      Cluster firmware history endpoint overview
Overview
Use this API to retrieve a history of firmware update requests. This API supports GET calls.
Retrieving history of firmware updates
The following example retrieves a history of firmware updates performed on the cluster. Note that if the fields=* parameter is not specified, only the job ID and start time are returned. Filters can be added on the fields to limit the results.
# The API:
GET /api/cluster/firmware/history
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/firmware/history/?fields=*" -H "accept: application/hal+json"
# The response:
200 OK
"records": [
    "start_time": "1970-01-01T00:02:03+00:00",
    "job": {
      "uuid": "adf700c2-b50e-11ea-a54f-005056bbec43"
    "node": {
      "uuid": "0530d6c1-8c6d-11e8-907f-00a0985a72ee",
      "name": "node1"
    "fw_file_name": "all_disk_fw.zip",
    "fw_update_state": "starting_workers",
    "end_time": "1970-01-01T00:07:36+00:00",
    "update_status": [
        "worker": {
          "node": {
            "name": "node1"
          "state": "failed",
          "error": {
            "message": "A firmware file already exists.",
            "code": 2228327
        "worker": {
          "node": {
            "uuid": "0530d6c1-8c6d-11e8-907f-00a0985a72ef",
            "name": "node2"
          "state": "complete",
          "error": {
            "message": "Success",
            "code": 0
        "href": "/api/cluster/firmware/history/1970-01-01T00%3A02%3A03-00%3A00/adf700c2-b50e-11ea-a54f-005056bbec43"
    "job": {
      "uuid": "f84adabe-b50e-11ea-a54f-005056bbec43"
    "node": {
      "name": "node1"
    "fw_file_name": "all_shelf_fw.zip",
    "fw_update_state": "completed",
    "update_status": [
        "worker": {
          "node": {
            "name": "node1"
          "state": "failed",
          "error": {
            "code": 2228327
        "worker": {
          "node": {
            "name": "node2"
          "error": {
            "code": 0
        "href": "/api/cluster/firmware/history/1970-01-01T00%3A02%3A03-00%3A00/f84adabe-b50e-11ea-a54f-005056bbec43"
"num_records": 2,
    "href": "/api/cluster/firmware/history/?fields=%2A"
