Create an S3 audit configuration
Creates an S3 audit configuration to define how audit logs are stored and managed within the storage virtual machine (SVM) namespace. Use this endpoint to set up audit logging to track and review S3 operations for compliance and security purposes.
HTTP method and endpoint
POST /protocols/audit/{svm.uuid}/object-store
Introduced in
ONTAP 9.10
Required properties
log_path- Path in the owning SVM namespace that is used to store audit logs.
Default property values
If not specified in POST, the following default property values are assigned:
enabled- true -
events.data- true -
events.management- false -
log.format- json -
log.retention.count- 0 -
log.retention.duration- PT0S -
log.rotation.size- 100MB -
log.rotation.now- false
Related ONTAP commands
vserver object-store-server audit create -
vserver object-store-server audit enable
Learn more
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
enabled |
boolean |
Specifies whether or not auditing is enabled on the SVM. |
events |
log |
log_path |
string |
The audit log destination path where consolidated audit logs are stored. |
svm |
Example request
"log": {
"format": "string",
"retention": {
"duration": "P4DT12H30M5S"
"rotation": {
"schedule": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"log_path": "string",
"svm": {
"name": "svm1",
Status: 202, Accepted
num_records |
integer |
Number of records |
records |
array[s3_audit] |
"num_records": 1,
"records": [
"log": {
"format": "string",
"retention": {
"rotation": {
"schedule": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
140902401 |
Failed to create an audit configuration for the SVM. |
140902402 |
Audit configuration is already present. |
140902402 |
Audit configuration is already enabled. |
140902403 |
Failed to create staging volume. |
140902415 |
Failed to modify an audit configuration because no audit configuration exists for the SVM. |
140902416 |
Failed to modify audit configuration for SVM. |
140902422 |
Final consolidation is in progress, audit delete failed. |
140902423 |
Failed to delete the audit configuration for the SVM. |
140902425 |
Audit configuration is not available for disabling. |
140902430 |
Audit configuration is not available for enabling. |
140902431 |
Audit enable failed, audit configuration already enabled for the SVM. |
140902432 |
Final consolidation is in progress, audit enable failed. |
140902445 |
Audit disable failed, audit configuration does not exist for the SVM. |
140902446 |
140902447 |
Audit disable failed. |
140902456 |
The specified log_path does not exist. |
140902457 |
The log_path must be a directory. |
140902458 |
The log_path must be a canonical path in the SVM's namespace. |
140902459 |
The log_path cannot be empty. |
140902460 |
Rotate size must be greater than or equal to 1024 KB. |
140902461 |
The destination path must not contain a symbolic link. |
140902470 |
The log_path exceeds a maximum supported length of characters. |
140902471 |
The log_path contains an unsupported read-only (DP/LS) volume. |
140902472 |
The log_path is not a valid destination for the SVM. |
140902474 |
The log_path contains an unsupported Snaplock volume. |
140902478 |
The log_path validation failed. |
140902478 |
The log_path cannot be accessed for validation. |
140902490 |
Audit configuration is absent for rotate. |
140902491 |
Failed to rotate audit log. |
140902492 |
Cannot rotate audit log, auditing is not enabled for this SVM. |
9699340 |
SVM UUID lookup failed |
9699407 |
Additional fields are provided |
events
data |
boolean |
Data events |
management |
boolean |
Management events |
href |
string |
_links
retention
count |
integer |
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with "duration". |
duration |
string |
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with "count". |
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days |
array[integer] |
Specifies the day of the month schedule to rotate audit log. Leave empty for all. |
hours |
array[integer] |
Specifies the hourly schedule to rotate audit log. Leave empty for all. |
minutes |
array[integer] |
Specifies the minutes schedule to rotate the audit log. |
months |
array[integer] |
Specifies the months schedule to rotate audit log. Leave empty for all. |
weekdays |
array[integer] |
Specifies the weekdays schedule to rotate audit log. Leave empty for all. |
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now |
boolean |
Manually rotates the audit logs. Optional in PATCH only. Not available in POST. |
schedule |
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values. |
size |
integer |
Rotates logs based on log size in bytes. |
s3_log
format |
string |
Format in which the logs are generated by the consolidation process. Possible values are:
retention |
rotation |
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
s3_audit
Auditing for NAS events is a security measure that enables you to track and log certain S3 events on SVMs.
enabled |
boolean |
events |
log |
log_path |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
