Manage storage FlexCache origin volumes
Overview
FlexCache is a persistent cache of an origin volume. An origin volume can only be a FlexVol while a FlexCache is always a FlexGroup.
The following relationship configurations are supported:
– Intra-Vserver where FlexCache and the corresponding origin volume reside in the same Vserver.
– Cross-Vserver but intra-cluster where FlexCache and the origin volume reside in the same cluster but belong to different Vservers.
– Cross-cluster where FlexCache and the origin volume reside in different clusters.
FlexCache supports fan-out and more than one FlexCache can be created from one origin volume. This API retrieves the origin of FlexCache onfigurations in the origin cluster.
FlexCache APIs
The following APIs can be used to perform operations related to the origin of a FlexCache:
– GET /api/storage/flexcache/origins
– GET /api/storage/flexcache/origins/{uuid}
– PATCH /api/storage/flexcache/origins/{uuid}
Retrieving origins of FlexCache attributes
The GET request is used to retrieve the origins of FlexCache attributes.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/flexcache/origins?" -H "accept: application/json"
# The response:
"records": [
"uuid": "2bc957dd-2617-4afb-8d2f-66ac6070d313",
"name": "vol_o1",
"href": "/api/storage/flexcache/origins/2bc957dd-2617-4afb-8d2f-66ac6070d313"
"uuid": "80fcaee4-0dc2-488b-afb8-86d28a34cda8",
"name": "vol_1",
"href": "/api/storage/flexcache/origins/80fcaee4-0dc2-488b-afb8-86d28a34cda8"
"num_records": 2,
"href": "/api/storage/flexcache/origins?"
Retrieving the attributes of an origin volume
The GET request is used to retrieve the attributes of an origin volume.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/flexcache/origins/80fcaee4-0dc2-488b-afb8-86d28a34cda8" -H "accept: application/json"
# The response:
"name": "vol_1",
"svm": {
"name": "vs_3",
"uuid": "8aa2cd28-0e92-11e9-b391-0050568e4115"
"block_level_invalidation": "false",
"global_file_locking_enabled": "true",
"flexcaches": [
"ip_address": "10.140.103.183",
"create_time": "2019-01-02T19:27:22+05:30",
"volume": {
"name": "fc_42",
"uuid": "4e7f9d49-0e96-11e9-aed0-0050568eddbe"
"svm": {
"name": "vs_1_4",
"uuid": "36f68322-0e93-11e9-aed0-0050568eddbe"
"cluster": {
"name": "node4",
"uuid": "c32f16b8-0e90-11e9-aed0-0050568eddbe"
"create_time": "2019-01-02T21:08:34+05:30",
"volume": {
"name": "fc_421",
"uuid": "71ee8f36-0ea4-11e9-aed0-0050568eddbe"
"svm": {
"name": "vs_1_4",
"cluster": {
"name": "node4",
"create_time": "2019-01-03T11:14:38+05:30",
"volume": {
"name": "fc_422"
"svm": {
"name": "vs_1_4",
"cluster": {
"name": "node4",
"ip_address": "10.140.103.179",
"size": 4294967296,
"create_time": "2019-01-02T19:24:14+05:30",
"state": "online",
"volume": {
"name": "fc_32",
"uuid": "ddb42bbc-0e95-11e9-8180-0050568e0b79"
"svm": {
"name": "vs_1",
"uuid": "e708fbe2-0e92-11e9-8180-0050568e0b79"
"cluster": {
"name": "node3",
"uuid": "8eb21b3b-0e90-11e9-8180-0050568e0b79"
"size": 4294967296,
"create_time": "2019-01-02T21:07:23+05:30",
"state": "online",
"volume": {
"name": "fc_321",
"uuid": "47902654-0ea4-11e9-8180-0050568e0b79"
"svm": {
"name": "vs_1",
"cluster": {
"name": "node3",
"size": 4294967296,
"create_time": "2019-01-03T00:11:38+05:30",
"state": "online",
"volume": {
"name": "fc_322",
"uuid": "04d5e07b-0ebe-11e9-8180-0050568e0b79"
"svm": {
"name": "vs_1",
"cluster": {
"name": "node3",
"size": 4294967296,
"create_time": "2019-01-03T00:14:52+05:30",
"state": "online",
"volume": {
"name": "fc_323",
"uuid": "77e911ff-0ebe-11e9-8180-0050568e0b79"
"svm": {
"name": "vs_1",
"cluster": {
"name": "node3",
Modifying origin options of an origin volume
Use the PATCH request to update options of an origin volume.
# the API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/flexcache/origins/1fbc0ebb-2440-11eb-a86c-005056ac8ca0" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"block_level_invalidation\": \"true\" } "
# The response:
"job": {
"uuid": "e751dd5d-0f3c-11e9-8b2b-0050568e0b79",
"href": "/api/cluster/jobs/e751dd5d-0f3c-11e9-8b2b-0050568e0b79"
