Manage FPolicy configuration
Overview
FPolicy is an infrastructure component of ONTAP that enables partner applications to connect to ONTAP in order to monitor and set file access permissions. Every time a client accesses a file from a storage system, based on the configuration of FPolicy, the partner application is notified about file access. This enables partners to set restrictions on files that are created or accessed on the storage system. FPolicy also allows you to create file policies that specify file operation permissions according to file type. For example, you can restrict certain file types, such as .jpeg and .mp3 files, from being stored on the storage system. FPolicy can monitor file access from CIFS and NFS clients.
As part of FPolicy configuration, you can specify an FPolicy engine which defines the external FPolicy server, FPolicy events, which defines the protocol and file operations to monitor and the FPolicy policy that acts as a container for the FPolicy engine and FPolicy events. It provides a way for policy management functions, such as policy enabling and disabling.
Creating an FPolicy configuration
To create an FPolicy for an SVM use the following API. Note that the return_records=true query parameter is used to obtain the newly created entry in the response.
# The API:
POST /protocols/fpolicy/
#The call:
curl -X POST "https://<mgmt-ip>/api/protocols/fpolicy?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"engines\": [ { \"name\": \"engine1\", \"port\": 9876, \"primary_servers\": [ \"10.132.145.22\", \"10.140.101.109\" ], \"secondary_servers\": [ \"10.132.145.20\", \"10.132.145.21\" ], \"type\": \"synchronous\", \"format\": \"xml\" } ], \"events\": [ { \"file_operations\": { \"read\": true, \"write\": true }, \"filters\": { \"monitor_ads\": true }, \"name\": \"event_cifs\", \"protocol\": \"cifs\", \"volume_monitoring\": true } ], \"policies\": [ { \"engine\": { \"name\": \"engine1\" }, \"events\": [ { \"name\": \"event_cifs\" } ], \"mandatory\": true, \"name\": \"pol0\", \"priority\": 1, \"scope\": { \"include_volumes\": [ \"vol1\" ] } } ], \"svm\": { \"name\": \"vs1\", \"uuid\": \"b34f5e3d-01d0-11e9-8f63-0050568ea311\" }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"uuid": "b34f5e3d-01d0-11e9-8f63-0050568ea311",
"name": "vs1"
"engines": [
"name": "engine1",
"primary_servers": [
"10.132.145.22",
"10.140.101.109"
"secondary_servers": [
"10.132.145.20",
"10.132.145.21"
"type": "synchronous",
"port": 9876,
"format": "xml"
"events": [
"name": "event_cifs",
"protocol": "cifs",
"volume_monitoring": true,
"file_operations": {
"read": true,
"write": true
"filters": {
"monitor_ads": true
"policies": [
"name": "pol0",
"priority": 1,
"events": [
"engine": {
"name": "engine1"
"scope": {
"include_volumes": [
"vol1"
"mandatory": true
Retrieving the FPolicy configuration for all the SVMs in the cluster
# The API:
GET /protocols/fpolicy
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
"svm": {
"name": "vs1"
"engines": [
"name": "engine1",
"10.132.145.22",
"10.140.101.109"
"10.132.145.20",
"10.132.145.21"
"port": 9876,
"format": "xml"
"events": [
"protocol": "cifs",
"close": false,
"create": false,
"create_dir": false,
"delete": false,
"delete_dir": false,
"getattr": false,
"link": false,
"lookup": false,
"open": false,
"read": true,
"write": true,
"rename": false,
"rename_dir": false,
"setattr": false,
"symlink": false
"filters": {
"monitor_ads": true,
"close_with_modification": false,
"close_without_modification": false,
"close_with_read": false,
"first_read": false,
"first_write": false,
"offline_bit": false,
"open_with_delete_intent": false,
"open_with_write_intent": false,
"write_with_size_change": false,
"setattr_with_owner_change": false,
"setattr_with_group_change": false,
"setattr_with_sacl_change": false,
"setattr_with_dacl_change": false,
"setattr_with_modify_time_change": false,
"setattr_with_access_time_change": false,
"setattr_with_creation_time_change": false,
"setattr_with_mode_change": false,
"setattr_with_size_change": false,
"setattr_with_allocation_size_change": false,
"exclude_directory": false
"policies": [
"name": "pol0",
"enabled": true,
"priority": 1,
"events": [
"engine": {
"name": "engine1"
"scope": {
"vol1"
"mandatory": true,
"passthrough_read": false,
"allow_privileged_access": false
"num_records": 1
Retrieving an FPolicy configuration for a particular SVM
# The API:
GET /protocols/fpolicy/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/b34f5e3d-01d0-11e9-8f63-0050568ea311?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1"
"engines": [
"name": "engine1",
"10.132.145.22",
"10.140.101.109"
"10.132.145.20",
"10.132.145.21"
"port": 9876,
"format": "xml"
"events": [
"protocol": "cifs",
"close": false,
"create": false,
"delete": false,
"getattr": false,
"link": false,
"lookup": false,
"open": false,
"read": true,
"write": true,
"rename": false,
"setattr": false,
"symlink": false
"filters": {
"policies": [
"name": "pol0",
"enabled": true,
"priority": 1,
"events": [
"engine": {
"name": "engine1"
"scope": {
"vol1"
"mandatory": true,
Deleting an FPolicy configuration for a particular SVM
# The API:
DELETE /protocols/fpolicy/{svm.uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/fpolicy/b34f5e3d-01d0-11e9-8f63-0050568ea311" -H "accept: application/json"
