REST API reference
Manage storage qtrees
Manage storage qtrees by creating, retrieving, updating, and deleting them within your ONTAP environment. Use these endpoints to define qtree properties, enforce QoS policies, and maintain file system hierarchy in volumes.
Overview
A qtree is a logically defined file system that can exist as a special subdirectory of the root directory within a FlexVol volume or a FlexGroup volume.
Qtree QoS policy
Qtree QoS policy and settings enforce Service Level Objectives (SLOs) on a qtree. SLOs can be set by specifying "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a qtree is not supported if its containing volume or SVM has a QoS policy attached, or a file or LUN in its containing volume already has a QoS policy attached.
Qtree APIs
The following APIs are used to create, retrieve, modify, and delete qtrees.
– POST /api/storage/qtrees
– GET /api/storage/qtrees
– GET /api/storage/qtrees/{volume-uuid}/{qtree-id}
– PATCH /api/storage/qtrees/{volume-uuid}/{qtree-id}
– DELETE /api/storage/qtrees/{volume-uuid}/{qtree-id}
Creating a qtree inside a volume for an SVM
This API is used to create a qtree inside a volume for an SVM.
The following example shows how to create a qtree in a FlexVol volume with a given security style, user, group, UNIX permissions, an export policy, and a QoS policy.
# The API:
# The call:
curl -X POST 'https://<mgmt-ip>/api/storage/qtrees?return_records=true' -H 'accept: application/hal+json' -d @test_qtree_post.txt
test_qtree_post.txt(body):
"svm": {
  "name": "svm1"
"volume": {
  "name": "fv"
"name": "qt1",
"security_style": "unix",
"user": {
  "name": "unix_user1"
"group": {
  "name": "unix_group1"
"unix_permissions": 744,
"export_policy": {
    "name": "default"
"qos_policy": {
    "max_throughput_iops": 1000
# The response:
  "num_records": 1,
  "records": [
      "svm": {
        "name": "svm1"
      "volume": {
        "name": "fv"
      "name": "qt1",
      "user": {
      "group": {
      "export_policy": {
        "name": "default"
      "qos_policy": {
        "min_throughput_iops": 0,
        "min_throughput_mbps": 0,
        "max_throughput_iops": 1000,
        "max_throughput_mbps": 0,
        "uuid": "39ac471f-ff35-11e9-b0f9-005056a7ab52",
        "name": "vs0_auto_gen_policy_39a9522f_ff35_11e9_b0f9_005056a7ab52"
          "href": "/api/storage/qtrees/?volume.name=fv&name=qt1"
  "job": {
    "uuid": "84edef3c-4f6d-11e9-9a71-005056a7f717",
        "href": "/api/cluster/jobs/84edef3c-4f6d-11e9-9a71-005056a7f717"
Retrieving qtrees
This API is used to retrieve qtrees.
The following example shows how to retrieve qtrees belonging to SVM svm1 and volume fv. The svm.name and volume.name query parameters are used to find the required qtrees.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/qtrees/?svm.name=svm1&volume.name=fv" -H 'accept: application/hal+json'
# The response
  "records": [
      "svm": {
        "uuid": "b68f961b-4cee-11e9-930a-005056a7f717",
        "name": "svm1",
            "href": "/api/svm/svms/b68f961b-4cee-11e9-930a-005056a7f717"
      "volume": {
        "uuid": "cb20da45-4f6b-11e9-9a71-005056a7f717",
        "name": "fv",
            "href": "/api/storage/volumes/cb20da45-4f6b-11e9-9a71-005056a7f717"
      "id": 0,
      "name": "",
          "href": "/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/0"
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "fv",
      "id": 1,
      "name": "qt1",
          "href": "/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/1"
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "fv",
      "id": 2,
      "name": "qt2",
          "href": "/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/2"
  "num_records": 3,
      "href": "/api/storage/qtrees/?svm.name=svm1&volume.name=fv"
Retrieving properties of a specific qtree using a qtree identifier
This API is used to retrieve properties of a specific qtree using qtree.id.
The following example shows how to use the qtree identifier to retrieve all properties of the qtree using the fields query parameter.
# The API:
GET /api/storage/qtrees/{volume.uuid}/{id}
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/2?fields=*' -H 'accept: application/hal+json'
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "fv",
  "id": 2,
  "name": "qt2",
  "user": {
  "group": {
  "export_policy": {
    "name": "default",
    "id": 12884901889,
        "href": "/api/protocols/nfs/export-policies/12884901889"
  "qos_policy": {
    "name": "vs0_auto_gen_policy_39a9522f_ff35_11e9_b0f9_005056a7ab52",
        "href": "/api/storage/qos/policies/39ac471f-ff35-11e9-b0f9-005056a7ab52"
  "statistics": {
    "timestamp": "2019-04-09T05:50:42Z",
    "status": "ok",
    "iops_raw": {
      "read": 0,
      "write": 0,
      "other": 3,
      "total": 3
    "throughput_raw": {
      "read": 0,
      "write": 0,
      "other": 0,
      "total": 0
  "path": "/fv/qt2",
  "nas": {
    "path": "/fv/qt2",
Retrieving properties of a specific qtree using the qtree name
This API is used to retrieve properties of a specific qtree using "qtree.name". The following example shows how to retrieve all of the properties belonging to qtree "qt2". The svm.name and volume.name query parameters are used here along with the qtree name.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/qtrees/?svm.name=svm1&volume.name=fv&name=qt2&fields=*' -H 'accept: application/hal+json'
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "fv",
  "id": 2,
  "name": "qt2",
  "user": {
  "group": {
  "export_policy": {
    "name": "default",
    "id": 12884901889,
  "qos_policy": {
  "statistics": {
    "status": "ok",
    "iops_raw": {
      "read": 0,
      "write": 0,
      "other": 3,
      "total": 3
    "throughput_raw": {
      "read": 0,
      "write": 0,
      "other": 0,
      "total": 0
Updating a qtree
This API is used to update a qtree.
The following example shows how to update properties in a qtree.
# The API:
PATCH /api/storage/qtrees/{volume.uuid}/{id}
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/2' -H 'accept: application/hal+json' -d '@test_qtree_patch.txt'
test_qtree_patch.txt(body):
"security_style": "mixed",
"user": {
"group": {
"unix_permissions": 777,
"export_policy": {
    "id": "9",
    "name": "exp1"
"qos_policy": {
    "uuid": "39ac471f-ff35-11e9-b0f9-005056a7ab53"
Renaming a qtree
This API is used to rename a qtree.
The following example below shows how to rename a qtree with a new name.
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/1' -H 'accept: application/hal+json' -d '{ "name": "new_qt1" }'
Deleting a qtree inside a volume of an SVM
This API is used to delete a qtree inside a volume of an SVM.
The following example shows how to delete a qtree.
# The API:
DELETE /api/storage/qtrees/{volume.uuid}/{id}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/2" -H 'accept: application/hal+json'
