REST API reference
Retrieve local groups for all SVMs
Retrieves local groups for all SVMs, offering insights into group configurations across your storage virtual machines.
HTTP method and endpoint
GET /protocols/cifs/local-groups
Introduced in
ONTAP 9.9
Usage notes
Retrieves the local groups for all of the SVMs.
Advanced properties
  • members
  • vserver cifs users-and-groups local-group show
  • vserver cifs users-and-groups local-group show-members
name
string
query
False
Filter by name
  • minLength: 1
sid
string
query
False
Filter by sid
  • Introduced in: 9.10
members.name
string
query
False
Filter by members.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
description
string
query
False
Filter by description
  • maxLength: 256
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of local group records.
records
array[local_cifs_group]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "description": "This is a local group",
      "members": [
          "name": "string"
      "name": "SMB_SERVER01\\group",
      "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
members
name
string
Local user, Active Directory user, or Active Directory group which is a member of the specified local group.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
local_cifs_group
_links
_links
description
string
Description for the local group.
members
array[members]
name
string
Local group name. The maximum supported length of a group name is 256 characters.
sid
string
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
