REST API reference
Delete a Vscan On-Demand configuration
Deletes a Vscan On-Demand configuration to remove an existing scanning setup from your ONTAP environment.
HTTP method and endpoint
DELETE /protocols/vscan/{svm.uuid}/on-demand-policies/{name}
Introduced in
ONTAP 9.6
  • vserver vscan on-demand-task delete
name
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
