Retrieve a specific resource tag
GET /resource-tags/{value}
Introduced In: 9.13
Retrieves a specific resource tag.
value |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
num_resources |
integer |
The number of resources that are currently using this tag. |
value |
string |
A key:value formatted string representing the tag's name. |
"value": "team:accounting"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
