Retrieve directories with the greatest value performance metric or capacity metric
Retrieves a list of directories that have the highest performance or capacity metrics, helping you identify which directories may require attention based on their current usage statistics.
HTTP method and endpoint
GET /storage/volumes/{volume.uuid}/top-metrics/directories
Introduced in
ONTAP 9.10
Usage notes
Retrieves a list of directories with the greatest value performance metric or capacity metric.
volume.uuid |
string |
path |
True |
Volume UUID |
top_metric |
string |
query |
False |
Type of performance metric or capacity metric.
max_records_per_volume |
integer |
query |
False |
Max records per volume. |
path |
string |
query |
False |
Filter by path |
volume.name |
string |
query |
False |
Filter by volume.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
non_recursive_bytes_used |
integer |
query |
False |
Filter by non_recursive_bytes_used
iops.error.lower_bound |
integer |
query |
False |
Filter by iops.error.lower_bound |
iops.error.upper_bound |
integer |
query |
False |
Filter by iops.error.upper_bound |
iops.write |
integer |
query |
False |
Filter by iops.write |
iops.read |
integer |
query |
False |
Filter by iops.read |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
throughput.error.lower_bound |
integer |
query |
False |
Filter by throughput.error.lower_bound |
throughput.error.upper_bound |
integer |
query |
False |
Filter by throughput.error.upper_bound |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
incomplete_response_reason |
Indicates that the metric report provides incomplete data. |
notice |
Optional field that indicates why no records are returned by the volume activity tracking REST API. |
num_records |
integer |
Number of records. |
records |
array[top_metrics_directory] |
"next": {
"href": "/api/resourcelink"
"incomplete_response_reason": {
"code": "111411207",
"message": "Partial data has been returned for this metric report. Reason: Data collection for the large directory report is in progress."
"notice": {
"message": "No read/write traffic on volume."
"num_records": 1,
"records": [
"metadata": {
"iops": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 10,
"write": 5
"non_recursive_bytes_used": 300,
"path": "/dir_abc/dir_123/dir_20",
"svm": {
"name": "svm1",
"throughput": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 3,
"write": 20
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
124518415 |
Failed to get the volume activity tracking report on volume volume.name in Vserver svm.name. Reason: |
124518416 |
Internal error. Volume activity tracking report timed out for volume volume.name in SVM svm.name. |
124518417 |
Volume wildcard queries are not supported for activity tracking reports. |
124518418 |
The activity tracking report for volume volume.name in Vserver svm.name returned zero records. Check whether the volume has read/write traffic. Refer to the REST API documentation for more information on why there might be no records. |
124519410 |
The large directory report for volume volume.name in Vserver svm.name is not available because the file system analytics database version doesn't support this report. Use the "volume analytics off" command to disable analytics on the volume, then use the "volume analytics on" command to re-enable analytics. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Warning code indicating why partial data was reported. |
message |
string |
A message describing the reason for partial data. |
notice
code |
string |
Warning code indicating why no records are returned. |
message |
string |
Details why no records are returned. |
_links
metadata |
self |
top_metric_value_error_bounds
lower_bound |
integer |
Lower bound of the nominal value of a metric. |
upper_bound |
integer |
Upper bound of the nominal value of a metric. |
iops
error |
read |
integer |
Average number of read operations per second. |
write |
integer |
Average number of write operations per second. |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
throughput
error |
read |
integer |
Average number of read bytes received per second. |
write |
integer |
Average number of write bytes received per second. |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
Information about a directory's IO metrics.
_links |
iops |
integer |
Non-recursive bytes used by the contents of a directory. |
path |
string |
Path of the directory. |
svm |
throughput |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
