REST API reference
Manage SAML service
Access and modify the SAML service provider configuration in your cluster using these endpoints. Retrieve existing configurations, create new ones, or update and remove them as needed to manage authentication settings effectively.
Overview
This API is used to retrieve and display relevant information pertaining to the SAML service provider configuration in the cluster. The POST request creates a SAML service provider configuration if there is none present. The DELETE request removes the SAML service provider configuration. The PATCH request enables and disables SAML in the cluster. Various responses are shown in the examples below.
Retrieving the SAML service provider configuration in the cluster
The following output shows the SAML service provider configuration in the cluster.
# The API:
/api/security/authentication/cluster/saml-sp
# The call:
curl -X GET "https://<mgmt-ip>/api/security/authentication/cluster/saml-sp" -H "accept: application/hal+json"
# The response:
"idp_uri": "https://examplelab.customer.com/idp/Metadata",
"enabled": true,
"host": "172.21.74.181",
"certificate": {
  "ca": "cluster1",
  "serial_number": "156F10C3EB4C51C1",
  "common_name": "cluster1"
    "href": "/api/security/authentication/cluster/saml-sp"
Creating the SAML service provider configuration
The following output shows how to create a SAML service provider configuration in the cluster.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/security/authentication/cluster/saml-sp?return_records=true" -H "accept: application/hal+json" -d '{ "idp_uri": "https://examplelab.customer.com/idp/Metadata", "host": "172.21.74.181", "certificate": { "ca": "cluster1", "serial_number": "156F10C3EB4C51C1" }}'
Updating the SAML service provider configuration
The following output shows how to enable a SAML service provider configuration in the cluster.
Disabling the configuration requires the client to be authenticated through SAML prior to performing the operation.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/authentication/cluster/saml-sp/" -d '{ "enabled": true }'
Deleting the SAML service provider configuration
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/security/authentication/cluster/saml-sp/"
