REST API reference
Retrieve a collection of aggregates for an entire cluster
Accesses the collection of aggregates for an entire cluster to review the configuration and state of storage resources within your ONTAP environment.
HTTP method and endpoint
GET /storage/aggregates
Introduced in
ONTAP 9.6
Usage notes
Retrieves the collection of aggregates for the entire cluster.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • metric.*
  • space.block_storage.inactive_user_data
  • space.block_storage.inactive_user_data_percent
  • space.footprint
  • is_spare_low
  • statistics.*
  • storage aggregate show
recommend
boolean
query
False
If set to 'true', it queries the system for the recommended optimal layout for creating new aggregates. The default setting is 'false'.
show_spares
boolean
query
False
If set to 'true', the spares object is returned instead of records to show the spare groups in the cluster. The default setting is 'false'.
flash_pool_eligible
boolean
query
False
If set to 'true' along with show_spares, the spares object is restricted to return spare groups that are compatible with whole disk based flash pool creation. The default setting is 'false'.
  • Introduced in: 9.12
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
  • Introduced in: 9.7
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.status
string
query
False
Filter by statistics.status
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.other
integer
query
False
Filter by statistics.throughput_raw.other
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
data_encryption.drive_protection_enabled
boolean
query
False
Filter by data_encryption.drive_protection_enabled
data_encryption.software_encryption_enabled
boolean
query
False
Filter by data_encryption.software_encryption_enabled
sidl_enabled
boolean
query
False
Filter by sidl_enabled
  • Introduced in: 9.11
inactive_data_reporting.enabled
boolean
query
False
Filter by inactive_data_reporting.enabled
  • Introduced in: 9.8
inactive_data_reporting.start_time
string
query
False
Filter by inactive_data_reporting.start_time
block_storage.storage_type
string
query
False
Filter by block_storage.storage_type
block_storage.plexes.name
string
query
False
Filter by block_storage.plexes.name
block_storage.hybrid_cache.raid_size
integer
query
False
Filter by block_storage.hybrid_cache.raid_size
block_storage.hybrid_cache.raid_type
string
query
False
Filter by block_storage.hybrid_cache.raid_type
block_storage.hybrid_cache.simulated_raid_groups.added_parity_disk_count
integer
query
False
Filter by block_storage.hybrid_cache.simulated_raid_groups.added_parity_disk_count
block_storage.hybrid_cache.simulated_raid_groups.name
string
query
False
Filter by block_storage.hybrid_cache.simulated_raid_groups.name
block_storage.hybrid_cache.simulated_raid_groups.existing_data_disk_count
integer
query
False
Filter by block_storage.hybrid_cache.simulated_raid_groups.existing_data_disk_count
block_storage.hybrid_cache.simulated_raid_groups.usable_size
integer
query
False
Filter by block_storage.hybrid_cache.simulated_raid_groups.usable_size
block_storage.hybrid_cache.simulated_raid_groups.existing_parity_disk_count
integer
query
False
Filter by block_storage.hybrid_cache.simulated_raid_groups.existing_parity_disk_count
block_storage.hybrid_cache.simulated_raid_groups.added_data_disk_count
integer
query
False
Filter by block_storage.hybrid_cache.simulated_raid_groups.added_data_disk_count
block_storage.hybrid_cache.simulated_raid_groups.is_partition
boolean
query
False
Filter by block_storage.hybrid_cache.simulated_raid_groups.is_partition
block_storage.hybrid_cache.enabled
boolean
query
False
Filter by block_storage.hybrid_cache.enabled
block_storage.hybrid_cache.size
integer
query
False
Filter by block_storage.hybrid_cache.size
block_storage.hybrid_cache.storage_pools.storage_pool.uuid
string
query
False
Filter by block_storage.hybrid_cache.storage_pools.storage_pool.uuid
block_storage.hybrid_cache.storage_pools.storage_pool.name
string
query
False
Filter by block_storage.hybrid_cache.storage_pools.storage_pool.name
block_storage.hybrid_cache.storage_pools.allocation_units_count
integer
query
False
Filter by block_storage.hybrid_cache.storage_pools.allocation_units_count
block_storage.hybrid_cache.used
integer
query
False
Filter by block_storage.hybrid_cache.used
block_storage.hybrid_cache.disk_count
integer
query
False
Filter by block_storage.hybrid_cache.disk_count
block_storage.hybrid_cache.disk_type
string
query
False
Filter by block_storage.hybrid_cache.disk_type
block_storage.mirror.state
string
query
False
Filter by block_storage.mirror.state
block_storage.mirror.enabled
boolean
query
False
Filter by block_storage.mirror.enabled
block_storage.primary.disk_type
string
query
False
Filter by block_storage.primary.disk_type
block_storage.primary.disk_class
string
query
False
Filter by block_storage.primary.disk_class
block_storage.primary.disk_count
integer
query
False
Filter by block_storage.primary.disk_count
block_storage.primary.simulated_raid_groups.added_data_disk_count
integer
query
False
Filter by block_storage.primary.simulated_raid_groups.added_data_disk_count
block_storage.primary.simulated_raid_groups.is_partition
boolean
query
False
Filter by block_storage.primary.simulated_raid_groups.is_partition
  • Introduced in: 9.10
block_storage.primary.simulated_raid_groups.existing_parity_disk_count
integer
query
False
Filter by block_storage.primary.simulated_raid_groups.existing_parity_disk_count
block_storage.primary.simulated_raid_groups.existing_data_disk_count
integer
query
False
Filter by block_storage.primary.simulated_raid_groups.existing_data_disk_count
block_storage.primary.simulated_raid_groups.data_disk_count
integer
query
False
Filter by block_storage.primary.simulated_raid_groups.data_disk_count
block_storage.primary.simulated_raid_groups.added_parity_disk_count
integer
query
False
Filter by block_storage.primary.simulated_raid_groups.added_parity_disk_count
block_storage.primary.simulated_raid_groups.parity_disk_count
integer
query
False
Filter by block_storage.primary.simulated_raid_groups.parity_disk_count
block_storage.primary.simulated_raid_groups.usable_size
integer
query
False
Filter by block_storage.primary.simulated_raid_groups.usable_size
block_storage.primary.simulated_raid_groups.name
string
query
False
Filter by block_storage.primary.simulated_raid_groups.name
block_storage.primary.simulated_raid_groups.raid_type
string
query
False
Filter by block_storage.primary.simulated_raid_groups.raid_type
block_storage.primary.raid_type
string
query
False
Filter by block_storage.primary.raid_type
block_storage.primary.raid_size
integer
query
False
Filter by block_storage.primary.raid_size
block_storage.primary.checksum_style
string
query
False
Filter by block_storage.primary.checksum_style
block_storage.uses_partitions
boolean
query
False
Filter by block_storage.uses_partitions
volume-count
integer
query
False
Filter by volume-count
_tags
string
query
False
Filter by _tags
  • Introduced in: 9.13
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.status
string
query
False
Filter by metric.status
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.other
integer
query
False
Filter by metric.throughput.other
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.duration
string
query
False
Filter by metric.duration
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.latency.write
integer
query
False
Filter by metric.latency.write
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.iops.write
integer
query
False
Filter by metric.iops.write
metric.iops.total
integer
query
False
Filter by metric.iops.total
home_node.uuid
string
query
False
Filter by home_node.uuid
home_node.name
string
query
False
Filter by home_node.name
dr_home_node.name
string
query
False
Filter by dr_home_node.name
dr_home_node.uuid
string
query
False
Filter by dr_home_node.uuid
recommendation_spares.is_partition
boolean
query
False
Filter by recommendation_spares.is_partition
recommendation_spares.disk_class
string
query
False
Filter by recommendation_spares.disk_class
recommendation_spares.disk_type
string
query
False
Filter by recommendation_spares.disk_type
recommendation_spares.checksum_style
string
query
False
Filter by recommendation_spares.checksum_style
recommendation_spares.syncmirror_pool
string
query
False
Filter by recommendation_spares.syncmirror_pool
recommendation_spares.size
integer
query
False
Filter by recommendation_spares.size
recommendation_spares.usable
integer
query
False
Filter by recommendation_spares.usable
recommendation_spares.node.uuid
string
query
False
Filter by recommendation_spares.node.uuid
recommendation_spares.node.name
string
query
False
Filter by recommendation_spares.node.name
recommendation_spares.layout_requirements.raid_type
string
query
False
Filter by recommendation_spares.layout_requirements.raid_type
recommendation_spares.layout_requirements.default
boolean
query
False
Filter by recommendation_spares.layout_requirements.default
recommendation_spares.layout_requirements.raid_group.max
integer
query
False
Filter by recommendation_spares.layout_requirements.raid_group.max
recommendation_spares.layout_requirements.raid_group.default
integer
query
False
Filter by recommendation_spares.layout_requirements.raid_group.default
recommendation_spares.layout_requirements.raid_group.min
integer
query
False
Filter by recommendation_spares.layout_requirements.raid_group.min
recommendation_spares.layout_requirements.aggregate_min_disks
integer
query
False
Filter by recommendation_spares.layout_requirements.aggregate_min_disks
recommendation_spares.total
integer
query
False
Filter by recommendation_spares.total
space.cloud_storage.used
integer
query
False
Filter by space.cloud_storage.used
space.footprint
integer
query
False
Filter by space.footprint
space.efficiency.logical_used
integer
query
False
Filter by space.efficiency.logical_used
space.efficiency.cross_volume_inline_dedupe
boolean
query
False
Filter by space.efficiency.cross_volume_inline_dedupe
space.efficiency.cross_volume_background_dedupe
boolean
query
False
Filter by space.efficiency.cross_volume_background_dedupe
space.efficiency.ratio
number
query
False
Filter by space.efficiency.ratio
space.efficiency.savings
integer
query
False
Filter by space.efficiency.savings
space.efficiency.cross_volume_dedupe_savings
boolean
query
False
Filter by space.efficiency.cross_volume_dedupe_savings
space.efficiency.auto_adaptive_compression_savings
boolean
query
False
Filter by space.efficiency.auto_adaptive_compression_savings
space.efficiency_without_snapshots_flexclones.logical_used
integer
query
False
Filter by space.efficiency_without_snapshots_flexclones.logical_used
  • Introduced in: 9.9
space.efficiency_without_snapshots_flexclones.savings
integer
query
False
Filter by space.efficiency_without_snapshots_flexclones.savings
space.efficiency_without_snapshots_flexclones.ratio
number
query
False
Filter by space.efficiency_without_snapshots_flexclones.ratio
space.block_storage.available
integer
query
False
Filter by space.block_storage.available
space.block_storage.size
integer
query
False
Filter by space.block_storage.size
space.block_storage.full_threshold_percent
integer
query
False
Filter by space.block_storage.full_threshold_percent
space.block_storage.volume_deduplication_space_saved
integer
query
False
Filter by space.block_storage.volume_deduplication_space_saved
space.block_storage.volume_deduplication_space_saved_percent
integer
query
False
Filter by space.block_storage.volume_deduplication_space_saved_percent
space.block_storage.data_compaction_space_saved
integer
query
False
Filter by space.block_storage.data_compaction_space_saved
space.block_storage.data_compaction_space_saved_percent
integer
query
False
Filter by space.block_storage.data_compaction_space_saved_percent
space.block_storage.data_compacted_count
integer
query
False
Filter by space.block_storage.data_compacted_count
space.block_storage.used_including_snapshot_reserve_percent
integer
query
False
Filter by space.block_storage.used_including_snapshot_reserve_percent
integer
query
False
integer
query
False
Filter by space.block_storage.inactive_user_data_percent
integer
query
False
space.block_storage.volume_footprints_percent
integer
query
False
Filter by space.block_storage.volume_footprints_percent
integer
query
False
space.block_storage.physical_used_percent
integer
query
False
Filter by space.block_storage.physical_used_percent
space.block_storage.aggregate_metadata
integer
query
False
Filter by space.block_storage.aggregate_metadata
space.block_storage.aggregate_metadata_percent
integer
query
False
Filter by space.block_storage.aggregate_metadata_percent
space.block_storage.volume_deduplication_shared_count
integer
query
False
Filter by space.block_storage.volume_deduplication_shared_count
space.block_storage.used_percent
integer
query
False
Filter by space.block_storage.used_percent
integer
query
False
space.snapshot.reserve_percent
integer
query
False
Filter by space.snapshot.reserve_percent
space.snapshot.used_percent
integer
query
False
Filter by space.snapshot.used_percent
space.snapshot.total
integer
query
False
Filter by space.snapshot.total
space.snapshot.available
integer
query
False
Filter by space.snapshot.available
space.snapshot.used
integer
query
False
space.efficiency_without_snapshots.logical_used
integer
query
False
Filter by space.efficiency_without_snapshots.logical_used
space.efficiency_without_snapshots.savings
integer
query
False
Filter by space.efficiency_without_snapshots.savings
space.efficiency_without_snapshots.ratio
number
query
False
Filter by space.efficiency_without_snapshots.ratio
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
snaplock_type
string
query
False
Filter by snaplock_type
name
string
query
False
Filter by name
create_time
string
query
False
Filter by create_time
state
string
query
False
Filter by state
uuid
string
query
False
Filter by uuid
inode_attributes.max_files_used
integer
query
False
Filter by inode_attributes.max_files_used
inode_attributes.files_total
integer
query
False
Filter by inode_attributes.files_total
inode_attributes.used_percent
integer
query
False
Filter by inode_attributes.used_percent
  • Max value: 100
  • Min value: 0
inode_attributes.version
integer
query
False
Filter by inode_attributes.version
inode_attributes.file_public_capacity
integer
query
False
Filter by inode_attributes.file_public_capacity
inode_attributes.max_files_possible
integer
query
False
Filter by inode_attributes.max_files_possible
inode_attributes.max_files_available
integer
query
False
Filter by inode_attributes.max_files_available
inode_attributes.file_private_capacity
integer
query
False
Filter by inode_attributes.file_private_capacity
inode_attributes.files_private_used
integer
query
False
Filter by inode_attributes.files_private_used
inode_attributes.files_used
integer
query
False
Filter by inode_attributes.files_used
is_spare_low
boolean
query
False
Filter by is_spare_low
snapshot.max_files_available
integer
query
False
Filter by snapshot.max_files_available
snapshot.files_total
integer
query
False
Filter by snapshot.files_total
snapshot.max_files_used
integer
query
False
Filter by snapshot.max_files_used
snapshot.files_used
integer
query
False
Filter by snapshot.files_used
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[aggregate]
spares
array[aggregate_spare]
warnings
array[aggregate_warning]
List of warnings and remediation advice for the aggregate recommendation.
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
  "num_records": 1,
  "records": [
      "_tags": [
        "team:csi",
        "environment:test"
      "block_storage": {
        "hybrid_cache": {
          "disk_count": 6,
          "disk_type": "string",
          "raid_size": 24,
          "raid_type": "string",
          "simulated_raid_groups": [
              "name": "string"
          "size": 1612709888,
          "storage_pools": [
              "storage_pool": {
                "name": "storage_pool_1",
          "used": 26501122
        "mirror": {
          "enabled": "",
          "state": "string"
        "plexes": [
            "name": "plex0"
        "primary": {
          "checksum_style": "string",
          "disk_class": "performance",
          "disk_count": 8,
          "raid_size": 16,
              "name": "string",
        "storage_type": "string"
      "cloud_storage": {
        "stores": [
            "cloud_store": {
              "name": "store1",
            "used": 0
      "create_time": "2018-01-01 16:00:00 +0000",
      "dr_home_node": {
        "name": "node1",
      "home_node": {
        "name": "node1",
      "inactive_data_reporting": {
        "start_time": "2019-12-12 16:00:00 +0000"
      "inode_attributes": {
        "file_private_capacity": 31136,
        "file_public_capacity": 31136,
        "files_private_used": 502,
        "files_total": 31136,
        "files_used": 97,
        "max_files_available": 31136,
        "max_files_possible": 2844525,
        "max_files_used": 97,
        "used_percent": 5,
        "version": 4
      "is_spare_low": "",
      "metric": {
        "duration": "PT15S",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 11:20:13 +0000"
      "name": "node1_aggr_1",
      "node": {
        "name": "node1",
      "recommendation_spares": [
          "disk_class": "solid_state",
          "is_partition": 1,
          "layout_requirements": [
              "aggregate_min_disks": 6,
              "raid_group": {
                "default": 16,
                "max": 28,
                "min": 5
          "node": {
            "name": "node1",
          "size": 10156769280,
          "syncmirror_pool": "string",
          "total": 10,
          "usable": 9
      "snaplock_type": "string",
      "snapshot": {
        "files_total": 10,
        "files_used": 3,
        "max_files_available": 5,
        "max_files_used": 50
      "space": {
        "block_storage": {
          "aggregate_metadata": 2655,
          "aggregate_metadata_percent": 8,
          "available": 10156560384,
          "data_compacted_count": 1990000,
          "data_compaction_space_saved": 1996000,
          "data_compaction_space_saved_percent": 27,
          "full_threshold_percent": 0,
          "inactive_user_data": 304448,
          "inactive_user_data_percent": 0,
          "physical_used": 2461696,
          "physical_used_percent": 50,
          "used": 2088960,
          "used_including_snapshot_reserve": 674685,
          "used_including_snapshot_reserve_percent": 35,
          "used_percent": 50,
          "volume_deduplication_shared_count": 1990000,
          "volume_deduplication_space_saved": 1996000,
          "volume_deduplication_space_saved_percent": 27,
          "volume_footprints_percent": 14
        "cloud_storage": {
          "used": 402743264
        "efficiency": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "efficiency_without_snapshots": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "efficiency_without_snapshots_flexclones": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "footprint": 608896,
        "snapshot": {
          "available": 2000,
          "reserve_percent": 20,
          "total": 5000,
          "used": 3000,
          "used_percent": 45
      "state": "string",
      "statistics": {
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "uuid": "string",
      "volume-count": 0
  "spares": [
      "is_partition": 1,
          "raid_group": {
            "default": 16,
            "max": 28,
            "min": 5
      "node": {
        "name": "node1",
      "total": 10,
      "usable": 9
  "warnings": [
      "action": {
        "arguments": [
          "string"
        "message": "string"
      "name": "string",
      "warning": {
        "arguments": [
          "string"
        "message": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
787092
The target field cannot be specified for this operation.
918138
Internal error. Failed to get encryption operation status.
8586225
Encountered unexpected error in retrieving metrics and statistics for an aggregate.
19726341
Not enough eligible spare disks are available on the node.
19726344
No recommendation can be made for this cluster.
19726357
Aggregate recommendations are not supported on MetroCluster with Fibre Channel (FC).
19726358
Aggregate recommendations are not supported on ONTAP Cloud.
19726382
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again.
19726386
Encountered an error when retrieving licensing information on this cluster.
19726387
No recommendation can be provided for this cluster within the license capacity.
19726401
Aggregate recommendations are not supported when the DR group is not in the "normal" state.
19726402
Internal error. Unable to determine the MetroCluster configuration state.
19726403
Aggregate recommendation is not supported when there are no healthy target connections to remote storage.
19726404
The recommended mirrored aggregate couldn't use all the attached capacity in one of the SyncMirror pools. Make sure that the remote and local storage is symmetrically wired.
19726405
Not all local and remote disks attached to the node have been auto-partitioned.
19726406
Aggregate recommendations are not supported on this node because remote and local storage is not symmetrically wired.
19726540
The next tag is not supported for recommended aggregates. Retry the operation with a higher "return_timeout" value.
196608055
Aggregate recommendation is not supported on this node because it does not support NetApp Aggregate Encryption (NAE).
196608206
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
self
integer
Number of added data disks in RAID group.
integer
Number of added parity disks in RAID group.
integer
Number of existing data disks in the RAID group.
integer
Number of existing parity disks in the RAID group.
is_partition
boolean
Indicates whether the disk is partitioned (true) or whole (false).
name
string
Name of the raid group.
usable_size
integer
Usable size of each disk, in bytes.
storage_pool_reference
Shared Storage Pool
_links
_links
name
string
uuid
string
storage_pools
integer
Allocation count of storage pool.
storage_pool
Shared Storage Pool
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count
integer
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
disk_type
string
Type of disk being used by the aggregate's cache tier.
enabled
boolean
Specifies whether the aggregate uses HDDs with SSDs as a cache.
raid_size
integer
Option to specify the maximum number of disks that can be included in a RAID group.
raid_type
string
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
array[simulated_raid_groups]
size
integer
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
storage_pools
array[storage_pools]
List of storage pool properties and allocation_units_count for aggregate.
used
integer
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
mirror
enabled
boolean
Aggregate is SyncMirror protected
state
string
plex_reference
Plex
_links
_links
name
string
integer
integer
data_disk_count
integer
Number of data disks in RAID group.
integer
integer
is_partition
boolean
name
string
parity_disk_count
integer
Number of parity disks in RAID group.
raid_type
string
RAID type of the aggregate.
usable_size
integer
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
checksum_style
string
The checksum style used by the aggregate.
disk_class
string
The class of disks being used by the aggregate.
disk_count
integer
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache.
disk_type
string
The type of disk being used by the aggregate.
raid_size
integer
raid_type
string
block_storage
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier.
hybrid_cache
hybrid_cache
mirror
mirror
plexes
array[plex_reference]
Plex reference for each plex in the aggregate.
primary
primary
storage_type
string
Type of aggregate.
uses_partitions
boolean
If true, aggregate is using shared disks.
cloud_store
Cloud store
_links
_links
name
string
uuid
string
cloud_storage_tier
cloud_store
cloud_store
Cloud store
used
integer
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes.
cloud_storage
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier.
attach_eligible
boolean
Specifies whether the aggregate is eligible for a cloud store to be attached.
migrate_threshold
integer
Specifies the minimum percentage of performance tier free space that must exist in order for migration of data from the capacity tier to performance tier to be allowed. Only valid for PATCH operations.
stores
array[cloud_storage_tier]
Configuration information for each cloud storage portion of the aggregate.
tiering_fullness_threshold
integer
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations.
data_encryption
boolean
Specifies whether the aggregate uses self-encrypting drives with data protection enabled.
boolean
Specifies whether NetApp aggregate encryption is enabled. All data in the aggregate is encrypted.
dr_home_node
Node where the aggregate resides after disaster recovery. The value for this field might differ from the 'node' field during switchover.
name
string
uuid
string
home_node
Node where the aggregate resides after giveback. The value for this field might differ from the value of the 'node' field during takeover.
_links
_links
name
string
uuid
string
enabled
boolean
Specifes whether or not inactive data reporting is enabled on the aggregate.
start_time
string
Timestamp at which inactive data reporting was enabled on the aggregate.
inode_attributes
integer
Number of files that can currently be stored on disk for system metadata files. This number will dynamically increase as more system files are created. This is an advanced property; there is an added computationl cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
integer
Number of files that can currently be stored on disk for user-visible files. This number will dynamically increase as more user-visible files are created. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
files_private_used
integer
Number of system metadata files used. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
files_total
integer
Maximum number of user-visible files that this referenced file system can currently hold. If the referenced file system is restricted or offline, a value of 0 is returned.
files_used
integer
Number of user-visible files used in the referenced file system. If the referenced file system is restricted or offline, a value of 0 is returned.
max_files_available
integer
The count of the maximum number of user-visible files currently allowable on the referenced file system.
max_files_possible
integer
The largest value to which the maxfiles-available parameter can be increased by reconfiguration, on the referenced file system.
max_files_used
integer
The number of user-visible files currently in use on the referenced file system.
used_percent
integer
The percentage of disk space currently in use based on user-visible file count on the referenced file system.
version
integer
The inofile-version of the aggregate. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
The most recent sample of I/O metrics for the aggregate.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
node
Node where the aggregate currently resides.
_links
_links
name
string
uuid
string
raid_group
default
integer
Default number of disks in a RAID group.
max
integer
Maximum number of disks allowed in a RAID group.
min
integer
Minimum number of disks allowed in a RAID group.
layout_requirement
aggregate_min_disks
integer
Minimum number of disks to create an aggregate.
default
boolean
Indicates if this RAID type is the default.
raid_group
raid_group
raid_type
string
RAID type.
node
Node where the spares are assigned.
_links
_links
name
string
uuid
string
aggregate_spare
checksum_style
string
The checksum type that has been assigned to the spares.
disk_class
string
Disk class of spares.
disk_type
string
Type of disk.
is_partition
boolean
Indicates whether a disk is partitioned (true) or whole (false)
layout_requirements
array[layout_requirement]
Available RAID protections and their restrictions.
node
node
size
integer
Usable size of each spare, in bytes.
syncmirror_pool
string
SyncMirror spare pool.
total
integer
Total number of spares in the bucket. The total spare count for each class of spares also includes reserved spare capacity recommended by ONTAP best practices.
  • example: 10
  • readOnly: 1
  • x-nullable: true
usable
integer
Total number of usable spares in the bucket. The usable count for each class of spares does not include reserved spare capacity recommended by ONTAP best practices.
  • example: 9
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
snapshot
files_total
integer
Total files allowed in Snapshot copies
files_used
integer
Total files created in Snapshot copies
max_files_available
integer
Maximum files available for Snapshot copies
max_files_used
integer
Files in use by Snapshot copies
block_storage
aggregate_metadata
integer
Space used by different metafiles and internal operations inside the aggregate, in bytes.
integer
Aggregate metadata as a percentage.
available
integer
Space available in bytes.
integer
Amount of compacted data in bytes.
integer
Space saved in bytes by compacting the data.
integer
Percentage saved by compacting the data.
integer
The aggregate used percentage at which 'monitor.volume.full' EMS is generated.
inactive_user_data
integer
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **.
integer
The percentage of inactive user data in the block storage. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data_percent or **.
physical_used
integer
Total physical used size of an aggregate in bytes.
integer
Physical used percentage.
size
integer
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve.
used
integer
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata.
integer
Total used including the Snapshot copy reserve, in bytes.
integer
Total used including the Snapshot reserve as a percentage.
used_percent
integer
Aggregate used percentage.
integer
Amount of shared bytes counted by storage efficiency.
integer
Amount of space saved in bytes by storage efficiency.
integer
Percentage of space saved by storage efficiency.
integer
A summation of volume footprints inside the aggregate, as a percentage. A volume's footprint is the amount of space being used for the volume in the aggregate.
cloud_storage
used
integer
Used space in bytes in the cloud store. Only applicable for aggregates with a cloud store tier.
efficiency
Storage efficiency.
boolean
Indicates whether or not aggregate has auto adaptive compression savings.
boolean
Indicates whether or not cross volume background deduplication is enabled.
boolean
Indicates whether or not aggregate has cross volume deduplication savings.
boolean
Indicates whether or not cross volume inline deduplication is enabled.
logical_used
integer
Logical used
ratio
number
Data reduction ratio (logical_used / used)
savings
integer
Space saved by storage efficiencies (logical_used - used)
Storage efficiency that does not include the savings provided by Snapshot copies.
logical_used
integer
Logical used
ratio
number
savings
integer
Storage efficiency that does not include the savings provided by Snapshot copies and Flexclone volumes.
logical_used
integer
Logical used
ratio
number
savings
integer
snapshot
available
integer
Available space for Snapshot copies in bytes
reserve_percent
integer
Percentage of space reserved for Snapshot copies
total
integer
Total space for Snapshot copies in bytes
used
integer
Space used by Snapshot copies in bytes
used_percent
integer
Percentage of disk space used by Snapshot copies
space
block_storage
block_storage
cloud_storage
cloud_storage
efficiency
efficiency
Storage efficiency.
footprint
integer
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
snapshot
snapshot
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the aggregate.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
aggregate
_links
_links
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
block_storage
block_storage
cloud_storage
cloud_storage
create_time
string
Timestamp of aggregate creation.
data_encryption
data_encryption
dr_home_node
dr_home_node
home_node
home_node
inode_attributes
inode_attributes
is_spare_low
boolean
Specifies whether the aggregate is in a spares low condition on any of the RAID groups. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
metric
metric
name
string
Aggregate name.
node
node
Information on the aggregate's remaining hot spare disks.
sidl_enabled
boolean
Specifies whether or not SIDL is enabled on the aggregate.
snaplock_type
string
SnapLock type.
snapshot
snapshot
space
space
state
string
Operational state of the aggregate.
statistics
statistics
uuid
string
Aggregate UUID.
volume-count
integer
Number of volumes in the aggregate.
action
arguments
array[string]
Arguments present in the specified action message.
code
integer
Corrective action code of the specified action.
message
string
Specifies the corrective action to be taken to resolve the issue.
warning
arguments
array[string]
Arguments present in the warning message encountered.
code
integer
Warning code of the warning encountered.
message
string
Details of the warning encountered by the aggregate simulate query.
aggregate_warning
action
action
name
string
Name of the entity that returns the warning.
warning
warning
