REST API reference
Deletes a snapmirror policy
example
<br/>
delete "/api/snapmirror/policies/510c15d4-f9e6-11e8-bdb5-0050568e12c2"
<br/> # learn more * [doc /snapmirror/policies](#docs-snapmirror-snapmirror_policies)
DELETE /snapmirror/policies/{uuid}
Introduced In: 9.6
Deletes a SnapMirror policy.
  • snapmirror policy delete
Example
DELETE "/api/snapmirror/policies/510c15d4-f9e6-11e8-bdb5-0050568e12c2"
uuid
string
path
True
Policy UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
