Storage file moves endpoint overview
Overview
You can use this API to start a file move operation between two FlexVol volumes or within a FlexGroup volume, and view the status of all on-going file move operations in the cluster.
– GET /api/storage/file/moves
– GET /api/storage/file/moves/{node.uuid}/{uuid}/{index}
– POST /api/storage/file/moves
Moving two files from one FlexVol volume to the other FlexVol volume
# The API: /api/storage/file/moves # The call: curl -X POST "https://<mgmt-ip>/api/storage/file/moves" -H "accept: application/hal+json" -d @move_between_fv.txt move_between_fv.txt: { "files_to_move":{ "sources":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fv1" }, "path":"dir1/f1.txt" }, { "svm":{ "name":"vs0" }, "volume":{ "name":"fv1" }, "path":"dir1/f2.txt" } ], "destinations":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fv2" }, "path":"dir2/f1.txt" }, { "svm":{ "name":"vs0" }, "volume":{ "name":"fv2" }, "path":"dir2/f2.txt" } ] } } # The response: { }
Moving two files from one FlexVol volume to the other FlexVol volume (only specifying the destination directory)
# The API: /api/storage/file/moves # The call: curl -X POST "https://<mgmt-ip>/api/storage/file/moves" -H "accept: application/hal+json" -d @move_between_fv_dir.txt move_between_fv_dir.txt: { "files_to_move":{ "sources":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fv1" }, "path":"dir1/f3.txt" }, { "svm":{ "name":"vs0" }, "volume":{ "name":"fv1" }, "path":"dir1/f4.txt" } ], "destinations":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fv2" }, "path":"dir2/" } ] } } # The response: { }
Moving multiple files from one FlexVol volume to the other FlexVol volume and providing a source reference file
# The API: /api/storage/file/moves # The call: curl -X POST "https://<mgmt-ip>/api/storage/file/moves" -H "accept: application/hal+json" -d @move_between_fv_source.txt move_between_fv_source.txt: { "files_to_move":{ "sources":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fv1" }, "path":"dir1/f5.txt" }, { "svm":{ "name":"vs0" }, "volume":{ "name":"fv1" }, "path":"dir1/f6.txt" }, { "svm":{ "name":"vs0" }, "volume":{ "name":"fv1" }, "path":"dir1/f7.txt" } ], "destinations":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fv2" }, "path":"dir2/f5.txt" }, { "svm":{ "name":"vs0" }, "volume":{ "name":"fv2" }, "path":"dir2/f6.txt" }, { "svm":{ "name":"vs0" }, "volume":{ "name":"fv2" }, "path":"dir2/f700.txt" } ] }, "reference":{ "svm":{ "name":"vs0" }, "volume":{ "name":"fv1" }, "path":"dir1/f6.txt" } } # The response: { }
Moving a file between two FlexGroup volume constituents in the same FlexGroup volume
# The API: /api/storage/file/moves # The call: curl -X POST "https://<mgmt-ip>/api/storage/file/moves" -H "accept: application/hal+json" -d @move_between_fg.txt move_between_fg.txt: { "files_to_move":{ "sources":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fg2" }, "path":"test/file.txt" } ], "destinations":[ { "volume":{ "name":"fg2__0008" } } ] } } # The response: { }
Automatically selecting a destination constituent to move a file in a FlexGroup volume for capacity rebalancing
# The API: /api/storage/file/moves # The call: curl -X POST "https://<mgmt-ip>/api/storage/file/moves?automatic=true" -H "accept: application/hal+json" -d @move_between_fg_automatic.txt move_between_fg_automatic.txt: { "files_to_move":{ "sources":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fg2" }, "path":"test/file2.txt" } ] } } # The response: { }
Moving a file between two FlexGroup volume constituents in the same FlexGroup volume using the "force" and "disruptive" options
# The API: /api/storage/file/moves # The call: curl -X POST "https://<mgmt-ip>/api/storage/file/moves?force=true&disruptive=true" -H "accept: application/hal+json" -d @move_between_fg_force.txt move_between_fg_force.txt { "files_to_move":{ "sources":[ { "svm":{ "name":"vs0" }, "volume":{ "name":"fg2" }, "path":"test/file3.txt" } ], "destinations":[ { "volume":{ "name":"fg2__0008" } } ] } } # The response: { }
Retrieving file move operations
# The API: /api/storage/file/moves # The call: curl -X GET "https://<mgmt-ip>/api/storage/file/moves" -H 'accept: application/hal+json' # The response: { "records": [ { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "e12bc78d-36bb-4274-8163-fb8c21d59c9b", "index": 0, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "4e919b6d-1c76-11ec-8e1b-005056acf2dd", "name": "fg2__0008" }, "path": "test/file2.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "4d14f2f6-1c76-11ec-8e1b-005056acf2dd", "name": "fg2__0005" }, "path": "test/file2.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/e12bc78d-36bb-4274-8163-fb8c21d59c9b/0" } } }, { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "ce2af347-586d-4b31-b728-1e925f51fdfc", "index": 1, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f2.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f2.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/ce2af347-586d-4b31-b728-1e925f51fdfc/1" } } }, { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "ce2af347-586d-4b31-b728-1e925f51fdfc", "index": 0, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f1.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f1.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/ce2af347-586d-4b31-b728-1e925f51fdfc/0" } } }, { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "6d12601b-5377-43bf-99f0-b4bec37565e2", "index": 0, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f3.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f3.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/6d12601b-5377-43bf-99f0-b4bec37565e2/0" } } }, { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "6d12601b-5377-43bf-99f0-b4bec37565e2", "index": 1, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f4.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f4.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/6d12601b-5377-43bf-99f0-b4bec37565e2/1" } } }, { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "bbfdface-0d46-4f5f-9624-72f4869eba81", "index": 0, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f5.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f5.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/bbfdface-0d46-4f5f-9624-72f4869eba81/0" } } }, { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "bbfdface-0d46-4f5f-9624-72f4869eba81", "index": 2, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f7.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f700.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/bbfdface-0d46-4f5f-9624-72f4869eba81/2" } } }, { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "bbfdface-0d46-4f5f-9624-72f4869eba81", "index": 1, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f6.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f6.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/bbfdface-0d46-4f5f-9624-72f4869eba81/1" } } }, { "node": { "uuid": "780255d2-10aa-11ec-a308-005056acf86d", "name": "node2", "_links": { "self": { "href": "/api/cluster/nodes/780255d2-10aa-11ec-a308-005056acf86d" } } }, "uuid": "6591a42a-4ea2-4d40-bfb4-38959f6bd68e", "index": 0, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "438731dd-1c76-11ec-8e1b-005056acf2dd", "name": "fg2__0001" }, "path": "test/file.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "4e919b6d-1c76-11ec-8e1b-005056acf2dd", "name": "fg2__0008" }, "path": "/test/file.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/780255d2-10aa-11ec-a308-005056acf86d/6591a42a-4ea2-4d40-bfb4-38959f6bd68e/0" } } }, { "node": { "uuid": "780255d2-10aa-11ec-a308-005056acf86d", "name": "node2", "_links": { "self": { "href": "/api/cluster/nodes/780255d2-10aa-11ec-a308-005056acf86d" } } }, "uuid": "1a94e95a-346e-4eb3-969a-110e275cbf18", "index": 0, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "438731dd-1c76-11ec-8e1b-005056acf2dd", "name": "fg2__0001" }, "path": "test/file3.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "4e919b6d-1c76-11ec-8e1b-005056acf2dd", "name": "fg2__0008" }, "path": "/test/file3.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/780255d2-10aa-11ec-a308-005056acf86d/1a94e95a-346e-4eb3-969a-110e275cbf18/0" } } } ], "num_records": 10, "_links": { "self": { "href": "/api/storage/file/moves" } } }
Retrieving all moves in a file move operation
# The API: /api/storage/file/moves/{node.uuid}/{uuid}/{index} # The call: curl -X GET "https://<mgmt-ip>/api/storage/file/moves/*/ce2af347-586d-4b31-b728-1e925f51fdfc/*" -H 'accept: application/hal+json' # The response: { "records": [ { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "ce2af347-586d-4b31-b728-1e925f51fdfc", "index": 1, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f2.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f2.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/ce2af347-586d-4b31-b728-1e925f51fdfc/1" } } }, { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "ce2af347-586d-4b31-b728-1e925f51fdfc", "index": 0, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f1.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f1.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/ce2af347-586d-4b31-b728-1e925f51fdfc/0" } } } ], "num_records": 2, "_links": { "self": { "href": "/api/storage/file/moves/*/ce2af347-586d-4b31-b728-1e925f51fdfc" } } }
Retrieving a specific file move in a file move operation
# The API: /api/storage/file/moves/{node.uuid}/{uuid}/{index} # The call: curl -X GET "https://<mgmt-ip>/api/storage/file/moves/*/ce2af347-586d-4b31-b728-1e925f51fdfc/1" -H 'accept: application/hal+json' # The response: { "node": { "uuid": "76bc12d1-10aa-11ec-a5b5-005056acf2dd", "name": "node1", "_links": { "self": { "href": "/api/cluster/nodes/76bc12d1-10aa-11ec-a5b5-005056acf2dd" } } }, "uuid": "ce2af347-586d-4b31-b728-1e925f51fdfc", "index": 1, "source": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "18fd9110-26f1-11ec-bf0d-005056acf2dd", "name": "fv1" }, "path": "dir1/f2.txt" }, "destination": { "svm": { "uuid": "5b2c8638-10bc-11ec-8e1b-005056acf2dd", "name": "vs0" }, "volume": { "uuid": "220bdb3a-26f1-11ec-bf0d-005056acf2dd", "name": "fv2" }, "path": "dir2/f2.txt" }, "_links": { "self": { "href": "/api/storage/file/moves/76bc12d1-10aa-11ec-a5b5-005056acf2dd/ce2af347-586d-4b31-b728-1e925f51fdfc/1" } } }
