REST API reference
Retrieve application components
Retrieves application components to access the necessary details for connecting to and using the storage provisioned for an application. This is especially useful when you need to understand the underlying ONTAP storage elements associated with an application.
HTTP method and endpoint
GET /application/applications/{application.uuid}/components
Introduced in
ONTAP 9.6
Overview
The application component object exposes how to access an application. Most application interfaces abstract away the underlying ONTAP storage elements, but this interface exposes what is necessary to connect to and uses the storage that is provisioned for an application. See the application component model for a detailed description of each property.
Query examples
Queries are limited on this API. Most of the details are nested under the nfs_access, cifs_access, or san_access properties, but those properties do not support queries, and properties nested under those properties cannot be requested individually in the current release.
The following query returns all application components with names beginning in secondary.
GET /application/applications/{application.uuid}/components?name=secondary*
The following query returns all application components at the extreme storage service.
GET /application/applications/{application.uuid}/components?storage_service.name=extreme
Learn more
application.uuid
string
path
True
Application UUID
uuid
string
query
False
Filter by UUID
name
string
query
False
Filter by name
string
query
False
Filter by storage_service.name
storage_service.uuid
string
query
False
Filter by storage_service.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[application_component]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "application": {
        "name": "string",
        "uuid": "string"
      "backing_storage": {
        "luns": [
            "creation_timestamp": "string",
            "path": "string",
            "size": 0,
            "uuid": "string"
        "namespaces": [
            "name": "string",
            "size": 0,
            "uuid": "string"
        "volumes": [
            "name": "string",
            "size": 0,
            "uuid": "string"
      "cifs_access": [
            "type": "string",
            "uuid": "string"
          "ips": [
            "string"
          "path": "string",
          "permissions": [
              "access": "string",
              "user_or_group": "string"
          "server": {
            "name": "string"
          "share": {
            "name": "string"
      "file_system": "string",
      "host_management_url": "string",
      "host_name": "string",
      "name": "string",
      "nfs_access": [
            "type": "string",
            "uuid": "string"
          "export_policy": {
            "name": "string"
          "ips": [
            "string"
          "path": "string",
          "permissions": [
              "access": "string",
              "host": "string"
      "nvme_access": [
            "type": "string",
            "uuid": "string"
          "subsystem_map": {
            "anagrpid": "string",
            "nsid": "string",
            "subsystem": {
              "hosts": [
                  "nqn": "string"
              "name": "string",
              "uuid": "string"
      "protection_groups": [
          "name": "string",
          "rpo": {
            "local": {
              "description": "string",
              "name": "string"
            "remote": {
              "name": "string"
          "uuid": "string"
      "san_access": [
            "type": "string",
            "uuid": "string"
          "lun_mappings": [
              "fcp": [
                  "interface": {
                    "name": "fc_lif1",
                    "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
                    "wwpn": "20:00:00:50:56:b4:13:a8"
              "igroup": {
                "initiators": [
                  "string"
                "name": "string",
                "uuid": "string"
              "iscsi": [
                  "interface": {
                    "ip": {
                      "address": "10.10.10.7"
                    "name": "lif1",
                  "port": 3260
              "lun_id": 0
          "serial_number": "string"
      "storage_service": {
        "name": "string",
        "uuid": "string"
      "svm": {
        "name": "string",
        "uuid": "string"
      "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
application
_links
_links
name
string
Application name
uuid
string
The application UUID. Valid in URL.
application_lun_object
LUN object
creation_timestamp
string
LUN creation time
path
string
LUN path
size
integer
LUN size
uuid
string
LUN UUID
application_namespace_object
Namespace object
_links
_links
creation_timestamp
string
Namespace creation time
name
string
Namespace name
size
integer
Namespace size
uuid
string
Namespace UUID
application_volume_object
Volume object
creation_timestamp
string
Creation time
name
string
Name
size
integer
Size
uuid
string
UUID
application_backing_storage
luns
array[application_lun_object]
namespaces
array[application_namespace_object]
volumes
array[application_volume_object]
backing_storage
type
string
Backing storage type
uuid
string
Backing storage UUID
permissions
access
string
Access granted to the user or group
user_or_group
string
User or group
server
name
string
Server name
share
name
string
Share name
application_cifs_properties
backing_storage
backing_storage
ips
array[string]
path
string
Junction path
permissions
array[permissions]
server
server
share
share
export_policy
name
string
Export policy name
permissions
access
string
Access granted to the host
host
string
Host granted access
application_nfs_properties
backing_storage
backing_storage
export_policy
export_policy
ips
array[string]
path
string
Junction path
permissions
array[permissions]
self
self
self
self
hosts
_links
_links
nqn
string
Host
subsystem
_links
_links
hosts
array[hosts]
name
string
Subsystem name
uuid
string
Subsystem UUID
subsystem_map
Subsystem map object
anagrpid
string
Subsystem ANA group ID
nsid
string
Subsystem namespace ID
subsystem
subsystem
application_nvme_access
Application NVME access
backing_storage
backing_storage
is_clone
boolean
Clone
subsystem_map
subsystem_map
local
description
string
A detailed description of the local RPO. This includes details on the Snapshot copy schedule.
name
string
The local RPO of the component. This indicates how often component Snapshot copies are automatically created.
remote
description
string
A detailed description of the remote RPO.
name
string
The remote RPO of the component. A remote RPO of zero indicates that the component is synchronously replicated to another cluster.
rpo
local
local
remote
remote
application_protection_groups
name
string
Protection group name
rpo
rpo
uuid
string
Protection group UUID
fc_interface_reference
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
application_san_access_fcp_endpoint
A Fibre Channel Protocol (FCP) access endpoint for the LUN.
interface
An FC interface.
igroup
initiators
array[string]
name
string
Igroup name
uuid
string
Igroup UUID
ip
IP information
address
string
IPv4 or IPv6 address
interface
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
application_san_access_iscsi_endpoint
An iSCSI access endpoint for the LUN.
_links
_links
interface
interface
port
integer
The TCP port number of the iSCSI access endpoint.
application_lun_mapping_object
fcp
array[application_san_access_fcp_endpoint]
All possible Fibre Channel Protocol (FCP) access endpoints for the LUN.
igroup
igroup
iscsi
array[application_san_access_iscsi_endpoint]
All possible iSCSI access endpoints for the LUN.
lun_id
integer
LUN ID
backing_storage
backing_storage
is_clone
boolean
Clone
lun_mappings
array[application_lun_mapping_object]
serial_number
string
LUN serial number
storage_service
name
string
Storage service name
uuid
string
Storage service UUID
svm
name
string
SVM name
uuid
string
SVM UUID
Application component
_links
_links
application
application
backing_storage
cifs_access
array[application_cifs_properties]
file_system
string
Defines the type of file system that will be installed on this application component.
host_management_url
string
Host management URL
host_name
string
L2 Host FQDN
name
string
Application component name
nfs_access
array[application_nfs_properties]
nvme_access
array[application_nvme_access]
protection_groups
array[application_protection_groups]
san_access
array[application_san_access]
storage_service
storage_service
svm
svm
uuid
string
The application component UUID. Valid in URL.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
