REST API reference
Retrieve a group membership cache setting for an SVM
Accesses a group membership cache setting for an SVM to view its current configuration.
HTTP method and endpoint
GET /name-services/cache/group-membership/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves a group-membership cache setting for a given SVM.
  • vserver services name-service cache group-membership settings show
svm.uuid
string
path
True
SVM UUID.
enabled
boolean
query
False
Filter by enabled
svm.name
string
query
False
Filter by svm.name
ttl
string
query
False
Filter by ttl
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
enabled
boolean
Specifies whether or not the cache is enabled.
svm
svm
ttl
string
Specifies Time to Live for list of group members, in ISO 8601 format.
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
  "ttl": "PT2H30M"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
