Retrieve a cluster peer instance
Retrieves details of a specific cluster peer instance, helping you understand its configuration and status within your network.
HTTP method and endpoint
GET /cluster/peers/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific cluster peer instance.
uuid |
string |
path |
True |
Cluster peer relationship UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
authentication |
encryption |
initial_allowed_svms |
array[initial_allowed_svms] |
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship. |
ip_address |
string |
IPv4 or IPv6 address |
ipspace |
The IPspace of the local intercluster LIFs. |
name |
string |
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster, or a temporary name might be autogenerated for anonymous cluster peer offers. |
peer_applications |
array[string] |
Peering applications against which allowed SVMs are configured. |
remote |
status |
uuid |
string |
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship. |
version |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes. |
"interfaces": {
"href": "/api/resourcelink"
"authentication": {
"expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
"in_use": "string",
"passphrase": "string",
"state": "string"
"encryption": {
"proposed": "string",
"state": "string"
"initial_allowed_svms": [
"name": "svm1",
"ip_address": "10.10.10.7",
"ipspace": {
"name": "exchange",
"name": "cluster2",
"peer_applications": [
"snapmirror",
"flexcache"
"remote": {
"ip_addresses": [
"10.10.10.7"
"name": "cluster2",
"serial_number": "4048820-60-9"
"status": {
"state": "available",
"update_time": "2017-01-25 11:20:13 +0000"
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"version": {
"full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
"generation": 9,
"major": 4,
"minor": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
interfaces |
self |
authentication
expiry_time |
string |
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour. |
generate_passphrase |
boolean |
Auto generate a passphrase when true. |
in_use |
string |
passphrase |
string |
A password to authenticate the cluster peer relationship. |
state |
string |
encryption
proposed |
string |
state |
string |
_links
self |
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
interfaces
ip_address |
string |
local_network
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node.
broadcast_domain |
string |
Broadcast domain that is in use within the IPspace. |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
interfaces |
array[interfaces] |
netmask |
string |
IPv4 mask or netmask length. |
remote
ip_addresses |
array[string] |
The IPv4 addresses, IPv6 addresses, or hostnames of the peers. |
name |
string |
The name of the remote cluster. |
serial_number |
string |
The serial number of the remote cluster. |
status
state |
string |
update_time |
string |
The last time the state was updated. |
version
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
