ONTAP REST API snaplock endpoints
SnapLock endpoints manage the storage and retention of WORM data, ensuring non-rewritable and non-erasable storage in compliance with regulatory requirements. Use these endpoints to configure SnapLock features like logs, compliance clocks, event retention policies, file retention, privileged delete operations, file fingerprinting, and legal holds, providing stringent data protection for sensitive environments.
SnapLock is an alternative to the traditional optical "write once, read many" (WORM) data. SnapLock is used for the storage of read-only WORM data. SnapLock is a license-based, disk-based, open-protocol feature that works with application software to administer non-rewritable storage of data. The primary objective of this feature is to provide storage-enforced WORM and retention functionality. SnapLock can be deployed for protecting data in strict regulatory environments in such a way that even the storage administrator is considered an untrusted party. SnapLock provides special purpose volumes in which files can be stored and committed to a non-erasable, non-rewritable state either forever or for a designated retention period. SnapLock allows this retention to be performed at the granularity of individual files. These APIs allow you to manage the following endpoints:
SnapLock log
SnapLock compliance-clock
SnapLock event-retention
SnapLock file retention
SnapLock privileged-delete
SnapLock file fingerprint
SnapLock legal-hold
APIs
SnapLock log
These APIs are used to create and initialize the SnapLock log configuration for an SVM, modify attributes associated with the SnapLock log configuration,and delete the auditlog configuration.
This API manages the ComplianceClock of the system. ComplianceClock determines the expiry time of the SnapLock objects in the system. ComplianceClock can be initialized only once by the user and once it is set, it cannot be changed or altered by the user.
This API is used to create Event Based Retention (EBR) policies for an SVM. A policy consists of a policy-name and a retention-period. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
This API is used to set the retention time of a file. Retention time expects the date in ISO 8601 format or "infinite".
This API is used to perform a privileged-delete operation on unexpired WORM files on a SnapLock Enterprise volume. The only built-in role that has access to the command is "vsadmin-snaplock".
This API is used to start the fingerprint computation on a file.
SnapLock legal-hold
This API is used to retain Compliance-mode WORM files for the duration of a litigation. A file under a Legal-Hold behaves like a WORM file with an indefinite retention period. Only a user with security login role vsadmin-snaplock is allowed to perform the operation.
