REST API reference
Retrieves an nvme subsystem map
  • anagrpid # related ontap commands
  • vserver nvme subsystem map show # learn more
  • [doc /protocols/nvme/subsystem-maps](#docs-nvme-protocols_nvme_subsystem-maps)
GET /protocols/nvme/subsystem-maps/{subsystem.uuid}/{namespace.uuid}
Introduced In: 9.6
Retrieves an NVMe subsystem map.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • anagrpid
subsystem.uuid
string
path
True
The unique identifier of the NVMe subsystem.
namespace.uuid
string
path
True
The unique identifier of the NVMe namespace.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
There is an added computational cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
namespace
namespace
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both.
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
subsystem
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either subsystem.uuid, subsystem.name or both.
svm
svm
      "href": "/api/resourcelink"
  "anagrpid": "00103050h",
  "namespace": {
    "name": "/vol/vol1/namespace1",
    "node": {
      "name": "node1",
  "nsid": "00000001h",
  "subsystem": {
    "name": "subsystem1",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
72090019
The specified NVMe namespace is not mapped to the specified NVMe subsystem.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
_links
_links
name
string
uuid
string
namespace
_links
_links
name
string
The fully qualified path name of the NVMe namespace composed from the volume name, qtree name, and file name of the NVMe namespace. Valid in POST.
node
node
uuid
string
The unique identifier of the NVMe namespace. Valid in POST.
subsystem
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
