REST API reference
Manage automatic updates
Retrieve and update the status of automatic package updates using this API. Utilize GET calls to check the update status and PATCH calls to perform actions like scheduling or dismissing updates.
Overview
Use this API to retrieve the status for a specific automatic package update.
This API supports GET and PATCH calls. PATCH can be used to perform an action on an automatic update.
Retrieving the status of an update
The following example shows how to retrieve the status of an automatic update:
# The API:
GET /support/auto-update/updates/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d
# The call:
curl -X GET "https://<mgmt-ip>/api/support/auto-update/updates/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d"
# The response:
"uuid" : "440ae2e4-fd8f-4225-9bee-94e2da3f8d9d",
"package_id" : "572361f3-e769-439d-9c04-2ba48a08ff47",
"content_type" : "disk_fw",
"content_category" : "Firmware",
"description" : "disk_fw version 3.0",
"state" : "downloading",
"creation_time" : "2020-12-01T09:12:03Z",
"expiry_time" : "2021-06-01T09:12:03Z",
"last_state_change_time" : "2020-12-01T09:12:23Z",
"start_time" : "2020-12-01T09:12:23Z",
"percent_complete": 25,
"remaining_time": "PT1M30S",
"status": {
    "message": "Get-url request to AutoSupport OnDemand Server failed. Error: Couldn't connect to server.",
    "code": "8650878"
    "href": "/support/auto-update/updates/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d"
Updating the state of an automatic update
The following example shows how to trigger an automatic update that is waiting for user confirmation:
# The API:
PATCH /support/auto-update/updates/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/auto-update/updates/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d?action=schedule_now" -H "accept: application/hal+json"
# The response:
200 OK
The following example shows how to dismiss an automatic update that is waiting for user confirmation:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/auto-update/updates/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d?action=dismiss" -H "accept: application/hal+json"
# Response
200 OK
