REST API reference
Update a netgroup cache setting
Updates a netgroup cache setting to change how cache information is handled for netgroups. This operation is useful for managing network communication settings efficiently.
HTTP method and endpoint
PATCH /name-services/cache/netgroup/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Important notes
  • svm.uuid field cannot be empty.
  • Returns success in case no values are provided for update.
  • vserver services name-service cache netgroups settings modify
svm.uuid
string
path
True
SVM UUID.
Request Body
Name Type Description
enabled
boolean
Indicates whether or not the cache is enabled.
negative_cache_enabled_byhost
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl_byhost
string
Specifies negative Time to Live by host, in ISO 8601 format.
svm
svm
ttl_byhost
string
Specifies Time to Live by host, in ISO 8601 format.
ttl_for_members
string
Specifies Time to Live for netgroup members, in ISO 8601 format.
Example request
  "negative_ttl_byhost": "PT2M5S",
  "svm": {
    "name": "svm1",
  "ttl_byhost": "PT24H",
  "ttl_for_members": "PT2M"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
23724055
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support.
string
svm
name
string
The name of the SVM.
uuid
string
netgroups_settings
Netgroups cache setting.
enabled
boolean
boolean
negative_ttl_byhost
string
svm
svm
ttl_byhost
string
ttl_for_members
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
