REST API reference
Create an audit configuration
Creates an audit configuration, setting up where and how audit logs are stored for an SVM in ONTAP. Use this endpoint when you need to establish or modify audit logging settings for security and compliance purposes.
HTTP method and endpoint
POST /protocols/audit
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM to which audit configuration is to be created.
  • log_path - Path in the owning SVM namespace that is used to store audit logs.
Default property values
If not specified in POST, the following default property values are assigned:
  • enabled - true
  • events.authorization_policy - false
  • events.cap_staging - false
  • events.file_share - false
  • events.security_group - false
  • events.user_account - false
  • events.cifs_logon_logoff - true
  • events.file_operations - true
  • log.format - evtx
  • log.retention.count - 0
  • log.retention.duration - PT0S
  • log.rotation.size - 100MB
  • log.rotation.now - false
  • guarantee - true
  • vserver audit create
  • vserver audit enable
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
enabled
boolean
Specifies whether or not auditing is enabled on the SVM.
events
events
guarantee
boolean
Indicates whether there is a strict Guarantee of Auditing
log
log
log_path
string
The audit log destination path where consolidated audit logs are stored.
svm
svm
Example request
  "guarantee": "",
  "log": {
    "format": "string",
    "retention": {
      "duration": "P4DT12H30M5S"
    "rotation": {
      "schedule": {
        "days": [
          "integer"
        "hours": [
          "integer"
        "minutes": [
          "integer"
        "months": [
          "integer"
        "weekdays": [
          "integer"
  "log_path": "string",
  "svm": {
    "name": "svm1",
Status: 202, Accepted
num_records
integer
Number of records
records
array[audit]
  "num_records": 1,
  "records": [
      "guarantee": "",
      "log": {
        "format": "string",
        "retention": {
        "rotation": {
          "schedule": {
            "days": [
              "integer"
            "hours": [
              "integer"
            "minutes": [
              "integer"
            "months": [
              "integer"
            "weekdays": [
              "integer"
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262196
Log_rotation_now is not an allowed operation
2621462
The specified SVM does not exist
9699330
An audit configuration already exists
9699337
Audit system internal update is in progress, audit configuration create failed
9699340
SVM UUID lookup failed
9699358
Audit configuration is absent for enabling
9699359
Audit configuration is already enabled
9699360
Final consolidation is in progress, audit enable failed
9699365
Enabling of audit configuration failed
9699370
Auditing was successfully configured, however audit configuration could not be enabled
9699384
The specified log_path does not exist
9699385
The log_path must be a directory
9699386
The log_path must be a canonical path in the SVMs namespace
9699387
The log_path cannot be empty
9699388
Rotate size must be greater than or equal to 1024 KB
9699389
The log_path must not contain a symbolic link
9699398
The log_path exceeds a maximum supported length of characters
9699399
The log_path contains an unsupported read-only (DP/LS) volume
9699400
The specified log_path is not a valid destination for SVM
9699402
The log_path contains an unsupported snaplock volume
9699403
The log_path cannot be accessed for validation
9699406
The log_path validation failed
9699409
Failed to enable multiproto.audit.evtxlog.support support capability
9699428
All nodes need to run ONTAP 8.3.0 release to audit CIFS logon-logoff events
9699429
Failed to enable multiproto.audit.cifslogonlogoff.support support capability
9699431
All nodes need to run ONTAP 8.3.0 release to audit CAP staging events
9699432
Failed to enable multiproto.audit.capstaging.support support capability
events
boolean
Authorization policy change events
cap_staging
boolean
Central access policy staging events
cifs_logon_logoff
boolean
CIFS logon and logoff events
file_operations
boolean
File operation events
file_share
boolean
File share category events
security_group
boolean
Local security group management events
user_account
boolean
Local user account management events
string
retention
count
integer
Determines how many audit log files to retain before rotating the oldest log file out. This is mutually exclusive with duration.
duration
string
Specifies an ISO-8601 format date and time to retain the audit log file. The audit log files are deleted once they reach the specified date/time. This is mutually exclusive with count.
audit_schedule
Rotates the audit logs based on a schedule by using the time-based rotation parameters in any combination. The rotation schedule is calculated by using all the time-related values.
days
array[integer]
Specifies the day of the month schedule to rotate audit log. Leave empty for all.
hours
array[integer]
Specifies the hourly schedule to rotate audit log. Leave empty for all.
minutes
array[integer]
Specifies the minutes schedule to rotate the audit log.
months
array[integer]
Specifies the months schedule to rotate audit log. Leave empty for all.
weekdays
array[integer]
Specifies the weekdays schedule to rotate audit log. Leave empty for all.
rotation
Audit event log files are rotated when they reach a configured threshold log size or are on a configured schedule. When an event log file is rotated, the scheduled consolidation task first renames the active converted file to a time-stamped archive file, and then creates a new active converted event log file.
now
boolean
Manually rotates the audit logs. Optional in PATCH only. Not available in POST.
schedule
audit_schedule
size
integer
Rotates logs based on log size in bytes.
log
format
string
The format in which the logs are generated by consolidation process. Possible values are:
  • xml - Data ONTAP-specific XML log format
  • evtx - Microsoft Windows EVTX log format
    • Default value: 1
    • enum: ["xml", "evtx"]
    • Introduced in: 9.6
retention
retention
rotation
rotation
svm
_links
_links
name
string
The name of the SVM.
uuid
string
audit
Auditing for NAS events is a security measure that enables you to track and log certain CIFS and NFS events on SVMs.
enabled
boolean
events
events
guarantee
boolean
log
log
log_path
string
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
