "create_destination.enabled" option is specified while making a POST for a SnapMirror relationship, the relationship can be automatically initialized by setting the "state" either to "snapmirrored" when the policy is of type "async" or to "in_sync" when the policy is of type "sync". The "destination.path" property must specify the destination endpoint path. For example, for FlexVol volume and FlexGroup volume, the "destination.path" can be specified as , for SVM data protection, the "destination.path" must be specified as <destination-svm-name:>, and for Consistency Group, the "destination.path" must be specified as <destination-svm-name:> along with the "destination.consistency_group_volumes" property to indicate the list of destination volumes of type "DP" in the Consistency Group. For a FlexVol volume, a FlexGroup volume, Consistency Group or a Bucket destination endpoint, the properties in this object can be specified either from the source or the destination cluster. For an SVM destination endpoint, the properties in this object can be specified from the destination cluster only. This object is not supported for non ONTAP endpoints. While protecting a S3 Bucket, the optional "size" property can be used to create ONTAP S3 Bucket destination endpoint of the specified size.</destination-svm-name:></destination-svm-name:>
enabled
boolean
Optional property to create the destination endpoint when establishing a SnapMirror relationship. It is assumed to be "false" if no other property is set and assumed to be "true" if any other property is set.
size
integer
Optional property to specify the size of destination endpoint in bytes. This property is applicable only to ONTAP S3 Bucket endpoints. The minimum size for S3 bucket is 80MB and maximum size is 64TB. If not specified, system will create destination with default size of 800GB.
  • Introduced in: 9.10
storage_service
storage_service
tiering
tiering
cluster
_links
_links
name
string
uuid
string
name
string
The name of the volume.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
snapmirror_endpoint
cluster
cluster
array[consistency_group_volumes]
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group.
path
string
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
  • example: svm1:volume1
svm
svm
policy
_links
_links
name
string
type
string
uuid
string
transfer
_links
_links
bytes_transferred
integer
Bytes transferred.
end_time
string
End time of the last transfer.
state
string
total_duration
string
Transfer elapsed time.
uuid
string
Transfer UUID. This property is applicable only for active transfers.
transfer_schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_error
SnapMirror error
code
integer
Error code
message
string
Error message
parameters
array[string]
Parameters for the error message
