Storage volumes volume.uuid snapshots endpoint overview
Overview
A Snapshot copy is the view of the filesystem as it exists at the time when the Snapshot copy is created.
In ONTAP, different types of Snapshot copies are supported, such as scheduled Snapshot copies, user requested Snapshot copies, SnapMirror Snapshot copies, and so on.
ONTAP Snapshot copy APIs allow you to create, modify, delete and retrieve Snapshot copies.
ONTAP Bulk Snapshot copy APIs allow you to create, modify, delete and retrieve Snapshot copies on multiple volumes in one request.
Snapshot copy APIs
The following APIs are used to perform operations related to Snapshot copies.
– POST /api/storage/volumes/{volume.uuid}/snapshots
– GET /api/storage/volumes/{volume.uuid}/snapshots
– GET /api/storage/volumes/{volume.uuid}/snapshots/{uuid}
– PATCH /api/storage/volumes/{volume.uuid}/snapshots/{uuid}
– DELETE /api/storage/volumes/{volume.uuid}/snapshots/{uuid} The following APIs are used to perform bulk operations related to Snapshot copies.
– POST /api/storage/volumes/*/snapshots
– GET /api/storage/volumes/*/snapshots
– PATCH /api/storage/volumes/*/snapshots/{uuid}
– DELETE /api/storage/volumes/*/snapshots/{uuid}
Creating a Snapshot copy
The POST operation is used to create a Snapshot copy with the specified attributes.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/snapshots" -H "accept: application/hal+json" -d '{"name": "snapshot_copy", "comment": "Store this copy." }'
# The response:
HTTP/1.1 202 Accepted
Date: Wed, 13 Mar 2019 22:43:34 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/?name=snapshot_copy
Content-Length: 189
Content-Type: application/json
"num_records": 1,
"records": [
    "volume": {
      "name": "v2"
    "svm": {
      "uuid": "8139f958-3c6e-11e9-a45f-005056bbc848",
      "name": "vs0"
"job": {
  "uuid": "6f68c85b-45e1-11e9-8fc7-005056bbc848",
      "href": "/api/cluster/jobs/6f68c85b-45e1-11e9-8fc7-005056bbc848"
# The Job:
HTTP/1.1 200 OK
Date: Wed, 13 Mar 2019 22:43:57 GMT
Content-Length: 224
"description": "POST /api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/?name=snapshot_copy",
"state": "success",
"message": "success",
"code": 0
Retrieving Snapshot copy attributes
The GET operation is used to retrieve Snapshot copy attributes.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/snapshots" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 13 Mar 2019 21:14:06 GMT
Transfer-Encoding: chunked
"records": [
    "uuid": "402b6c73-73a0-4e89-a58a-75ee0ab3e8c0",
    "name": "hourly.2019-03-13_1305",
        "href": "/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/402b6c73-73a0-4e89-a58a-75ee0ab3e8c0"
    "uuid": "f0dd497f-efe8-44b7-a4f4-bdd3890bc0c8",
    "name": "hourly.2019-03-13_1405",
        "href": "/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/f0dd497f-efe8-44b7-a4f4-bdd3890bc0c8"
    "uuid": "02701900-51bd-46b8-9c77-47d9a9e2ce1d",
    "name": "hourly.2019-03-13_1522",
        "href": "/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/02701900-51bd-46b8-9c77-47d9a9e2ce1d"
"num_records": 3,
    "href": "/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots"
Creating bulk Snapshot copies
The POST operation is used to create a Snapshot copy with the same name on multiple volumes in one request. This operation accepts a volume UUID or volume name and SVM, and a Snapshot copy name. This operation only supports SnapMirror label attributes to be added to Snapshot copies during creation.
# The API:
# The call:
curl -k -u admin -X POST "https://<mgmt-ip>/api/storage/volumes/*/snapshots" -H 'accept: application/hal+json' -d '{"records": [{"volume.uuid":"e8815adb-5209-11ec-b4ad-005056bbc3e8", "name":"snapshot_copy"},{ "volume.uuid":"efda9101-5209-11ec-b4ad-005056bbc3e8", "name":"snapshot_copy"}]}'
# The response:
Date: Tue, 14 Dec 2021 20:18:13 GMT
Content-Security-Policy: default-src 'self'; script-src 'self' 'unsafe-inline'; style-src 'self' 'unsafe-inline'; img-src 'self' data:; frame-ancestors: 'self'
Content-Length: 209
"num_records": 2,
"job": {
  "uuid": "f7130fc0-5d1a-11ec-b78c-005056bbb467",
      "href": "/api/cluster/jobs/f7130fc0-5d1a-11ec-b78c-005056bbb467"
# The Job:
HTTP/1.1 200 OK
Date: Tue, 14 Dec 2021 20:20:54 GMT
Content-Length: 258
Vary: Accept-Encoding
"description": "POST /api/storage/volumes/*/snapshots/",
"state": "success",
"code": 0,
"start_time": "2021-12-14T15:18:13-05:00",
"end_time": "2021-12-14T15:18:13-05:00"
Retrieving Snapshot copy advanced attributes
A collection GET request is used to calculate the amount of Snapshot copy reclaimable space. When the advanced privilege field 'reclaimable space' is requested, the API returns the amount of reclaimable space for the queried list of Snapshot copies.
# The API:
/api/storage/volumes/{volume.uuid}/snapshots?fields=reclaimable_space
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/snapshots?fields=reclaimable_space&name=hourly.2019-03-13_1305|hourly.2019-03-13_1405|hourly.2019-03-13_1522" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
"records": [
"num_records": 3,
"reclaimable_space": 1567832,
A collection GET request is used to calculate the delta between two Snapshot copies. When the advanced privilege field 'delta' is requested, the API returns the delta between the queried Snapshot copies.
# The API:
/api/storage/volumes/{volume.uuid}/snapshots?fields=delta
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/{volume.uuid}/snapshots?fields=delta&name=hourly.2022-06-29_1105,hourly.2022-06-29_1205" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Connection: Keep-Alive
Content-Encoding: gzip
Content-Length: 378
Content-Type: application/hal+json
Date: Wed, 29 Jun 2022 18:37:11 GMT
Keep-Alive: timeout=5, max=99
"records": [
    "uuid": "52a2247a-7735-4a92-bc3c-e51df1fe502f",
    "name": "hourly.2022-06-29_1105",
    "delta": {
      "size_consumed": 675840,
      "time_elapsed": "PT3H27M45S"
    "uuid": "b399eb34-44fe-4689-9fb5-c8f72162dd77",
    "name": "hourly.2022-06-29_1205",
    "delta": {
      "size_consumed": 507904,
      "time_elapsed": "PT2H27M45S"
"num_records": 2,
"delta": {
  "size_consumed": 167936,
  "time_elapsed": "PT1H"
Retrieving the attributes of a specific Snapshot copy
The GET operation is used to retrieve the attributes of a specific Snapshot copy.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/402b6c73-73a0-4e89-a58a-75ee0ab3e8c0" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Wed, 13 Mar 2019 22:39:26 GMT
Content-Length: 308
"volume": {
  "uuid": "0353dc05-405f-11e9-acb6-005056bbc848",
  "name": "v2",
      "href": "/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848"
"svm": {
  "name": "vs0",
      "href": "/api/svm/svms/8139f958-3c6e-11e9-a45f-005056bbc848"
"create_time": "2019-03-13T13:05:00-04:00",
"size": 122880,
Retrieving the advanced attributes of a specific Snapshot copy
The GET operation is used to retrieve the attributes of a specific Snapshot copy. Snapshot copy reclaimable space can be requested during a GET request. When the advanced privilege field reclaimable space is requested, the API returns the amount of reclaimable space for the Snapshot copy.
# The API:
/api/storage/volumes/{volume.uuid}/snapshots/{uuid}?fields=reclaimable_space
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/402b6c73-73a0-4e89-a58a-75ee0ab3e8c0?fields=**" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Content-Length: 308
"volume": {
  "name": "v2",
"svm": {
  "name": "vs0",
"reclaimable_space": 167832,
# The API:
# The call:
# The response:
HTTP/1.1 200 OK
Content-Length: 378
"records": [
    "delta": {
    "delta": {
"num_records": 2,
"delta": {
Retrieving bulk Snapshot copies
The bulk GET operation is used to retrieve Snapshot copy attributes across all volumes.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volumes/*/snapshots" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
"records": [
    "volume": {
      "uuid": "966c285f-47f7-11ec-8407-005056bbc08f",
      "name": "v1"
    "uuid": "3edba912-5507-4535-adce-e12fe5c0e31c",
    "name": "daily.2021-11-18_0010"
    "volume": {
      "name": "v1"
    "uuid": "3ad61153-d5ef-495d-8e0e-5c3b8bbaf5e6",
    "name": "hourly.2021-11-18_0705"
    "volume": {
      "uuid": "99c974e3-47f7-11ec-8407-005056bbc08f",
      "name": "v2"
    "uuid": "3dd0fa97-65d9-41ea-a99d-5ceb9d2f55c5",
   "volume": {
     "name": "v2"
   "uuid": "6ca20a52-c342-4753-8865-3693fa9b7e23",
"num_records": 4
Updating a Snapshot copy
The PATCH operation is used to update the specific attributes of a Snapshot copy.
# The API:
# The call:
curl -X PATCH  "https://<mgmt-ip>/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/16f7008c-18fd-4a7d-8485-a0e290d9db7f" -d '{"name": "snapshot_copy_new" }' -H "accept: application/hal+json"
# The response:
Date: Wed, 13 Mar 2019 22:50:44 GMT
Content-Length: 189
"job": {
  "uuid": "6f7c3a82-45e2-11e9-8fc7-005056bbc848",
      "href": "/api/cluster/jobs/6f7c3a82-45e2-11e9-8fc7-005056bbc848"
# The Job:
HTTP/1.1 200 OK
Date: Wed, 13 Mar 2019 22:54:16 GMT
Content-Length: 242
"description": "PATCH /api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/16f7008c-18fd-4a7d-8485-a0e290d9db7f",
"state": "success",
"code": 0
Updating bulk Snapshot copies
The bulk PATCH operation is used to update the specific attributes of Snapshot copies across volumes in a single request.
# The API:
# The call:
curl -X PATCH  "https://<mgmt-ip>/api/storage/volumes/*/snapshots" -d '{"records": [{"volume.uuid":"e8815adb-5209-11ec-b4ad-005056bbc3e8", "svm.uuid":"d0e6def5-5209-11ec-b4ad-005056bbc3e8", "uuid":"f9b7714d-1166-410a-b143-874f27969db6", "comment":"yay"},{"volume.uuid":"efda9101-5209-11ec-b4ad-005056bbc3e8", "svm.uuid":"d0e6def5-5209-11ec-b4ad-005056bbc3e8", "uuid":"514c82a7-bff7-48e2-a13c-5337b09ed41e", "comment":"yay"}]}' -H "accept: application/hal+json"
# The response:
"job": {
  "uuid": "1e9a561f-520f-11ec-b4ad-005056bbc3e8",
      "href": "/api/cluster/jobs/1e9a561f-520f-11ec-b4ad-005056bbc3e8"
    "results": {
      "href": "/api/storage/volumes/*/snapshots?job_results_uuid=1e9a561f-520f-11ec-b4ad-005056bbc3e8"
# The Job:
curl -u admin:netapp1! -k -X GET --header 'Content-Type: application/json' --header 'Accept: application/json' 'https://<mgmt-ip>/api/storage/volumes/*/snapshots?job_results_uuid=1e9a561f-520f-11ec-b4ad-005056bbc3e8'
HTTP/1.1 200 OK
"records": [
    "volume": {
      "uuid": "e8815adb-5209-11ec-b4ad-005056bbc3e8",
      "name": "v1"
    "uuid": "f9b7714d-1166-410a-b143-874f27969db6",
    "svm": {
      "uuid": "d0e6def5-5209-11ec-b4ad-005056bbc3e8"
    "name": "s1",
    "comment": "yay"
    "volume": {
      "uuid": "efda9101-5209-11ec-b4ad-005056bbc3e8",
      "name": "v2"
    "uuid": "514c82a7-bff7-48e2-a13c-5337b09ed41e",
    "svm": {
    "name": "s1",
    "comment": "yay"
"num_records": 2
Deleting a Snapshot copy
The DELETE operation is used to delete a Snapshot copy.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/16f7008c-18fd-4a7d-8485-a0e290d9db7f" -H "accept: application/hal+json"
# The response:
Date: Wed, 13 Mar 2019 22:57:51 GMT
Content-Length: 189
"job": {
  "uuid": "6da1dfdd-45e3-11e9-8fc7-005056bbc848",
      "href": "/api/cluster/jobs/6da1dfdd-45e3-11e9-8fc7-005056bbc848"
# The Job:
HTTP/1.1 200 OK
Date: Wed, 13 Mar 2019 23:02:46 GMT
Content-Length: 243
"description": "DELETE /api/storage/volumes/0353dc05-405f-11e9-acb6-005056bbc848/snapshots/16f7008c-18fd-4a7d-8485-a0e290d9db7f",
"state": "success",
"code": 0
Deleting bulk Snapshot copies
The bulk DELETE operation is used to delete a Snapshot copies across volumes in a single request.
# The API:
# The call:
curl -X DELETE  "https://<mgmt-ip>/api/storage/volumes/*/snapshots" -d '{"records": [{"volume.uuid":"e8815adb-5209-11ec-b4ad-005056bbc3e8", "uuid":"f9b7714d-1166-410a-b143-874f27969db6"}, {"volume.uuid":"efda9101-5209-11ec-b4ad-005056bbc3e8", "uuid":"1d55c97a-25f3-4366-bfa8-9ea75c255469"}]}' -H "accept: application/hal+json"
# The response:
"job": {
  "uuid": "fe114ed7-520f-11ec-b4ad-005056bbc3e8",
      "href": "/api/cluster/jobs/fe114ed7-520f-11ec-b4ad-005056bbc3e8"
    "results": {
      "href": "/api/storage/volumes/*/snapshots?job_results_uuid=fe114ed7-520f-11ec-b4ad-005056bbc3e8"
# The Job:
HTTP/1.1 200 OK
curl -u admin:netapp1! -k -X GET --header 'Content-Type: application/json' --header 'Accept: application/json' 'https://<mgmt-ip>/api/storage/volumes/*/snapshots?job_results_uuid=fe114ed7-520f-11ec-b4ad-005056bbc3e8'
"records": [
"num_records": 0
