REST API reference
Manage shelves
Retrieve storage shelf information using endpoints that list all shelves in the cluster and provide detailed data for individual shelves. Access these endpoints to monitor and review shelf attributes and their operational state.
Retrieving storage shelf information
The storage shelf GET API retrieves all of the shelves in the cluster.
1) Retrieve a list of shelves from the cluster
The following example shows the response with a list of shelves in the cluster:
# The API:
/api/storage/shelves
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/shelves" -H "accept: application/hal+json"
# The response:
"records": [
    "uid": "3109174803597886800",
        "href": "/api/storage/shelves/3109174803597886800"
    "uid": "9237728366621690448",
        "href": "/api/storage/shelves/9237728366621690448"
    "uid": "9946762738829886800",
        "href": "/api/storage/shelves/9946762738829886800"
    "uid": "10318311901725526608",
        "href": "/api/storage/shelves/10318311901725526608"
    "uid": "13477584846688355664",
        "href": "/api/storage/shelves/13477584846688355664"
"num_records": 5,
    "href": "/api/storage/shelves/"
2) Retrieve a specific shelf from the cluster
The following example shows the response of the requested shelf. If there is no shelf with the requested uid, an error is returned.
# The API:
/api/storage/shelves/{uid}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/shelves/3109174803597886800" -H "accept: application/hal+json"
# The response:
"name": "6.10",
"id": "10",
"serial_number": "SHU0954292N0HAH",
"model": "DS4246",
"module_type": "iom6",
"internal": false,
"local": true,
"manufacturer": {
  "name": "NETAPP"
"state": "ok",
"connection_type": "sas",
"disk_count": 24,
"location_led": "off",
"paths": [
    "name": "0e",
    "node": {
      "uuid": "0530d6c1-8c6d-11e8-907f-00a0985a72ee",
      "name": "node-1",
          "href": "/api/cluster/nodes/0530d6c1-8c6d-11e8-907f-00a0985a72ee"
        "href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0e"
    "name": "0g",
    "node": {
      "name": "node-1",
        "href": "/api/storage/ports/0530d6c1-8c6d-11e8-907f-00a0985a72ee/0g"
"bays": [
    "id": 0,
    "has_disk": true,
    "type": "single_disk",
    "state": "ok"
    "id": 1,
    "has_disk": true,
    "state": "ok"
    "id": 2,
    "has_disk": true,
    "state": "ok"
    "id": 3,
    "has_disk": true,
    "state": "ok"
    "id": 4,
    "has_disk": true,
    "state": "ok"
    "id": 5,
    "has_disk": true,
    "state": "ok"
    "id": 6,
    "has_disk": true,
    "state": "ok"
    "id": 7,
    "has_disk": true,
    "state": "ok"
    "id": 8,
    "has_disk": true,
    "state": "ok"
    "id": 9,
    "has_disk": true,
    "state": "ok"
    "id": 10,
    "has_disk": true,
    "state": "ok"
    "id": 11,
    "has_disk": true,
    "state": "ok"
    "id": 12,
    "has_disk": true,
    "state": "ok"
    "id": 13,
    "has_disk": true,
    "state": "ok"
    "id": 14,
    "has_disk": true,
    "state": "ok"
    "id": 15,
    "has_disk": true,
    "state": "ok"
    "id": 16,
    "has_disk": true,
    "state": "ok"
    "id": 17,
    "has_disk": true,
    "state": "ok"
    "id": 18,
    "has_disk": true,
    "state": "ok"
    "id": 19,
    "has_disk": true,
    "state": "ok"
    "id": 20,
    "has_disk": true,
    "state": "ok"
    "id": 21,
    "has_disk": true,
    "state": "ok"
    "id": 22,
    "has_disk": true,
    "state": "ok"
    "id": 23,
    "has_disk": true,
    "state": "ok"
"frus": [
    "type": "module",
    "id": 0,
    "state": "ok",
    "part_number": "111-00690+B2",
    "serial_number": "8001900099",
    "firmware_version": "0191",
    "installed": true
    "type": "module",
    "id": 1,
    "state": "ok",
    "part_number": "111-00190+B0",
    "serial_number": "7903785183",
    "installed": true
    "type": "psu",
    "id": 1,
    "state": "ok",
    "part_number": "0082562-12",
    "serial_number": "PMW82562007513E",
    "firmware_version": "0311",
    "installed": true,
    "psu": {
      "model": "9C"
    "type": "psu",
    "id": 2,
    "state": "ok",
    "serial_number": "PMW825620075138",
    "installed": true,
    "psu": {
      "model": "9C"
    "type": "psu",
    "id": 3,
    "state": "ok",
    "serial_number": "PMW8256200750BA",
    "installed": true,
    "psu": {
      "model": "9C"
    "type": "psu",
    "id": 4,
    "state": "ok",
    "serial_number": "PMW8256200750A2",
    "installed": true,
    "psu": {
      "model": "9C"
"ports": [
    "id": 0,
    "module_id": "a",
    "designator": "square",
    "state": "connected",
    "internal": false,
    "wwn": "500A098000C9EDBF",
    "cable": {
      "identifier": "5001086000702488-500a098000c9edbf",
      "part_number": "112-00430+A0",
      "length": "2m",
      "serial_number": "APF16510229807"
    "remote": {
      "wwn": "5001086000702488",
      "phy": "08"
    "id": 1,
    "module_id": "a",
    "designator": "circle",
    "internal": false,
    "cable": {
      "identifier": "500a098000d5c4bf-500a098000c9edbf",
      "part_number": "112-00176+A0",
      "length": "0.5-1.0m",
      "serial_number": "APF133917610YT"
    "remote": {
      "wwn": "500A098000D5C4BF",
      "phy": "00"
    "id": 2,
    "module_id": "b",
    "internal": false,
    "wwn": "500A098004F208BF",
    "cable": {
      "identifier": "5001086000702648-500a098004f208bf",
      "length": "2m",
      "serial_number": "APF16510229540"
    "remote": {
      "wwn": "5001086000702648",
      "phy": "08"
    "id": 3,
    "module_id": "b",
    "internal": false,
    "cable": {
      "identifier": "500a0980062ba33f-500a098004f208bf",
      "part_number": "112-00176+20",
      "serial_number": "832210017"
    "remote": {
      "wwn": "500A0980062BA33F",
      "phy": "00"
"fans": [
    "id": 1,
    "location": "rear of the shelf on the upper left power supply",
    "rpm": 3150,
    "state": "ok"
    "id": 2,
    "rpm": 3000,
    "state": "ok"
    "id": 3,
    "location": "rear of the shelf on the upper right power supply",
    "rpm": 3220,
    "state": "ok"
    "id": 4,
    "rpm": 3000,
    "state": "ok"
    "id": 5,
    "location": "rear of the shelf on the lower left power supply",
    "rpm": 3000,
    "state": "ok"
    "id": 6,
    "rpm": 3150,
    "state": "ok"
    "id": 7,
    "location": "rear of the shelf on the lower right power supply",
    "rpm": 3150,
    "state": "ok"
    "id": 8,
    "rpm": 3000,
    "state": "ok"
"temperature_sensors": [
    "id": 1,
    "location": "front of the shelf on the left, on the OPS panel",
    "temperature": 20,
    "ambient": true,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 42,
        "warning": 40
      "low": {
        "critical": 0,
        "warning": 5
    "id": 2,
    "location": "inside of the shelf on the midplane",
    "temperature": 29,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 3,
    "temperature": 33,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 4,
    "temperature": 41,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 70,
        "warning": 65
      "low": {
        "critical": 5,
        "warning": 10
    "id": 5,
    "temperature": 32,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 6,
    "temperature": 41,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 70,
        "warning": 65
      "low": {
        "critical": 5,
        "warning": 10
    "id": 7,
    "temperature": 34,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 8,
    "temperature": 45,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 70,
        "warning": 65
      "low": {
        "critical": 5,
        "warning": 10
    "id": 9,
    "temperature": 30,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 55,
        "warning": 50
      "low": {
        "critical": 5,
        "warning": 10
    "id": 10,
    "temperature": 40,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 70,
        "warning": 65
      "low": {
        "critical": 5,
        "warning": 10
    "id": 11,
    "location": "rear of the shelf at the top left, on shelf module A",
    "temperature": 30,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 60,
        "warning": 55
      "low": {
        "critical": 5,
        "warning": 10
    "id": 12,
    "location": "rear of the shelf at the top right, on shelf module B",
    "temperature": 33,
    "ambient": false,
    "state": "ok",
    "threshold": {
      "high": {
        "critical": 60,
        "warning": 55
      "low": {
        "critical": 5,
        "warning": 10
"voltage_sensors": [
    "id": 1,
    "voltage": 5.11,
    "state": "ok"
    "id": 2,
    "voltage": 12.38,
    "state": "ok"
    "id": 3,
    "voltage": 5.11,
    "state": "ok"
    "id": 4,
    "voltage": 12.26,
    "state": "ok"
    "id": 5,
    "voltage": 5.7,
    "state": "ok"
    "id": 6,
    "voltage": 12.26,
    "state": "ok"
    "id": 7,
    "voltage": 5.15,
    "state": "ok"
    "id": 8,
    "voltage": 12.3,
    "state": "ok"
"current_sensors": [
    "id": 1,
    "current": 6990,
    "state": "ok"
    "id": 2,
    "current": 5150,
    "state": "ok"
    "id": 3,
    "current": 4600,
    "state": "ok"
    "id": 4,
    "current": 4800,
    "state": "ok"
    "id": 5,
    "current": 4140,
    "state": "ok"
    "id": 6,
    "current": 7770,
    "state": "ok"
    "id": 7,
    "current": 4140,
    "state": "ok"
    "id": 8,
    "current": 4720,
    "state": "ok"
"acps": [
    "enabled": true,
    "channel": "in_band",
    "connection_state": "active",
    "node": {
      "uuid": "cf62d23c-6100-11eb-9852-00a098fd725d",
      "name": "cat33-01",
          "href": "/api/cluster/nodes/cf62d23c-6100-11eb-9852-00a098fd725d"
    "enabled": true,
    "node": {
      "uuid": "d0892dd7-6100-11eb-9cdb-d039ea010238",
      "name": "cat33-02",
          "href": "/api/cluster/nodes/d0892dd7-6100-11eb-9cdb-d039ea010238"
Modifying storage shelf
The storage shelf PATCH API modifies the shelf location LED.
Example
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/shelves/3109174803597886800" -H "accept: application/hal+json" -H "Content-Type: application/hal+json" -d '{"location_led": "on"}'
# The response:
