REST API reference
Manage DNS configurations
Overview
Displays DNS information and controls the DNS subsytem. DNS domain name and DNS servers are required parameters.
Retrieving DNS information
The DNS GET endpoint retrieves all of the DNS configurations for all SVMs. DNS configuration for the cluster is retrieved via /api/cluster .
Retrieving all of the fields for all of the DNS configurations
# The API:
/api/name-services/dns
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/dns?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "27eff5d8-22b2-11eb-8038-0050568ed32c",
      "name": "clust-1",
          "href": "/api/svm/svms/179d3c85-7053-11e8-b9b8-005056b41bd1"
    "domains": [
      "domain.example.com"
    "servers": [
      "44.44.44.44"
    "timeout":2,
    "attempts":1,
    "scope": "cluster",
        "href": "/api/name-services/dns/27eff5d8-22b2-11eb-8038-0050568ed32c"
    "uuid": "179d3c85-7053-11e8-b9b8-005056b41bd1",
    "svm": {
      "name": "vs1",
    "domains": [
      "domainA.example.com"
    "servers": [
      "10.10.10.10"
    "timeout":2,
    "attempts":1,
    "dynamic_dns": {
      "enabled": false,
      "use_secure": false,
      "time_to_live": "PT1H"
    "scope": "svm",
        "href": "/api/name-services/dns/179d3c85-7053-11e8-b9b8-005056b41bd1"
    "uuid": "19076d35-6e27-11e8-b9b8-005056b41bd1",
    "svm": {
      "name": "vs2",
          "href": "/api/svm/svms/19076d35-6e27-11e8-b9b8-005056b41bd1"
    "domains": [
      "sample.example.com"
    "servers": [
      "11.11.11.11",
      "22.22.22.22",
      "33.33.33.33"
    "timeout":2,
    "attempts":2,
    "dynamic_dns": {
      "enabled": true,
      "time_to_live": "PT3H"
    "scope": "svm",
        "href": "/api/name-services/dns/19076d35-6e27-11e8-b9b8-005056b41bd1"
"num_records": 3,
    "href": "/api/name-services/dns?fields=*"
Retrieving all DNS configurations whose domain name starts with dom*.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/dns?domains=dom*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "name": "vs1",
    "domains": [
"num_records": 1,
    "href": "/api/name-services/dns?domains=dom*"
Retrieving the DNS configuration for a specific SVM
# The API:
/api/name-services/dns/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/dns/179d3c85-7053-11e8-b9b8-005056b41bd1" -H "accept: application/hal+json"
# The response:
"svm": {
  "name": "vs1",
"domains": [
"servers": [
  "10.10.10.10"
"timeout":2,
"attempts":1,
"tld_query_enabled": true,
"source_address_match": true,
"packet_query_match": true,
"dynamic_dns": {
  "enabled": false,
  "time_to_live": "P1D"
"scope": "svm",
Retrieving the advanced fields "DNS status", "tld_query_enable", "source_address_match", and "packet_query_match" using wildcards **
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/dns/179d3c85-7053-11e8-b9b8-005056b41bd1?fileds=**" -H "accept: application/hal+json"
# The response:
"svm": {
  "name": "vs1",
"domains": [
"servers": [
  "10.10.10.10"
"timeout":2,
"attempts":1,
"dynamic_dns": {
  "enabled": false,
"scope": "svm",
"status": [
    "name_server": "10.10.10.10",
    "state": "up",
    "message": "Response time (msec): ",
    "code": 0
Creating a DNS configuration
The DNS POST endpoint creates a DNS configuration for the specified SVM.
Specifying only the required fields
# The API:
# The call:
    curl -X POST "https://<mgmt-ip>/api/name-services/dns" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"svm\": { \"uuid\": \"179d3c85-7053-11e8-b9b8-005056b41bd1\" }, \"domains\": [ \"domainA.example.com\" ], \"servers\": [ \"10.10.10.10\" ]}"
Specifying the optional fields as well
# The API:
# The call:
    curl -X POST "https://<mgmt-ip>/api/name-services/dns" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"svm\": { \"uuid\": \"179d3c85-7053-11e8-b9b8-005056b41bd1\" }, \"domains\": [ \"domainA.example.com\" ], \"servers\": [ \"10.10.10.10\" ], \"timeout\":2, \"attempts\":3}"
Specifying the scope of the SVM
# The API:
# The call:
    curl -X POST "https://<mgmt-ip>/api/name-services/dns" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"svm\": { \"uuid\": \"179d3c85-7053-11e8-b9b8-005056b41bd1\" }, \"domains\": [ \"domainA.example.com\" ], \"servers\": [ \"10.10.10.10\" ], \"timeout\":2, \"attempts\":3, \"scope\":\"svm\"}"
Updating a DNS configuration
The DNS PATCH endpoint updates the DNS configuration for the specified SVM.
Updating both the DNS domains and servers
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/dns/179d3c85-7053-11e8-b9b8-005056b41bd1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"domains\": [ \"domainA.example.com\", \"domainB.example.com\" ], \"servers\": [ \"10.10.10.10\", \"10.10.10.11\" ]}"
Updating the DNS servers only
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/dns/179d3c85-7053-11e8-b9b8-005056b41bd1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"servers\": [ \"10.10.10.10\" ]}"
Updating the optional fields "timeout", "attempts", and "source_address_match"
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/dns/179d3c85-7053-11e8-b9b8-005056b41bd1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"timeout\":2, \"attempts\":3, \"source_address_match\":true}"
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/dns/179d3c85-7053-11e8-b9b8-005056b41bd1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"timeout\":2, \"attempts\":3, \"dynamic_dns.enabled\":\"true\", \"dynamic_dns.time_to_live\":\"20h\"}"
Deleting a DNS configuration
The DNS DELETE endpoint deletes the DNS configuration for the specified SVM.
Example
The following example shows a DELETE operation.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/name-services/dns/179d3c85-7053-11e8-b9b8-005056b41bd1" -H "accept: application/hal+json"
