Retrieve unapplied group policy objects for all SVMs
Retrieves group policy objects that have not been applied across all SVMs. This helps you identify and manage policies that need attention or updates.
HTTP method and endpoint
GET /protocols/cifs/group-policies
Introduced in
ONTAP 9.12
Usage notes
Retrieves group policy objects that are yet to be applied for all SVMs.
Related ONTAP commands
vserver cifs group-policy show-defined
name |
string |
query |
False |
Filter by name
extensions |
string |
query |
False |
Filter by extensions |
central_access_policy_settings |
string |
query |
False |
Filter by central_access_policy_settings |
registry_settings.branchcache.supported_hash_version |
string |
query |
False |
Filter by registry_settings.branchcache.supported_hash_version |
registry_settings.branchcache.hash_publication_mode |
string |
query |
False |
Filter by registry_settings.branchcache.hash_publication_mode |
registry_settings.refresh_time_random_offset |
string |
query |
False |
Filter by registry_settings.refresh_time_random_offset |
registry_settings.refresh_time_interval |
string |
query |
False |
Filter by registry_settings.refresh_time_interval |
link |
string |
query |
False |
Filter by link |
central_access_policy_staging_audit_type |
string |
query |
False |
Filter by central_access_policy_staging_audit_type |
uuid |
string |
query |
False |
Filter by uuid |
security_settings.restricted_groups |
string |
query |
False |
Filter by security_settings.restricted_groups |
security_settings.event_audit_settings.logon_type |
string |
query |
False |
Filter by security_settings.event_audit_settings.logon_type |
security_settings.event_audit_settings.object_access_type |
string |
query |
False |
Filter by security_settings.event_audit_settings.object_access_type |
security_settings.kerberos.max_clock_skew |
string |
query |
False |
Filter by security_settings.kerberos.max_clock_skew |
security_settings.kerberos.max_renew_age |
string |
query |
False |
Filter by security_settings.kerberos.max_renew_age |
security_settings.kerberos.max_ticket_age |
string |
query |
False |
Filter by security_settings.kerberos.max_ticket_age |
security_settings.files_or_folders |
string |
query |
False |
Filter by security_settings.files_or_folders |
security_settings.privilege_rights.change_notify_users |
string |
query |
False |
Filter by security_settings.privilege_rights.change_notify_users |
security_settings.privilege_rights.security_privilege_users |
string |
query |
False |
Filter by security_settings.privilege_rights.security_privilege_users |
security_settings.privilege_rights.take_ownership_users |
string |
query |
False |
Filter by security_settings.privilege_rights.take_ownership_users |
security_settings.restrict_anonymous.anonymous_access_to_shares_and_named_pipes_restricted |
boolean |
query |
False |
Filter by security_settings.restrict_anonymous.anonymous_access_to_shares_and_named_pipes_restricted |
security_settings.restrict_anonymous.no_enumeration_of_sam_accounts |
boolean |
query |
False |
Filter by security_settings.restrict_anonymous.no_enumeration_of_sam_accounts |
security_settings.restrict_anonymous.no_enumeration_of_sam_accounts_and_shares |
boolean |
query |
False |
Filter by security_settings.restrict_anonymous.no_enumeration_of_sam_accounts_and_shares |
security_settings.restrict_anonymous.combined_restriction_for_anonymous_user |
string |
query |
False |
Filter by security_settings.restrict_anonymous.combined_restriction_for_anonymous_user |
security_settings.event_log_settings.max_size |
integer |
query |
False |
Filter by security_settings.event_log_settings.max_size |
security_settings.event_log_settings.retention_method |
string |
query |
False |
Filter by security_settings.event_log_settings.retention_method |
security_settings.registry_values.signing_required |
boolean |
query |
False |
Filter by security_settings.registry_values.signing_required |
version |
integer |
query |
False |
Filter by version |
enabled |
boolean |
query |
False |
Filter by enabled |
index |
integer |
query |
False |
Filter by index |
ldap_path |
string |
query |
False |
Filter by ldap_path |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
file_system_path |
string |
query |
False |
Filter by file_system_path |
fields |
array[string] |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of central access rules. |
records |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"svm": {
"name": "svm1",
"to_be_applied": {
"access_policies": [
"create_time": "2018-01-01 16:00:00 +0000",
"description": "policy #1",
"member_rules": [
"r1",
"r2"
"name": "p1",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
"update_time": "2018-01-01 16:00:00 +0000"
"access_rules": [
"current_permission": "O:SYG:SYD:AR(A;;FA;;;WD)",
"description": "rule #1",
"name": "p1",
"proposed_permission": "O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY)",
"resource_criteria": "department",
"svm": {
"name": "svm1",
"objects": [
"central_access_policy_settings": [
"p1",
"p2"
"central_access_policy_staging_audit_type": "none",
"extensions": [
"audit",
"security"
"file_system_path": "\\test.com\\SysVol\\test.com\\policies\\{42474212-3f9d-4489-ae01-6fcf4f805d4c}",
"index": 1,
"ldap_path": "cn={42474212-3f9d-4489-ae01-6fcf4f805d4c},cn=policies,cn=system,DC=TEST,DC=COM",
"link": "domain",
"name": "test_policy",
"registry_settings": {
"branchcache": {
"hash_publication_mode": "disabled",
"supported_hash_version": "version1"
"refresh_time_interval": "P15M",
"refresh_time_random_offset": "P1D"
"security_settings": {
"event_audit_settings": {
"logon_type": "failure",
"object_access_type": "failure"
"event_log_settings": {
"max_size": 2048,
"retention_method": "do_not_overwrite"
"files_or_folders": [
"/vol1/home",
"/vol1/dir1"
"kerberos": {
"max_clock_skew": "P15M",
"max_renew_age": "P2D",
"max_ticket_age": "P24H"
"privilege_rights": {
"change_notify_users": [
"usr1",
"usr2"
"security_privilege_users": [
"usr1",
"usr2"
"take_ownership_users": [
"usr1",
"usr2"
"restrict_anonymous": {
"combined_restriction_for_anonymous_user": "no_access"
"restricted_groups": [
"test_grp1",
"test_grp2"
"svm": {
"name": "svm1",
"uuid": "42474212-3f9d-4489-ae01-6fcf4f805d4c",
"version": 7
"group_name": "test_group",
"link": "domain",
"members": [
"DOMAIN/test_user",
"DOMAIN/user2"
"memberships": [
"DOMAIN/AdministratorGrp",
"DOMAIN/deptMark"
"policy_name": "test_policy",
"svm": {
"name": "svm1",
"version": 7
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
svm
Will not be populated for objects that are yet to be applied.
_links |
name |
string |
uuid |
string |
group_policy_object_central_access_policy
create_time |
string |
Policy creation timestamp. |
description |
string |
Description about the policy. |
member_rules |
array[string] |
Names of all central access rules applied to members. |
name |
string |
sid |
string |
Security ID, unique identifier of the central policy. |
svm |
Will not be populated for objects that are yet to be applied. |
update_time |
string |
Last policy modification timestamp. |
group_policy_object_central_access_rule
create_time |
string |
current_permission |
string |
Effective security policy in security descriptor definition language format. |
description |
string |
name |
string |
proposed_permission |
string |
Proposed security policy in security descriptor definition language format. |
resource_criteria |
string |
Criteria to scope resources for which access rules apply. |
svm |
update_time |
string |
group_policy_object_branchcache
string |
Hash publication mode. |
string |
Hash version. |
group_policy_object_registry_setting
branchcache |
string |
Refresh time interval in ISO-8601 format. |
string |
Random offset in ISO-8601 format. |
group_policy_object_event_audit
logon_type |
string |
Type of logon event to be audited. |
string |
Type of object access to be audited. |
group_policy_object_event_log
max_size |
integer |
Maximum size of security log, in kilobytes. |
retention_method |
string |
Audit log retention method. |
group_policy_object_kerberos
max_clock_skew |
string |
Kerberos clock skew in ISO-8601 format. |
max_renew_age |
string |
Kerberos max renew age in ISO-8601 format. |
max_ticket_age |
string |
Kerberos max ticket age in ISO-8601 format. |
group_policy_object_privilege_right
array[string] |
Users with traversing bypass privileges. |
array[string] |
Users with security privileges. |
array[string] |
Users who can take ownership of securable objects. |
group_policy_object_registry_value
signing_required |
boolean |
SMB signing required. |
group_policy_object_restrict_anonymous
boolean |
Restrict anonymous access to shares and named pipes. |
string |
Combined restriction for anonymous user. |
boolean |
No enumeration of SAM accounts. |
boolean |
No enumeration of SAM accounts and shares. |
group_policy_object_security_setting
event_audit_settings |
event_log_settings |
files_or_folders |
array[string] |
Files/Directories for file security. |
kerberos |
privilege_rights |
registry_values |
restrict_anonymous |
restricted_groups |
array[string] |
List of restricted groups. |
group_policy_object
array[string] |
List of central access policies. |
string |
Types of events to be audited. |
enabled |
boolean |
Specifies whether group policies are enabled for the SVM. |
extensions |
array[string] |
List of extensions. |
file_system_path |
string |
File system path. |
index |
integer |
Group policy object index. |
ldap_path |
string |
LDAP path to the GPO. |
link |
string |
Link info. |
name |
string |
registry_settings |
security_settings |
svm |
uuid |
string |
Policy UUID. |
version |
integer |
Group policy object version. |
group_policy_object_restricted_group
group_name |
string |
link |
string |
Link info. |
members |
array[string] |
Members of the group. |
memberships |
array[string] |
Group is member of Group/OU. |
policy_name |
string |
svm |
version |
integer |
to_be_applied
access_policies |
access_rules |
objects |
array[group_policy_object] |
restricted_groups |
policies_and_rules_to_be_applied
svm |
to_be_applied |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
