REST API reference
Retrieve a SnapLock ComplianceClock for a node
Obtains the SnapLock ComplianceClock for a node, which is essential for managing data retention policies on that node. Use this information to ensure compliance with your organization's data governance requirements.
HTTP method and endpoint
GET /storage/snaplock/compliance-clocks/{node.uuid}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the SnapLock ComplianceClock for a specific node.
  • snaplock compliance-clock show
node.uuid
string
path
True
Node UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
node
node
time
string
Compliance clock time
      "href": "/api/resourcelink"
  "node": {
    "name": "node1",
  "time": "2018-06-04T19:00:00Z"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
