REST API reference
Retrieve a shadow copy
Retrieves a shadow copy to view the available shadow copy details for your CIFS shares.
HTTP method and endpoint
GET /protocols/cifs/shadow-copies/{client_uuid}
Introduced in
ONTAP 9.11
Usage notes
Retrieves a Shadowcopy
  • vserver cifs shadowcopy show-shares
client_uuid
string
path
True
client shadowcopy ID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
client_uuid
string
The universally-unique identifier of the client's shadow copy.
destination_dir
string
The path of the destination directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume.
files
array[string]
The list of files to shadow copy in the share. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the share.
shadowcopy_set
shadowcopy_set
share
share
source_dir
string
The path of the source directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume.
svm
svm
uuid
string
The universally-unique identifier of the storage's shadow copy.
volume
volume
The name of the volume where the source and destination directories reside.
with_content
boolean
Specifies what needs to be restored. False specifies the directory only. True indicates the directory and its content.
      "href": "/api/resourcelink"
  "client_uuid": "abc13450-1f19-40ba-9b82-ebf277517e7e",
  "destination_dir": "/dir2",
  "files": [
    "/vhd1",
    "/vhd2"
  "shadowcopy_set": {
    "uuid": "5f4e19f3-5e2d-11ec-8766-005056a7c134"
  "share": {
    "name": "sh1"
  "source_dir": "/dir1",
  "svm": {
    "name": "svm1",
  "uuid": "fef32805-1f19-40ba-9b82-ebf277517e7e",
  "volume": {
    "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
self
shadowcopy_set
_links
self_link
uuid
string
share
_links
_links
name
string
Share name
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
