REST API reference
Retrieve broadcast domains for the entire cluster
Retrieves a collection of broadcast domains across the entire cluster to manage network configurations effectively.
HTTP method and endpoint
GET /network/ethernet/broadcast-domains
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of broadcast domains for the entire cluster.
  • network port broadcast-domain show
name
string
query
False
Filter by name
uuid
string
query
False
Filter by uuid
ports.node.name
string
query
False
Filter by ports.node.name
ports.name
string
query
False
Filter by ports.name
ports.uuid
string
query
False
Filter by ports.uuid
mtu
integer
query
False
Filter by mtu
  • Min value: 68
ipspace.name
string
query
False
Filter by ipspace.name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Min value: 0
  • Default value: 15
  • Max value: 120
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[broadcast_domain]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "ipspace": {
        "name": "exchange",
      "mtu": 1500,
      "name": "bd1",
      "ports": [
          "name": "e1b",
          "node": {
            "name": "node1"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
node
name
string
Name of node on which the port is located.
ports
Port UUID along with readable names
_links
_links
name
string
node
node
uuid
string
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
_links
_links
ipspace
ipspace
mtu
integer
Maximum transmission unit, largest packet size on this network
name
string
Name of the broadcast domain, scoped to its IPspace
ports
array[ports]
Ports that belong to the broadcast domain
uuid
string
Broadcast domain UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
