REST API reference
Update the Vscan On-Access policy configuration for an SVM
Updates the Vscan On-Access policy configuration for an SVM, adjusting policy settings or toggling the policy's active status. This is useful for managing access and security protocols within your storage virtual machine.
HTTP method and endpoint
PATCH /protocols/vscan/{svm.uuid}/on-access-policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Updates the Vscan On-Access policy configuration and/or enables/disables the Vscan On-Access policy of an SVM. You cannot modify the configurations for an On-Access policy associated with an administrative SVM, although you can encable and disable the policy associated with an administrative SVM.
  • vserver vscan on-access-policy modify
  • vserver vscan on-access-policy enable
  • vserver vscan on-access-policy disable
  • vserver vscan on-access-policy file-ext-to-include add
  • vserver vscan on-access-policy file-ext-to-exclude add
  • vserver vscan on-access-policy paths-to-exclude add
  • vserver vscan on-access-policy file-ext-to-include remove
  • vserver vscan on-access-policy file-ext-to-exclude remove
  • vserver vscan on-access-policy paths-to-exclude remove
name
string
path
True
svm.uuid
string
path
True
Request Body
Name Type Description
enabled
boolean
Status of the On-Access Vscan policy
mandatory
boolean
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning.
scope
scope
Example request
  "scope": {
    "exclude_extensions": [
      "mp*",
      "txt"
    "exclude_paths": [
      "\\dir1\\dir2\\name",
      "\\vol\\a b",
      "\\vol\\a,b\\"
    "include_extensions": [
      "mp*",
      "txt"
    "max_file_size": 2147483648
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10027033
Configurations for an On-Access policy associated with an administrative SVM cannot be modified. However, the policy can be enabled or disabled.
10027046
The specified SVM is not the owner of the specified policy. Check for the correct SVM who owns the policy.
10027101
The file size must be in the range 1KB to 1TB
10027107
The include extensions list cannot be empty. Specify at least one extension for inclusion.
10027109
The specified CIFS path is invalid. It must be in the form "\dir1\dir2" or "\dir1\dir2\".
10027249
The On-Access policy updated successfully but failed to enable/disable the policy. The reason for an enable policy operation failure might be that another policy is enabled. Disable the already enabled policy and then enable the policy. The reason for a disable policy operation failure might be that Vscan is enabled on the SVM. Disable the Vscan first and then disable the policy.
10027250
The On-Access policy cannot be enabled/disabled. The reason for an enable policy operation failure might be that another policy is enabled. Disable the already enabled policy and then enable the policy. The reason for a disable policy operation failure might be that Vscan is enabled on the SVM. Disable the Vscan and then disable the policy.
10027253
The number of paths specified exceeds the configured maximum number of paths. You cannot specify more than the maximum number of configured paths.
10027254
The number of extensions specified exceeds the configured maximum number of extensions. You cannot specify more than the maximum number of configured extensions.
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
only_execute_access
boolean
Scan only files opened with execute-access.
scan_readonly_volumes
boolean
Specifies whether or not read-only volume can be scanned.
scan_without_extension
boolean
Specifies whether or not files without any extension can be scanned.
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled
boolean
mandatory
boolean
scope
scope
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
