REST API reference
Web services security configuration
Update and retrieve the web services security configuration for each data SVM using these endpoints. This API is essential for maintaining secure communication and certificate management within your ONTAP environment.
You can use this API to update and retrieve the web services security configuration for each data SVM.
Updating the web services security configuration
The following fields can be used to update the web services security configuration:
  • certificate.uuid
  • client_enabled
  • ocsp_enabled When updating the certificate, the certificate UUID of an existing certificate known to ONTAP must be provided. The certificate must be of type "server".
A "client-ca" certificate must be installed on ONTAP to enable "client_enabled".
Retrieving the web services security configuration
# API:
GET /api/svm/svms/{svm.uuid}/web
# The call:
curl -X GET "https://<mgmt-ip>/api/svm/svms/3c1b259d-5789-a2eb-9301-10705682b34f/web" -H "accept: application/hal+json"
# The response:
"svm": {
  "uuid": "3c1b259d-5789-a2eb-9301-10705682b34f",
  "name": "svm2",
      "href": "/api/svm/svms/3c1b259d-5789-a2eb-9301-10705682b34f"
"certificate": {
  "uuid": "a3bb219d-4382-1fe0-9c06-1070568ea23d",
  "name": "cert1",
      "href": "/api/security/certificates/a3bb219d-4382-1fe0-9c06-1070568ea23d"
"client_enabled": false,
"ocsp_enabled": false,
    "href": "/api/svm/svms/3c1b259d-5789-a2eb-9301-10705682b34f/web"
# The API:
PATCH /api/svm/svms/{svm.uuid}/web
# The call:
curl -X PATCH "https://<mgmt-ip>/api/svm/svms/3c1b259d-5789-a2eb-9301-10705682b34f/web" -d '{ "certificate": {"uuid": "56da2799-13bc-2ae4-0c16-0c71244ea2ca" }}' -H "accept: application/hal+json"
# The response:
HTTP/1.1 202 Accepted
Date: Fri, 28 May 2021 09:36:43 GMT
Server: libzapid-httpd
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 189
Content-Type: application/hal+json
