Retrieve historical performance metrics of a consistency group
Accesses historical performance and capacity metrics for a consistency group. Use this information to analyze past performance trends and manage resource capacity effectively.
HTTP method and endpoint
GET /application/consistency-groups/{consistency_group.uuid}/metrics
Introduced in
ONTAP 9.13
Usage notes
Retrieves historical performance and capacity metrics for a consistency group.
available_space |
integer |
query |
False |
Filter by available_space |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
throughput.other |
integer |
query |
False |
Filter by throughput.other |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
throughput.total |
integer |
query |
False |
Filter by throughput.total |
duration |
string |
query |
False |
Filter by duration |
latency.read |
integer |
query |
False |
Filter by latency.read |
latency.other |
integer |
query |
False |
Filter by latency.other |
latency.write |
integer |
query |
False |
Filter by latency.write |
latency.total |
integer |
query |
False |
Filter by latency.total |
used_space |
integer |
query |
False |
Filter by used_space |
size |
integer |
query |
False |
Filter by size |
timestamp |
string |
query |
False |
Filter by timestamp |
status |
string |
query |
False |
Filter by status |
iops.read |
integer |
query |
False |
Filter by iops.read |
iops.other |
integer |
query |
False |
Filter by iops.other |
iops.write |
integer |
query |
False |
Filter by iops.write |
iops.total |
integer |
query |
False |
Filter by iops.total |
consistency_group.uuid |
string |
path |
True |
Unique identifier of the consistency group. |
interval |
string |
query |
False |
The time range for the data. Examples can be 1h, 1d, 1w, 1m, 1y. The period for each time range is as follows:
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Order results by specified fields and optional [asc/desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"records": [
"available_space": 4096,
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"size": 4096,
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 11:20:13 +0000",
"used_space": 4096
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
The round trip latency observed at the storage object, in microseconds.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
records
Performance and capacity numbers, such as, IOPS, latency, throughput, used space, and available space.
_links |
available_space |
integer |
The total space available in the consistency group, in bytes. |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency observed at the storage object, in microseconds. |
size |
integer |
The total size of the consistency group, in bytes. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance and capacity data. |
used_space |
integer |
The total space used in the consistency group, in bytes. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
