REST API reference
Delete an NVMe subsystem map
Deletes an NVMe subsystem map to manage and update your NVMe configurations effectively.
HTTP method and endpoint
DELETE /protocols/nvme/subsystem-maps/{subsystem.uuid}/{namespace.uuid}
Introduced in
ONTAP 9.6
  • vserver nvme subsystem map delete
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
namespace.uuid
string
path
True
The unique identifier of the NVMe namespace.
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[nvme_subsystem_map]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "anagrpid": "00103050h",
      "namespace": {
        "name": "/vol/vol1/namespace1",
        "node": {
          "name": "node1",
      "nsid": "00000001h",
      "subsystem": {
        "name": "subsystem1",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
72090019
The specified NVMe namespace is not mapped to the specified NVMe subsystem.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
namespace
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both.
_links
_links
name
string
The fully qualified path name of the NVMe namespace composed from the volume name, qtree name, and file name of the NVMe namespace. Valid in POST.
node
node
uuid
string
The unique identifier of the NVMe namespace. Valid in POST.
subsystem
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either subsystem.uuid, subsystem.name or both.
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
nvme_subsystem_map
An NVMe subsystem map is an association of an NVMe namespace with an NVMe subsystem. When an NVMe namespace is mapped to an NVMe subsystem, the NVMe subsystem's hosts are granted access to the NVMe namespace. The relationship between an NVMe subsystem and an NVMe namespace is one subsystem to many namespaces.
_links
_links
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
There is an added computational cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
namespace
namespace
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
subsystem
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
