REST API reference
Delete a CIFS home directory search path
Removes a CIFS home directory search path when it's no longer needed, helping to manage and streamline your directory configurations.
HTTP method and endpoint
DELETE /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Introduced in
ONTAP 9.6
Usage notes
Deletes a CIFS home directory search path.
  • cifs server home-directory search-path remove
index
integer
path
True
Home directory search path index
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
