Create a LUN
Creates a logical unit number (LUN) within a specified storage volume. This operation is useful for organizing and managing storage resources on your network.
HTTP method and endpoint
POST /storage/luns
Introduced in
ONTAP 9.6
Usage notes
Creates a LUN.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the LUN. -
name,location.volume.nameorlocation.volume.uuid- Existing volume in which to create the LUN. -
nameorlocation.logical_unit- Base name of the LUN. -
os_type- Operating system from which the LUN will be accessed. Required when creating a non-clone LUN and disallowed when creating a clone of an existing LUN. A clone'sos_typeis taken from the source LUN. -
space.size- Size of the LUN. Required when creating a non-clone LUN and disallowed when creating a clone of an existing LUN. A clone's size is taken from the source LUN.
Recommended optional properties
qos_policy.nameorqos_policy.uuid- Existing traditional or adaptive QoS policy to be applied to the LUN. All LUNs should be managed by a QoS policy at the volume or LUN level.
Default property values
If not specified in POST, the follow default property values are assigned.
auto_delete- false
Related ONTAP commands
lun create -
lun convert-from-namespace -
lun copy start -
volume file clone autodelete -
volume file clone create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
attributes |
array[attributes] |
An array of name/value pairs optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP. Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes. Valid in POST except when creating a LUN clone. A cloned can already have attributes from its source. You can add, modify, and delete the attributes of a LUN clone in separate requests after creation of the LUN. Attributes may be added/modified/removed for an existing LUN using the /api/storage/luns/{lun.uuid}/attributes endpoint. For further information, see DOC /storage/luns/{lun.uuid}/attributes . There is an added computational cost to retrieving property values for
auto_delete |
boolean |
This property marks the LUN for auto deletion when the volume containing the LUN runs out of space. This is most commonly set on LUN clones. When set to true, the LUN becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the LUN is also configured for auto deletion and free space in the volume decreases below a particular threshold. This property is optional in POST and PATCH. The default value for a new LUN is false. There is an added computational cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
class |
string |
The class of LUN. Optional in POST. |
clone |
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: Persistent reservations for the patched LUN are also preserved. |
comment |
string |
A configurable comment available for use by the administrator. Valid in POST and PATCH. |
consistency_group |
The LUN's consistency group. This property is populated for LUNs whose volume is a member of a consistency group. If the volume is a member of a child consistency group, the parent consistency group is reported. |
convert |
This sub-object is used in POST to convert a valid in-place NVMe namespace to a LUN. Setting a property in this sub-object indicates that a conversion from the specified NVMe namespace to LUN is desired. |
copy |
This sub-object applies to LUN copy operations. A LUN can be copied with a POST request that supplies Copying a LUN is an asynchronous activity begun by a POST request that specifies the source of the copy in the While LUNs are being copied, the status of the LUN copy operations can be obtained using a GET of the source or destination LUN that requests the There is an added computational cost to retrieving property values for |
create_time |
string |
The time the LUN was created. |
location |
The location of the LUN within the ONTAP cluster. Valid in POST and PATCH.
lun_maps |
array[lun_maps] |
The LUN maps with which the LUN is associated. There is an added computational cost to retrieving property values for |
movement |
This sub-object applies to LUN movement between volumes. A LUN can be moved to a new volume with a PATCH request that changes either the volume portion of property Moving a LUN between volumes is an asynchronous activity begun by a PATCH request. The data for the LUN is then asynchronously copied from the source volume to the destination volume. The time required to complete the move depends on the size of the LUN and the load on the cluster. The While the LUN is being moved, the status of the LUN movement operation can be obtained using a GET for the LUN that requests the There is an added computational cost to retrieving property values for |
name |
string |
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH. A PATCH that modifies the qtree and/or base name portion of the LUN path is considered a rename operation. A PATCH that modifies the volume portion of the LUN path begins an asynchronous LUN movement operation. |
os_type |
string |
The operating system type of the LUN. Required in POST when creating a LUN that is not a clone of another. Disallowed in POST when creating a LUN clone. |
qos_policy |
The QoS policy for the LUN. Both traditional and adaptive QoS policies are supported. If both property Note that a QoS policy can be set on a LUN, or a LUN's volume, but not both. |
serial_number |
string |
The LUN serial number. The serial number is generated by ONTAP when the LUN is created.
space |
The storage space related properties of the LUN. |
status |
Status information about the LUN. |
svm |
The SVM in which the LUN is located. |
uuid |
string |
The unique identifier of the LUN. The UUID is generated by ONTAP when the LUN is created.
vvol |
A VMware virtual volume (vVol) binding is an association between a LUN of class See POST /protocols/san/vvol-bindings to learn more about creating vVol bindings and DELETE /protocols/san/vvol-bindings to learn more about deleting vVol bindings. There is an added computational cost to retrieving property values for |
Example request
"attributes": [
"name": "name1",
"value": "value1"
"class": "string",
"clone": {
"source": {
"name": "/vol/volume1/lun1",
"comment": "string",
"consistency_group": {
"name": "cg1",
"uuid": "4abc2317-4332-9d37-93a0-20bd29c22df0"
"convert": {
"namespace": {
"name": "/vol/volume1/namespace1",
"copy": {
"destinations": [
"max_throughput": 0,
"name": "/vol/vol1/lun1",
"progress": {
"elapsed": 0,
"percent_complete": 0,
"state": "string"
"uuid": "1bc327d5-4654-5284-a116-f182282240b4"
"source": {
"name": "/vol/vol2/lun1",
"uuid": "03c05019-40d9-3945-c767-dca4c3be5e90"
"create_time": "2018-06-04T19:00:00Z",
"enabled": true,
"location": {
"logical_unit": "lun1",
"node": {
"name": "node1",
"qtree": {
"id": 1,
"name": "qt1"
"volume": {
"name": "volume1",
"lun_maps": [
"igroup": {
"name": "igroup1",
"logical_unit_number": 0
"movement": {
"paths": {
"destination": "/vol/vol1/lun1",
"source": "/vol/vol2/lun2"
"name": "/vol/volume1/qtree1/lun1",
"os_type": "string",
"qos_policy": {
"name": "qos1",
"serial_number": "string",
"space": {
"size": 1073741824,
"used": 0
"status": {
"container_state": "string",
"state": "online"
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"vvol": {
"bindings": [
"id": 1,
"partner": {
"secondary_id": "0000D20000010000h"
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[lun] |
"num_records": 1,
"records": [
"attributes": [
"name": "name1",
"value": "value1"
"class": "string",
"clone": {
"source": {
"name": "cg1",
"convert": {
"namespace": {
"copy": {
"destinations": [
"progress": {
"elapsed": 0,
"state": "string"
"source": {
"enabled": true,
"location": {
"node": {
"name": "node1",
"qtree": {
"id": 1,
"name": "qt1"
"volume": {
"name": "volume1",
"lun_maps": [
"igroup": {
"name": "igroup1",
"movement": {
"paths": {
"qos_policy": {
"name": "qos1",
"space": {
"size": 1073741824,
"used": 0
"status": {
"state": "online"
"svm": {
"name": "svm1",
"vvol": {
"bindings": [
"id": 1,
"partner": {
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
917927 |
The specified volume was not found. |
918236 |
The specified |
2621462 |
The specified SVM does not exist. |
2621706 |
The specified |
2621707 |
No SVM was specified. Either |
5242927 |
The specified qtree was not found. |
5242950 |
The specified |
5374121 |
A LUN name can only contain characters A-Z, a-z, 0-9, "-", ".", "_", "{" and "}". |
5374123 |
A negative size was provided for the LUN. |
5374124 |
The specified size is too small for the LUN. |
5374125 |
The specified size is too large for the LUN. |
5374129 |
LUNs cannot be created on a load sharing mirror volume. |
5374130 |
An invalid size value was provided. |
5374237 |
LUNs cannot be created on an SVM root volume. |
5374238 |
LUNs cannot be created in Snapshot copies. |
5374241 |
A size value with invalid units was provided. |
5374242 |
A LUN or NVMe namespace already exists at the specified path. |
5374352 |
An invalid name was provided for the LUN. |
5374707 |
Creating a LUN in the specific volume is not allowed because the volume is reserved for an application. |
5374858 |
The volume specified by |
5374859 |
No volume was specified for the LUN. |
5374860 |
The qtree specified by |
5374861 |
The LUN base name specified by |
5374862 |
No LUN path base name was provided for the LUN. |
5374863 |
An error occurred after successfully creating the LUN. Some properties were not set. |
5374874 |
The specified |
5374875 |
The specified |
5374876 |
The specified |
5374883 |
The property cannot be specified when creating a LUN clone. The |
5374884 |
A property that is required when creating a new LUN that is not a LUN clone or LUN copy was not supplied. The |
5374886 |
An error occurred after successfully creating the LUN preventing the retrieval of its properties. |
5374899 |
The |
5374928 |
An incomplete attribute name/value pair was supplied. |
5374929 |
The combined sizes of an attribute name and value are too large. |
5374932 |
A name for an attribute was duplicated. |
5374942 |
The property cannot be specified at the same time when creating a LUN as a clone. The |
5374943 |
The property cannot be specified at the same time when creating a LUN as a copy. The |
5374944 |
The property cannot be specified when converting an NVMe namespace into a LUN. The |
7018877 |
Maximum combined total (50) of file and LUN copy and move operations reached. When one or more of the operations has completed, try the command again. |
13565952 |
The LUN clone request failed. |
72089755 |
NVMe namespace with a block size of 4096 bytes cannot be converted to a LUN. |
72089756 |
Namespace is currently mapped to subsystem. |
72089757 |
NVMe namespace in a Snapshot copy cannot be converted to a LUN. |
href |
string |
_links
attributes
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Optional in POST.
name |
string |
The attribute name. |
value |
string |
The attribute value. |
source
The source LUN for a LUN clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST to create a new LUN as a clone of the source.
Valid in PATCH to overwrite an existing LUN's data as a clone of another.
name |
string |
The fully qualified path name of the clone source LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH. |
uuid |
string |
The unique identifier of the clone source LUN. Valid in POST and PATCH. |
clone
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: auto_delete, qos_policy, space.guarantee.requested and space.scsi_thin_provisioning_support_enabled.
When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: class, auto_delete, lun_maps, serial_number, status.state, and uuid.
source |
The source LUN for a LUN clone operation. This can be specified using property Valid in POST to create a new LUN as a clone of the source. Valid in PATCH to overwrite an existing LUN's data as a clone of another. |
consistency_group
name |
string |
The name of the consistency group. |
uuid |
string |
The unique identifier of the consistency group. |
namespace
The source namespace for convert operation. This can be specified using property convert.namespace.uuid or convert.namespace.name. If both properties are supplied, they must refer to the same NVMe namespace.
Valid in POST. A convert request from NVMe namespace to LUN cannot be combined with setting any other LUN properties. All other properties of the converted LUN comes from the source NVMe namespace.
name |
string |
The fully qualified path name of the source NVMe namespace composed of a "/vol" prefix, the volume name, the (optional) qtree name and base name of the NVMe namespace. Valid in POST. |
uuid |
string |
The unique identifier of the source NVMe namespace. Valid in POST. |
convert
namespace |
The source namespace for convert operation. This can be specified using property Valid in POST. A convert request from NVMe namespace to LUN cannot be combined with setting any other LUN properties. All other properties of the converted LUN comes from the source NVMe namespace. |
code |
string |
Argument code |
message |
string |
Message argument |
error
Error information provided if the asynchronous LUN copy operation fails.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
progress
Properties related to the progress of an active or recently completed LUN copy.
elapsed |
integer |
The amount of time that has elapsed since the start of the LUN copy, in seconds. |
percent_complete |
integer |
The percentage completed of the LUN copy. |
state |
string |
The state of the LUN copy. |
volume_snapshot_blocked |
boolean |
This property reports if volume Snapshot copies are blocked by the LUN copy. This property can be polled to identify when volume Snapshot copies can be resumed after beginning a LUN copy. |
destinations
A LUN copy operation in which the containing LUN is the source of the copy.
max_throughput |
integer |
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN copy. See property |
name |
string |
The fully qualified path of the LUN copy destination composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. |
progress |
Properties related to the progress of an active or recently completed LUN copy. |
uuid |
string |
The unique identifier of the LUN copy destination. |
progress
elapsed |
integer |
percent_complete |
integer |
boolean |
source
The source LUN of a LUN copy operation in which the containing LUN is the destination of the copy.
Valid in POST except when creating a LUN clone. A LUN copy request cannot be combined with setting any other LUN properties except the destination location. All other properties of the destination LUN come from the source LUN.
max_throughput |
integer |
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN copy. This property can be used to throttle a transfer and limit its impact on the performance of the source and destination nodes. The specified value will be rounded up to the nearest megabyte. If this property is not specified in a POST that begins a LUN copy, throttling is not applied to the data transfer. For more information, see Size properties in the docs section of the ONTAP REST API documentation. Valid only in a POST that begins a LUN copy or a PATCH when a LUN copy is already in process.
name |
string |
The fully qualified path of the LUN copy source composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Set this property in POST to specify the source for a LUN copy operation. |
uuid |
string |
The unique identifier of the LUN copy source. Set this property in POST to specify the source for a LUN copy operation. |
copy
This sub-object applies to LUN copy operations. A LUN can be copied with a POST request that supplies copy.source properties.
Copying a LUN is an asynchronous activity begun by a POST request that specifies the source of the copy in the copy.source properties. The data for the LUN is then asynchronously copied from the source to the destination. The time required to complete the copy depends on the size of the LUN and the load on the cluster. The copy sub-object is populated while a LUN copy is in progress and for two (2) minutes following completion of a copy.
While LUNs are being copied, the status of the LUN copy operations can be obtained using a GET of the source or destination LUN that requests the copy properties. If the LUN is the source LUN for one or more copy operations, the copy.destinations array is populated in GET. If the containing LUN is the destination LUN for a copy operation, the copy.source sub-object is populated in GET. The LUN copy operation can be further modified using a PATCH on the properties on the copy.source sub-object of the copy destination LUN.
There is an added computational cost to retrieving property values for copy. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
destinations |
array[destinations] |
An array of destination LUNs of LUN copy operations in which the containing LUN is the source of the copy. |
source |
The source LUN of a LUN copy operation in which the containing LUN is the destination of the copy. Valid in POST except when creating a LUN clone. A LUN copy request cannot be combined with setting any other LUN properties except the destination location. All other properties of the destination LUN come from the source LUN. |
node
The cluster node that hosts the LUN.
name |
string |
uuid |
string |
qtree
The qtree in which the LUN is optionally located. Valid in POST and PATCH.
If properties name and location.qtree.name and/or location.qtree.uuid are specified in the same request, they must refer to the same qtree.
A PATCH that modifies the qtree of the LUN is considered a rename operation.
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. |
volume
The volume in which the LUN is located. Valid in POST and PATCH.
If properties name and location.volume.name and/or location.volume.uuid are specified in the same request, they must refer to the same volume.
A PATCH that modifies the volume of the LUN begins an asynchronous LUN movement operation.
name |
string |
The name of the volume. |
uuid |
string |
location
logical_unit |
string |
The base name component of the LUN. Valid in POST and PATCH. If properties A PATCH that modifies the base name of the LUN is considered a rename operation. |
node |
The cluster node that hosts the LUN. |
qtree |
The qtree in which the LUN is optionally located. Valid in POST and PATCH. If properties A PATCH that modifies the qtree of the LUN is considered a rename operation. |
volume |
The volume in which the LUN is located. Valid in POST and PATCH. If properties A PATCH that modifies the volume of the LUN begins an asynchronous LUN movement operation. |
igroup
The initiator group to which the LUN is mapped.
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
lun_maps
A LUN map with which the LUN is associated.
igroup |
The initiator group to which the LUN is mapped. |
logical_unit_number |
integer |
The logical unit number assigned to the LUN for initiators in the initiator group. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
paths
The fully qualified LUN path names involved in the LUN movement.
destination |
string |
The fully qualified path of the LUN movement destination composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. |
source |
string |
The fully qualified path of the LUN movement source composed of a "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. |
error
Error information provided if the asynchronous LUN movement operation fails.
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
progress
Properties related to the progress of an active or recently completed LUN movement.
elapsed |
integer |
The amount of time that has elapsed since the start of the LUN movement, in seconds. |
percent_complete |
integer |
The percentage completed of the LUN movement. |
boolean |
This property reports if volume Snapshot copies are blocked by the LUN movement. This property can be polled to identify when volume Snapshot copies can be resumed after beginning a LUN movement. |
movement
This sub-object applies to LUN movement between volumes. A LUN can be moved to a new volume with a PATCH request that changes either the volume portion of property name, location.volume.uuid, or location.volume.name. If the volume is changed using more than one of these properties, the supplied properties used must refer to the same volume.
Moving a LUN between volumes is an asynchronous activity begun by a PATCH request. The data for the LUN is then asynchronously copied from the source volume to the destination volume. The time required to complete the move depends on the size of the LUN and the load on the cluster. The movement sub-object is populated while a LUN movement is in progress and for two (2) minutes following completion of a movement.
While the LUN is being moved, the status of the LUN movement operation can be obtained using a GET for the LUN that requests the movement properties. The LUN movement operation can be further modified using a PATCH on the properties on the movement sub-object.
There is an added computational cost to retrieving property values for movement. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
max_throughput |
integer |
The maximum data throughput, in bytes per second, that should be utilized in support of the LUN movement. This property can be used to throttle a transfer and limit its impact on the performance of the source and destination nodes. The specified value will be rounded up to the nearest megabyte. If this property is not specified in a POST that begins a LUN movement, throttling is not applied to the data transfer. For more information, see Size properties in the docs section of the ONTAP REST API documentation. This property is valid only in a POST that begins a LUN movement or a PATCH when a LUN movement is already in process.
paths |
The fully qualified LUN path names involved in the LUN movement. |
qos_policy
The QoS policy for the LUN. Both traditional and adaptive QoS policies are supported. If both property qos_policy.uuid and qos_policy.name are specified in the same request, they must refer to the same QoS policy. To remove the QoS policy from a LUN, leaving it with no QoS policy, set property qos_policy.name to an empty string ("") in a PATCH request. Valid in POST and PATCH.
name |
string |
The name of the QoS policy. To remove the QoS policy from a LUN, leaving it with no QoS policy, set this property to an empty string ("") in a PATCH request. Valid in POST and PATCH. |
uuid |
string |
The unique identifier of the QoS policy. Valid in POST and PATCH. |
guarantee
Properties that request and report the space guarantee for the LUN.
requested |
boolean |
The requested space reservation policy for the LUN. If true, a space reservation is requested for the LUN; if false, the LUN is thin provisioned. Guaranteeing a space reservation request for a LUN requires that the volume in which the LUN resides is also space reserved and that the fractional reserve for the volume is 100%. Valid in POST and PATCH. |
reserved |
boolean |
Reports if the LUN is space guaranteed. If true, a space guarantee is requested and the containing volume and aggregate support the request. If false, a space guarantee is not requested or a space guarantee is requested and either the containing volume or aggregate do not support the request. |
space
guarantee |
Properties that request and report the space guarantee for the LUN. |
scsi_thin_provisioning_support_enabled |
boolean |
To leverage the benefits of SCSI thin provisioning, it must be supported by your host. SCSI thin provisioning uses the Logical Block Provisioning feature as defined in the SCSI SBC-3 standard. Only hosts that support this standard can use SCSI thin provisioning in ONTAP. When you enable SCSI thin provisioning support in ONTAP, you turn on the following SCSI thin provisioning features:
The value of this property is not propagated to the destination when a LUN is cloned as a new LUN or copied; it is reset to false. The value of this property is maintained from the destination LUN when a LUN is overwritten as a clone. Valid in POST and PATCH.
size |
integer |
The total provisioned size of the LUN. The LUN size can be increased but not be made smaller using the REST interface. The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes in bytes. The actual minimum and maxiumum sizes vary depending on the ONTAP version, ONTAP platform and the available space in the containing volume and aggregate. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
used |
integer |
The amount of space consumed by the main data stream of the LUN. This value is the total space consumed in the volume by the LUN, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways SAN filesystems and applications utilize blocks within a LUN, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the LUN blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
status
container_state |
string |
The state of the volume and aggregate that contain the LUN. LUNs are only available when their containers are available. |
mapped |
boolean |
Reports if the LUN is mapped to one or more initiator groups. There is an added computational cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
read_only |
boolean |
Reports if the LUN allows only read access. |
state |
string |
The state of the LUN. Normal states for a LUN are online and offline. Other states indicate errors. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
partner
The LUN partner that this LUN is bound to. If this LUN is a vvol class LUN, the partner is a protocol_endpoint class LUN.
name |
string |
The name of the partner LUN. |
uuid |
string |
The unique identifier of the partner LUN. |
bindings
A vVol binding with which the LUN is associated.
id |
integer |
The ONTAP internal identifier assigned to the vVol binding. The bind identifier is unique amongst all class This property was included in early releases of the REST API for vVols and is maintained for backward compatability. See the
partner |
The LUN partner that this LUN is bound to. If this LUN is a |
secondary_id |
string |
The identifier assigned to the vVol binding, known as the secondary LUN ID. The identifier is unique amongst all class The format for a secondary LUN ID is 16 hexadecimal digits (zero-filled) followed by a lower case "h". |
vvol
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
There is an added computational cost to retrieving property values for vvol. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
bindings |
array[bindings] |
Bindings between the LUN, which must be of class A class The bindings array contains LUNs of the opposite class of the containing LUN object. There is an added computational cost to retrieving property values for |
is_bound |
boolean |
Reports if the LUN is part of a VMware virtual volume (vVol) bind relationship. This is |
lun
A LUN is the logical representation of storage in a storage area network (SAN).
In ONTAP, a LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
A LUN can be created to a specified size using thin or thick provisioning. A LUN can then be renamed, resized, cloned, and moved to a different volume. LUNs support the assignment of a quality of service (QoS) policy for performance management or a QoS policy can be assigned to the volume containing the LUN. See the LUN object model to learn more about each of the properties supported by the LUN REST API.
A LUN must be mapped to an initiator group to grant access to the initiator group's initiators (client hosts). Initiators can then access the LUN and perform I/O over a Fibre Channel (FC) fabric using the Fibre Channel Protocol or a TCP/IP network using iSCSI.
attributes |
array[attributes] |
auto_delete |
boolean |
class |
string |
clone |
comment |
string |
consistency_group |
convert |
copy |
create_time |
string |
location |
lun_maps |
array[lun_maps] |
movement |
name |
string |
os_type |
string |
qos_policy |
serial_number |
string |
space |
status |
svm |
uuid |
string |
vvol |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
