REST API reference
Create an HTTP proxy configuration for an SVM or cluster IPspace
Creates an HTTP proxy configuration for an SVM or a Cluster IPspace to enable routing of HTTP traffic through a specified proxy server. This is useful for managing and controlling network communication within your ONTAP environment.
HTTP method and endpoint
POST /network/http-proxy
Introduced in
ONTAP 9.7
Usage notes
Important notes:
  • IPv6 must be enabled if IPv6 family addresses are specified in the "server" field.
  • The server and the port combination specified using the "server" and "port" fields is validated during this operation. The validation will fail in the following scenarios:
    • The HTTP proxy service is not configured on the server.
    • The HTTP proxy service is not running on the specified port.
    • The server is unreachable.
Required properties
  • SVM-scoped HTTP proxy
    • svm.uuid or svm.name - Existing SVM in which to create the HTTP proxy.
  • Cluster-scoped HTTP proxy
    • ipspace.uuid or ipspace.name - Exisitng Cluster IPspace in which to create the HTTP proxy.
  • server - HTTP proxy server FQDN or IP address.
  • port - HTTP proxy server port.
Optional properties
  • authentication_enabled - Specifies if authentication is required for the HTTP proxy server.
  • username - Username used to authenticate with the HTTP proxy server.
  • password - Password used to authenticate with the HTTP proxy server.
  • vserver http-proxy create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
boolean
Specifies whether or not authentication with the HTTP proxy server is enabled.
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
password
string
Password to authenticate with the HTTP proxy server when authentication_enabled is set to "true".
port
integer
The port number on which the HTTP proxy service is configured on the proxy server.
scope
string
Set to “svm” for HTTP proxy owned by an SVM. Otherwise, set to "cluster".
server
string
Fully qualified domain name (FQDN) or IP address of the HTTP proxy server.
svm
svm
username
string
Username to authenticate with the HTTP proxy server when authentication_enabled is set to "true".
uuid
string
The UUID that uniquely identifies the HTTP proxy.
Example request
  "ipspace": {
    "name": "exchange",
  "password": "string",
  "port": 3128,
  "scope": "string",
  "server": "string",
  "svm": {
    "name": "svm1",
  "username": "string",
  "uuid": "string"
Status: 201, Created
num_records
integer
Number of HTTP proxy records
records
array[network_http_proxy]
  "num_records": 1,
  "records": [
      "ipspace": {
        "name": "exchange",
      "port": 3128,
      "scope": "string",
      "server": "string",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
26214473
HTTP proxy configuration is not valid.
26214476
The "IPspace" parameter should not be specified in the SVM context.
26214477
The specified IPspace does not exist.
23724130
Cannot use an IPv6 name server address because there are no IPv6 interfaces.
26214481
Username and password cannot be empty when HTTP proxy authentication is enabled.
26214482
Username and password cannot be specified when HTTP proxy authentication is disabled.
string
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
svm
name
string
The name of the SVM.
uuid
string
network_http_proxy
boolean
ipspace
ipspace
password
string
port
integer
scope
string
server
string
svm
svm
username
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
