Manage cluster licensing
Use these endpoints to manage cluster licensing and tailor system features to your organizational needs. Install or retrieve licenses to activate new capabilities and ensure compliance with licensing terms.
Overview
Licensing allows you to tailor a system to meet an organization's specific needs. You can enable new features by purchasing a license from a NetApp sales associate. After installation of the license, the new feature is available immediately.
This interface manages licenses according to their supported feature. By default, the interface displays packages with installed licenses, but you can also return unlicensed packages.
Each feature has a compliance state that is indicated at the package level. Individual licenses also contain a compliance state indicated in the "licenses" array. The state of the package is determined by analyzing the underlying licenses according to the following criteria:
Licensing terms
Cluster state
Licensing terms
The licensing terms define the conditions under which a package is considered "compliant". Individual licenses are evaluated based on the following:
Scope
Time period
Usage
Scope
A package can be licensed under the following scopes:
Site - Permits the feature to be used by any node in any cluster.
Cluster - Permits the feature to be used by any node in a single specific cluster.
Node - Permits the authorized node to use the feature. Within a cluster, if you don't supply every node with a valid license, the package state indicates "noncompliant". You must purchase a license for each node in a cluster for the package to be considered "compliant".
Time period
Some package licenses are only valid for a limited period of time. After a license has expired, the package state changes to "noncompliant". You need to purchase a new license for the package to return to a "compliant" state.
Usage
Some package licenses have additional terms that need to be maintained to keep a license in compliance. These conditions are defined by the individual license. For example, a license might define the maximum amount of storage that a node can allocate for the license to be "compliant".
Cluster state
A cluster's state consists of the following:
Node online status
Node cluster membership
Some features require that a node be online to display a valid compliance state. If a node cannot be reached or is not known to the cluster, the individual license might indicate an "unknown" state.
Licensing keys
A license is issued in one of the following three formats:
28-character key
NetApp License File Version 1 (NLFv1)
NetApp License File Version 2 (NLFv2)
Overview of NLFv1 and NLFv2 License Formats
NLFv1 and NLFv2 licenses are both JSON based files that allow features to be enabled.
The difference between the two formats is that a NLFv2 license allows multiple features to be enabled with a single file. A NLFv1 license is capable of enabling a single feature.
These licenses are identified, in the various methods, as follows:
| Format | Identifying Keys |
28 Character Key |
name / serial_number |
NLFv1 |
NLFv2 |
licenses.installed_license / serial_number |
The following is an example of a 28-character key:
AMEPOSOIKLKGEEEEDGNDEKSJDEEE
The following is an example of an NLFv1 key:
"statusResp": {
"version": "1",
"serialNumber": "123456789",
"message": "Success",
"licenses": {
"capacity": "1",
"type": "capacity",
"licenseProtocol": "FABRICPOOL-TB",
"package": "FabricPool",
"licenseScope": "cluster"
"snStatus": "Active",
"product": "fabricpool",
"statusCode": "S007"
"Signature": "signatureABC"
The following is an example of an NLFv2 key:
"statusResp": {
"version": "2",
"product": "Sample NLFv2 License",
"licenses": {
"capacity": "1",
"type": "capacity",
"HostID": "5554444",
"package": [ "NFS", "CIFS" ],
"licenseScope": "node"
You can use this API to submit any format to enable features.
Retrieving a collection of licenses organized by package
This example retrieves a collection that contains one entry for each package (filtered to only the 'fabricpool' package).
# API
curl -X GET "https://<mgmt-ip>/api/cluster/licensing/licenses?fields=*&name=fabricpool"
# Response
200 OK
# JSON Body
"records": [
"name": "fabricpool",
"scope": "cluster",
"state": "compliant",
"description": "FabricPool License",
"licenses": [
"owner": "testcluster-1",
"serial_number": "4149027342",
"capacity": {
"maximum_size": 1099511627776,
"used_size": 0
"href": "/api/cluster/licensing/licenses/fabricpool"
"num_records": 1,
"href": "/api/cluster/licensing/licenses/?fields=*&name=fabricpool"
Retrieving a collection of licenses organized by package - for package cloud
The following example retrieves a collection that contains one entry for each package (filtered to only the 'cloud' package). The cloud package, in this example, is in the enforcement period as the license has expired. The REST GET output displays an additional field 'shutdown_imminent' to indicate that the system will shutdown.
# API
curl -X GET "https://<mgmt-ip>/api/cluster/licensing/licenses?fields=*&name=cloud"
# Response
200 OK
# JSON Body
"records": [
"name": "cloud",
"scope": "node",
"state": "noncompliant",
"description": "Cloud ONTAP License",
"entitlement": {
"action": "acquire_license",
"risk": "unlicensed"
"licenses": [
"owner": "test-vsim1",
"serial_number": "90120130000000000001",
"active": false,
"evaluation": true,
"expiry_time": "2021-10-26T19:57:41Z",
"shutdown_imminent": true,
"compliance": {
"href": "/api/cluster/licensing/licenses/cloud"
"num_records": 1,
"href": "/api/cluster/licensing/licenses/?fields=*&name=cloud"
Retrieving a collection of licenses installed with NLFv2
This example retrieves a collection of licenses that were installed by a NLFv2 formatted license.
The license is referenced by the installed license "Core*Bundle" and the license serial number "4212426890" |
# API
curl -X GET "https://<mgmt-ip>/api/cluster/licensing/licenses?fields=*&licenses.installed_license=Core*Bundle&serial_number=4212426890"
# Response
200 OK
# JSON Body
"records": [
"name": "nfs",
"scope": "node",
"description": "NFS License",
"entitlement": {
"risk": "medium"
"licenses": [
"owner": "test-vsim3",
"active": false,
"evaluation": false,
"compliance": {
"state": "unlicensed"
"owner": "test-vsim4",
"installed_license": "Core Bundle",
"host_id": "4212426890",
"serial_number": "4212426890",
"active": true,
"compliance": {
"capacity": {
"maximum_size": 10995116277760
"href": "/api/cluster/licensing/licenses/nfs/?licenses.installed_license=Core*Bundle"
"name": "cifs",
"scope": "node",
"description": "CIFS License",
"entitlement": {
"risk": "medium"
"licenses": [
"active": false,
"compliance": {
"active": true,
"compliance": {
"capacity": {
"href": "/api/cluster/licensing/licenses/cifs/?licenses.installed_license=Core*Bundle"
"name": "iscsi",
"scope": "node",
"description": "iSCSI License",
"entitlement": {
"risk": "medium"
"licenses": [
"active": false,
"compliance": {
"active": true,
"compliance": {
"capacity": {
"href": "/api/cluster/licensing/licenses/iscsi/?licenses.installed_license=Core*Bundle"
"name": "fcp",
"scope": "node",
"description": "FCP License",
"entitlement": {
"risk": "medium"
"licenses": [
"active": false,
"compliance": {
"active": true,
"compliance": {
"capacity": {
"href": "/api/cluster/licensing/licenses/fcp/?licenses.installed_license=Core*Bundle"
"name": "snaprestore",
"scope": "node",
"description": "SnapRestore License",
"entitlement": {
"risk": "medium"
"licenses": [
"active": false,
"compliance": {
"active": true,
"compliance": {
"capacity": {
"href": "/api/cluster/licensing/licenses/snaprestore/?licenses.installed_license=Core*Bundle"
"name": "flexclone",
"scope": "node",
"description": "FlexClone License",
"entitlement": {
"risk": "medium"
"licenses": [
"active": false,
"compliance": {
"active": true,
"compliance": {
"capacity": {
"href": "/api/cluster/licensing/licenses/flexclone/?licenses.installed_license=Core*Bundle"
"name": "nvme_of",
"scope": "node",
"description": "NVMe-oF License",
"licenses": [
"active": false,
"compliance": {
"active": true,
"compliance": {
"capacity": {
"href": "/api/cluster/licensing/licenses/nvme_of/?licenses.installed_license=Core*Bundle"
"name": "s3",
"scope": "node",
"description": "S3 License",
"entitlement": {
"risk": "medium"
"licenses": [
"active": false,
"compliance": {
"active": true,
"compliance": {
"capacity": {
"href": "/api/cluster/licensing/licenses/s3/?licenses.installed_license=Core*Bundle"
"num_records": 8,
"href": "/api/cluster/licensing/licenses?fields=*&licenses.installed_license=Core*Bundle&serial_number=4212426890"
Retrieving a collection of installed licenses
This example retrieves a collection containing all packages (except base) that have installed licenses.
# API
curl -X GET "https://<mgmt-ip>/api/cluster/licensing/licenses?fields=*&name=!base"
# Response
200 OK
# JSON Body
"records": [
"name": "nfs",
"scope": "node",
"entitlement": {
"action": "none",
"risk": "low"
"licenses": [
"serial_number": "1-81-0000000000000004149027492",
"href": "/api/cluster/licensing/licenses/nfs"
"name": "cifs",
"scope": "node",
"entitlement": {
"risk": "medium"
"licenses": [
"href": "/api/cluster/licensing/licenses/cifs"
"num_records": 2,
"href": "/api/cluster/licensing/licenses/?fields=*&name=!base"
Retrieving a collection of unlicensed packages
By default, unlicensed packages are filtered from the collection output. This example shows how to use a query to retrieve unlicensed packages.
# API
curl -X GET "https://<mgmt-ip>/api/cluster/licensing/licenses?name=flexcache&state=unlicensed"
# Response
200 OK
# JSON Body
"records": [
"name": "flexcache",
"href": "/api/cluster/licensing/licenses/flexcache"
"num_records": 1,
"href": "/api/cluster/licensing/licenses?name=flexcache&state=unlicensed"
Installing a NLF license
This example installs a single NLFv1 license. A NLFv2 license installs using the same procedure.
You must escape all the double quotes and backslash characters of the JSON license before it can be placed in the POST request. |
# API
curl -X POST "https://<mgmt-ip>/api/cluster/licensing/licenses"
# JSON Body
"keys" : [ "{\"statusResp\":{\"snStatus\": \"Active\", \"licenses\": {\"package\": \"FabricPool\", \"capacity\": \"1\", \"licenseProtocol\": \"FABRICPOOL-TB\", \"type\": \"capacity\", \"licenseScope\": \"cluster\"}, \"message\": \"Success\", \"statusCode\": \"S007\", \"version\": \"1\", \"product\": \"fabricpool\", \"serialNumber\": \"4149027342\"}, \"Signature\":\"SignatureABC\"}" ]
# Response
201 Created
Installing a 28-character key
This example installs a single 28-character key formatted license.
# API
# JSON Body
"keys" : [ "AAAAAAAAAAAAAAAAAAAAAAAAAAAA" ]
# Response
201 Created
Installing multiple licenses with one API call
This example shows how multiple keys can be provided to install multiple features in a single API call.
# API
# JSON Body
"keys" : [ "AAAAAAAAAAAAAAAAAAAAAAAAAAAA",
"BBBBBBBBBBBBBBBBBBBBBBBBBBBB" ]
# Response
201 Created
Retrieving information for a specific license package
This example shows how to retrieve information about the specific feature package fabricpool.
# API
curl -X GET "https://<mgmt-ip>/api/cluster/licensing/licenses/fabricpool"
# Response
200 OK
# JSON Body
"scope": "cluster",
"licenses": [
"serial_number": "123456789",
"capacity": {
"maximum_size": 109951162777600,
"used_size": 0
"href": "/api/cluster/licensing/licenses/fabricpool/"
Deleting a specific license
This example show how to delete a CIFS site license.
# API
curl -X DELETE "https://<mgmt-ip>/api/cluster/licensing/licenses/cifs?serial_number=1-80-000011"
# JSON Body
# Response
200 OK
Deleting with a query
The following example shows how to delete all NFS licenses specified with the '*' query.
# API
curl -X DELETE "https://<mgmt-ip>/api/cluster/licensing/licenses/nfs?serial_number=*"
# JSON Body
# Response
200 OK
Deleting all licenses installed with NLFv2
The following example shows how to delete all licenses installed by a NLFv2 formatted license.
# API
curl -X DELETE "https://<mgmt-ip>/api/cluster/licensing/licenses?licenses.installed_license=Core*Bundle&serial_number=4149026-97-8"
# JSON Body
"num_records": 1,
"href": "/api/cluster/licensing/licenses?licenses.installed_license=Core*Bundle&serial_number=4149026-97-8"
# Response
200 OK
